#include <ossimAffineProjection.h>
| ossimAffineProjection () | |
| ossimAffineProjection (ossimProjection *client) | |
| ossimAffineProjection (const ossimKeywordlist &geom_kwl, const char *prefix=NULL) | |
| ~ossimAffineProjection () | |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSampPt) const |
| virtual void | lineSampleToWorld (const ossimDpt &lineSampPt, ossimGpt &worldPt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &hgtEllipsoid, ossimGpt &worldPt) const |
| virtual bool | operator== (const ossimProjection &) const |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Protected Attributes | |
| ossimRefPtr< ossimProjection > | theClientProjection |
| ossimRefPtr< ossim2dTo2dTransform > | theAffineTransform |
Friends | |
| std::ostream & | operator<< (std::ostream &os, const ossimAffineProjection &m) |
| ossimAffineProjection::ossimAffineProjection | ( | ) |
Default Contructor:
Definition at line 32 of file ossimAffineProjection.cpp.
Referenced by dup().
| ossimAffineProjection::ossimAffineProjection | ( | ossimProjection * | client | ) |
Primary constructor accepting pointer to the underlying client projection.
Definition at line 46 of file ossimAffineProjection.cpp.
| ossimAffineProjection::ossimAffineProjection | ( | const ossimKeywordlist & | geom_kwl, |
| const char * | prefix = NULL |
Constructor accepts OSSIM keywordlist geometry file.
Definition at line 57 of file ossimAffineProjection.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimProjectionFactoryRegistry::instance(), ossim2dTo2dTransform::loadState(), ossimErrorCodes::OSSIM_ERROR, ossimErrorStatusInterface::setErrorStatus(), theAffineTransform, and theClientProjection.
| ossimAffineProjection::~ossimAffineProjection | ( | ) |
Definition at line 78 of file ossimAffineProjection.cpp.
Returns pointer to a new instance, copy of this.
Implements ossimProjection.
Definition at line 242 of file ossimAffineProjection.cpp.
References ossimAffineProjection(), and saveState().
ACCESS METHODS:
Definition at line 263 of file ossimAffineProjection.cpp.
References ossimProjection::getMetersPerPixel(), ossim::nan(), theClientProjection, and ossimRefPtr< T >::valid().
inlinevirtual |
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
Definition at line 108 of file ossimAffineProjection.h.
Performs the inverse projection from line, sample to ground, bypassing reference to elevation surface:
Definition at line 129 of file ossimAffineProjection.cpp.
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 106 of file ossimAffineProjection.cpp.
Reimplemented from ossimProjection.
Definition at line 197 of file ossimAffineProjection.cpp.
inlinevirtual |
Compares this instance with arg projection. NOT IMPLEMENTED.
Definition at line 98 of file ossimAffineProjection.h.
Returns projection's ground point origin. That is the GP corresponding to line=0, sample=0.
Definition at line 253 of file ossimAffineProjection.cpp.
References ossimProjection::origin(), theClientProjection, and ossimRefPtr< T >::valid().
Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 152 of file ossimAffineProjection.cpp.
References ossimProjection::print(), theAffineTransform, theClientProjection, and ossimRefPtr< T >::valid().
Referenced by operator<<().
Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 179 of file ossimAffineProjection.cpp.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 86 of file ossimAffineProjection.cpp.
friend |
Definition at line 171 of file ossimAffineProjection.cpp.
protected |
Definition at line 116 of file ossimAffineProjection.h.
Referenced by ossimAffineProjection(), and print().
protected |
Data Members:
Definition at line 115 of file ossimAffineProjection.h.
Referenced by getMetersPerPixel(), origin(), ossimAffineProjection(), and print().
