This is the elevation database registry. More...
#include <ossimElevationDatabaseRegistry.h>
| ossimElevationDatabaseRegistry () | |
| void | getTypeNameList (std::vector< ossimString > &typeList) const |
| ossimElevationDatabase * | createDatabase (const ossimString &typeName) const |
| ossimElevationDatabase * | createDatabase (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimElevationDatabase * | open (const ossimString &connectionString) |
Public Member Functions inherited from ossimFactoryListInterface< ossimElevationDatabaseFactoryBase, ossimElevationDatabase > | |
| ossimFactoryListInterface () | |
| void | addFactory (ossimElevationDatabaseFactoryBase *factory) |
| This is for backward compatability and calls registerFactory for simple adds. More... | |
| bool | isFactoryRegistered (ossimElevationDatabaseFactoryBase *factory) const |
| Public access method to determine if a factory is already registered to this list. More... | |
| void | registerFactory (ossimElevationDatabaseFactoryBase *factory, bool pushToFrontFlag=false) |
| Will register a factory to the factory list. More... | |
| void | unregisterFactory (ossimElevationDatabaseFactoryBase *factory) |
| Will remove the factory from the registry. More... | |
| void | unregisterFactory (const ossimString &factoryTypeName) |
| Will remove the factory from the registry by name. More... | |
| void | unregisterAllFactories () |
| Will remove all factories from the registry. More... | |
| void | registerFactoryToFront (ossimElevationDatabaseFactoryBase *factory) |
| Inserts the factory to the front of the list. More... | |
| void | registerFactoryBefore (ossimElevationDatabaseFactoryBase *factory, ossimElevationDatabaseFactoryBase *beforeThisFactory) |
| Will insert the factory before the beforeThisFactory. More... | |
| void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
| Will add all object types the factories can allocate. More... | |
| ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
| This is the base object return for all objects in the system. More... | |
| ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimElevationDatabase * | createNativeObjectFromRegistry (const ossimString &typeName) const |
| This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More... | |
| ossimElevationDatabase * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| static ossimElevationDatabaseRegistry * | instance () |
Static Protected Attributes | |
| static ossimElevationDatabaseRegistry * | m_instance = 0 |
Public Types inherited from ossimFactoryListInterface< ossimElevationDatabaseFactoryBase, ossimElevationDatabase > | |
| typedef std::vector< ossimElevationDatabaseFactoryBase *> | FactoryListType |
| typedef ossimElevationDatabaseFactoryBase | FactoryType |
| typedef ossimElevationDatabase | NativeReturnType |
Protected Member Functions inherited from ossimFactoryListInterface< ossimElevationDatabaseFactoryBase, ossimElevationDatabase > | |
| bool | findFactory (ossimElevationDatabaseFactoryBase *factory) const |
| Utility to find a factory in the list. More... | |
Protected Attributes inherited from ossimFactoryListInterface< ossimElevationDatabaseFactoryBase, ossimElevationDatabase > | |
| std::mutex | m_factoryListMutex |
| FactoryListType | m_factoryList |
Definition at line 14 of file ossimElevationDatabaseRegistry.h.
inline |
Definition at line 18 of file ossimElevationDatabaseRegistry.h.
Referenced by instance().
| ossimElevationDatabase * ossimElevationDatabaseRegistry::createDatabase | ( | const ossimString & | typeName | ) | const |
| typeName | is the type name of the database you wish to create |
Definition at line 18 of file ossimElevationDatabaseRegistry.cpp.
References ossimFactoryListInterface< ossimElevationDatabaseFactoryBase, ossimElevationDatabase >::m_factoryList.
| ossimElevationDatabase * ossimElevationDatabaseRegistry::createDatabase | ( | const ossimKeywordlist & | kwl, |
| const char * | prefix = 0 |
| ) | const |
| kwl | kewyord list that has state information about how to create a database |
| prefix | prefix key to use when loading the state information. |
Definition at line 30 of file ossimElevationDatabaseRegistry.cpp.
inline |
Definition at line 23 of file ossimElevationDatabaseRegistry.h.
References ossimFactoryListInterface< T, NativeType >::getAllTypeNamesFromRegistry().
static |
Definition at line 6 of file ossimElevationDatabaseRegistry.cpp.
References ossimElevationDatabaseFactory::instance(), m_instance, ossimElevationDatabaseRegistry(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
Referenced by ossimElevManager::getCellsForBounds(), and ossimElevManager::loadElevationPath().
| ossimElevationDatabase * ossimElevationDatabaseRegistry::open | ( | const ossimString & | connectionString | ) |
| connectionString | used to determine which database can support that connection. |
Definition at line 43 of file ossimElevationDatabaseRegistry.cpp.
staticprotected |
Definition at line 51 of file ossimElevationDatabaseRegistry.h.
