#include <ossimWarpProjection.h>
| ossimWarpProjection () | |
| ossimWarpProjection (ossimProjection *client) | |
| ossimWarpProjection (const ossimKeywordlist &geom_kwl, const char *prefix=0) | |
| ~ossimWarpProjection () | |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSampPt) const |
| virtual void | lineSampleToWorld (const ossimDpt &lineSampPt, ossimGpt &worldPt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &hgtEllipsoid, ossimGpt &worldPt) const |
| virtual bool | operator== (const ossimProjection &) const |
| virtual ossim2dTo2dTransform * | getWarpTransform () |
| virtual ossim2dTo2dTransform * | getAffineTransform () |
| virtual ossimProjection * | getClientProjection () |
| virtual void | setNewWarpTransform (ossim2dTo2dTransform *warp) |
| virtual void | setNewAffineTransform (ossim2dTo2dTransform *affine) |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Protected Attributes | |
| ossimRefPtr< ossimProjection > | theClientProjection |
| ossimRefPtr< ossim2dTo2dTransform > | theWarpTransform |
| ossimRefPtr< ossim2dTo2dTransform > | theAffineTransform |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const ossimWarpProjection &m) |
| ossimWarpProjection::ossimWarpProjection | ( | ) |
Default Contructor:
Definition at line 37 of file ossimWarpProjection.cpp.
References theAffineTransform, and theWarpTransform.
Referenced by dup().
| ossimWarpProjection::ossimWarpProjection | ( | ossimProjection * | client | ) |
Primary constructor accepting pointer to the underlying client projection.
Definition at line 54 of file ossimWarpProjection.cpp.
| ossimWarpProjection::ossimWarpProjection | ( | const ossimKeywordlist & | geom_kwl, |
| const char * | prefix = 0 |
Constructor accepts OSSIM keywordlist geometry file.
Definition at line 68 of file ossimWarpProjection.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimProjectionFactoryRegistry::instance(), ossim2dTo2dTransform::loadState(), ossimErrorCodes::OSSIM_ERROR, ossimErrorStatusInterface::setErrorStatus(), theAffineTransform, theClientProjection, and theWarpTransform.
| ossimWarpProjection::~ossimWarpProjection | ( | ) |
Definition at line 94 of file ossimWarpProjection.cpp.
References theAffineTransform, theClientProjection, and theWarpTransform.
Returns pointer to a new instance, copy of this.
Implements ossimProjection.
Definition at line 270 of file ossimWarpProjection.cpp.
References ossimWarpProjection(), and saveState().
inlinevirtual |
Definition at line 107 of file ossimWarpProjection.h.
inlinevirtual |
Definition at line 111 of file ossimWarpProjection.h.
ACCESS METHODS:
Definition at line 290 of file ossimWarpProjection.cpp.
References ossimProjection::getMetersPerPixel(), ossim::nan(), theClientProjection, and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 103 of file ossimWarpProjection.h.
inlinevirtual |
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
Definition at line 138 of file ossimWarpProjection.h.
References ossimProjection::isAffectedByElevation(), theClientProjection, and ossimRefPtr< T >::valid().
Performs the inverse projection from line, sample to ground, bypassing reference to elevation surface:
Definition at line 149 of file ossimWarpProjection.cpp.
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 126 of file ossimWarpProjection.cpp.
Reimplemented from ossimProjection.
Definition at line 223 of file ossimWarpProjection.cpp.
inlinevirtual |
Compares this instance with arg projection. NOT IMPLEMENTED.
Definition at line 98 of file ossimWarpProjection.h.
Returns projection's ground point origin. That is the GP corresponding to line=0, sample=0.
Definition at line 280 of file ossimWarpProjection.cpp.
References ossimProjection::origin(), theClientProjection, and ossimRefPtr< T >::valid().
Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 173 of file ossimWarpProjection.cpp.
References ossimProjection::print(), theAffineTransform, theClientProjection, theWarpTransform, and ossimRefPtr< T >::valid().
Referenced by operator<<().
Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 200 of file ossimWarpProjection.cpp.
Definition at line 306 of file ossimWarpProjection.cpp.
References theAffineTransform.
Definition at line 298 of file ossimWarpProjection.cpp.
References theWarpTransform.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 104 of file ossimWarpProjection.cpp.
friend |
Definition at line 192 of file ossimWarpProjection.cpp.
protected |
Definition at line 133 of file ossimWarpProjection.h.
Referenced by ossimWarpProjection(), print(), setNewAffineTransform(), and ~ossimWarpProjection().
protected |
Data Members:
Definition at line 131 of file ossimWarpProjection.h.
Referenced by getMetersPerPixel(), isAffectedByElevation(), origin(), ossimWarpProjection(), print(), and ~ossimWarpProjection().
protected |
Definition at line 132 of file ossimWarpProjection.h.
Referenced by ossimWarpProjection(), print(), setNewWarpTransform(), and ~ossimWarpProjection().
