#include <ossimHistogramSource.h>
| virtual | ~ossimHistogramSource () |
| virtual ossimRefPtr< ossimMultiResLevelHistogram > | getHistogram () |
| virtual | ~ossimSource () |
| virtual bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0 |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimHistogramSource (ossimObject *owner=NULL, ossim_uint32 numberOfInputs=0, ossim_uint32 numberOfOutputs=0, bool inputListFixedFlag=true, bool outputListFixedFlag=true) | |
Protected Attributes | |
| ossimRefPtr< ossimMultiResLevelHistogram > | theHistogram |
| ossimFilename | theFilename |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Private Member Functions | |
| ossimHistogramSource (const ossimHistogramSource &) | |
| Hidden from use copy constructor. More... | |
Definition at line 19 of file ossimHistogramSource.h.
Definition at line 35 of file ossimHistogramSource.cpp.
protected |
Definition at line 20 of file ossimHistogramSource.cpp.
private |
Definition at line 101 of file ossimHistogramSource.cpp.
Reimplemented in ossimImageHistogramSource.
Definition at line 39 of file ossimHistogramSource.cpp.
References theHistogram.
Referenced by ossimImageSourceHistogramFilter::getHistogram(), and ossimHistogramWriter::writeHistogram().
Definition at line 44 of file ossimHistogramSource.cpp.
References ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimMultiResLevelHistogram::importHistogram(), ossimSource::loadState(), ossimMultiResLevelHistogram::loadState(), theFilename, and theHistogram.
Referenced by ossimImageHistogramSource::loadState().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 73 of file ossimHistogramSource.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimString::empty(), ossimKeywordNames::FILENAME_KW, ossimSource::saveState(), ossimMultiResLevelHistogram::saveState(), theFilename, theHistogram, ossimRefPtr< T >::valid(), and ossimKeywordlist::write().
Referenced by ossimImageHistogramSource::saveState().
protected |
if the filename is not "" then it will use this to store the histogram outside the keywordlist.
it will set the filename keyword to the filename and during a save state will save it out to the file instead of inline to the keyword list.
Definition at line 48 of file ossimHistogramSource.h.
Referenced by loadState(), and saveState().
protected |
Definition at line 38 of file ossimHistogramSource.h.
Referenced by ossimImageHistogramSource::computeFastModeHistogram(), ossimImageHistogramSource::computeNormalModeHistogram(), ossimImageHistogramSource::execute(), getHistogram(), ossimImageHistogramSource::getHistogram(), loadState(), and saveState().
