Base class for all automatic tiepoints. More...
#include <AutoTiePoint.h>
| AutoTiePoint () | |
| AutoTiePoint (const AutoTiePoint ©_me) | |
| AutoTiePoint (std::shared_ptr< AtpGenerator > generator, const std::string &id) | |
| Constructs given two images and a point on the REF image. More... | |
| AutoTiePoint (const Json::Value &tp_json_node) | |
| Creates new tiepoint from JSON object formatted as: { "id": <unsigned int>="">, // may be ignored if not valid "type": "M"|"A"|"G" For “manual”, “auto”, or “GCP-associated” "imagePoints: [ { "imageId": <string>, "x": <double>, "y": <double>, "covariance": [ cxx, cyy, cxy ], "gcpId": <string> Only if associated with a GCP } ] }. More... | |
| virtual | ~AutoTiePoint () |
| void | setRefImagePt (const ossimDpt &imagePt) |
| Sets the reference image's image point (in image space) for this tiepoint. More... | |
| void | setRefViewPt (const ossimDpt &viewPt) |
| Sets the reference image's view point (in view space) for this tiepoint. More... | |
| bool | getVectorResidual (ossimDpt &residual) const |
| Returns the vector residual (CMP-REF) of current active peak (in view space) via argument. More... | |
| bool | getRefImagePoint (ossimDpt &image_pt) const |
| Returns the center location of the reference patch (the feature) in image-space. More... | |
| bool | getCmpImagePoint (ossimDpt &image_pt) const |
| Fetches the comparison image point for current best peak. Returns false if no valid peak. More... | |
| Stream output dump of object. More... | |
| std::vector< MatchPoint > & | matchPoints () |
| Access to peaks list for GUI debug display. More... | |
| void | addImageMatch (const ossimDpt &cmpPt, double confidenceValue=1.0) |
| Inserts match in image space by confidence in descending order. More... | |
| void | addViewMatch (const ossimDpt &cmpViewPt, double confidenceValue=1.0) |
| unsigned int | getNumMatches () const |
| Returns the total number of peaks in the list. More... | |
| bool | hasValidMatch () const |
| Returns true if there is a valid peak in the list. More... | |
| bool | getConfidenceMeasure (double &confidence) const |
| Returns the correlation value of current active peak via argument. Returns true if valid. More... | |
| bool | getRefViewPoint (ossimDpt &view_pt) const |
| Returns the center location of the reference patch (the feature) in view-space. More... | |
| bool | getRefGroundPoint (ossimGpt &gpt) const |
| Returns the center location of the reference patch (the feature) in geographic. More... | |
| bool | getCmpViewPoint (ossimDpt &view_pt, unsigned int peak_idx=0) const |
| Fetches the comparison view point for current best peak, or for the peak indicated if provided. More... | |
| bool | bumpActiveMatch () |
| Removes the active match and sets the next peak as active. More... | |
| virtual void | saveJSON (Json::Value &json) const |
Public Member Functions inherited from ossim::TiePoint | |
| TiePoint () | |
| TiePoint (const TiePoint ©) | |
| virtual | ~TiePoint () |
| unsigned int | getImageCount () const |
| const std::string & | getTiePointId () const |
| void | setTiePointId (const std::string &id) |
| void | getImagePoint (unsigned int index, std::string &imageId, ossimDpt &imagePoint, NEWMAT::SymmetricMatrix &cov) const |
| Fetches the image point coordinates along with image ID and GCP ID if available. More... | |
| void | setImagePoint (std::shared_ptr< Image > image, const ossimDpt &imagePoint, const NEWMAT::SymmetricMatrix &cov) |
| Sets image point value and associated measurement covariance for specified image ID. More... | |
| Type | getType () const |
| void | setType (Type t) |
| const std::string & | getGcpId () const |
| void | setGcpId (const std::string &id) |
| virtual void | loadJSON (const Json::Value &json) |
Public Member Functions inherited from ossim::JsonInterface | |
| JsonInterface () | |
| virtual | ~JsonInterface () |
| virtual void | recomputeResidual () |
| Recomputes active peak's residual after a model adjustment or change in peak. More... | |
Protected Attributes | |
| std::shared_ptr< AtpGenerator > | m_generator |
| std::vector< MatchPoint > | m_matchPoints |
| ossimDpt | m_refViewPt |
| ossimDpt | m_cmpViewPt |
| ossimDpt | m_residual |
| double | m_relativeError |
| Uncertainty in position of feature in CMP image. More... | |
Protected Attributes inherited from ossim::TiePoint | |
| Type | m_type |
| std::string | m_tiePointId |
| std::vector< std::shared_ptr< Image > > | m_images |
| std::vector< ossimDpt > | m_imagePoints |
| std::vector< NEWMAT::SymmetricMatrix > | m_covariances |
| double | m_gsd |
| std::string | m_gcpId |
Public Types inherited from ossim::TiePoint | |
| enum | Type { UNASSIGNED, MANUAL, AUTO, GCP } |
Static Protected Attributes inherited from ossim::TiePoint | |
| static int | s_runningId = 1 |
These differ from tiepoint base class in that it is guarantied to represent a single image pair. Therefore, residuals between the pair can be computed without referencing image ids, etc. TODO: Eventually need to generalize to permit N-way auto-tiepoints, at which point it should merge with TiePoint base class.
Definition at line 30 of file AutoTiePoint.h.
| ATP::AutoTiePoint::AutoTiePoint | ( | ) |
Definition at line 18 of file AutoTiePoint.cpp.
| ATP::AutoTiePoint::AutoTiePoint | ( | const AutoTiePoint & | copy_me | ) |
Definition at line 24 of file AutoTiePoint.cpp.
References m_matchPoints.
| ATP::AutoTiePoint::AutoTiePoint | ( | std::shared_ptr< AtpGenerator > | generator, |
| const std::string & | id | ||
The matching is still to be established.
| overlap | The combiner source representing the overlap between REF and CMP images. Tie point ID |
| ATP::AutoTiePoint::AutoTiePoint | ( | const Json::Value & | tp_json_node | ) |
Definition at line 55 of file AutoTiePoint.cpp.
Definition at line 62 of file AutoTiePoint.cpp.
| void ATP::AutoTiePoint::addImageMatch | ( | const ossimDpt & | cmpPt, |
| double | confidenceValue = 1.0 |
Definition at line 154 of file AutoTiePoint.cpp.
References ossim::TiePoint::m_imagePoints, m_matchPoints, m_residual, ossimDpt::makeNan(), and recomputeResidual().
Referenced by addViewMatch().
| void ATP::AutoTiePoint::addViewMatch | ( | const ossimDpt & | cmpViewPt, |
Definition at line 207 of file AutoTiePoint.cpp.
References addImageMatch(), m_cmpViewPt, m_generator, and m_matchPoints.
| bool ATP::AutoTiePoint::bumpActiveMatch | ( | ) |
Returns TRUE unless there are no more active matches.
Definition at line 192 of file AutoTiePoint.cpp.
References m_matchPoints, and recomputeResidual().
| bool ATP::AutoTiePoint::getCmpImagePoint | ( | ossimDpt & | image_pt | ) | const |
Definition at line 73 of file AutoTiePoint.cpp.
References ossim::TiePoint::m_imagePoints.
| bool ATP::AutoTiePoint::getCmpViewPoint | ( | ossimDpt & | view_pt, |
| unsigned int | peak_idx = 0 |
| ) | const |
Definition at line 229 of file AutoTiePoint.cpp.
References m_cmpViewPt.
| bool ATP::AutoTiePoint::getConfidenceMeasure | ( | double & | confidence | ) | const |
Definition at line 178 of file AutoTiePoint.cpp.
References hasValidMatch(), and m_matchPoints.
inline |
Definition at line 95 of file AutoTiePoint.h.
| bool ATP::AutoTiePoint::getRefGroundPoint | ( | ossimGpt & | gpt | ) | const |
Returns false if point not yet defined. Note that there may not be any valid peak.
Definition at line 258 of file AutoTiePoint.cpp.
References ossimDpt::isNan(), m_generator, m_refViewPt, and ossimGpt::makeNan().
| bool ATP::AutoTiePoint::getRefImagePoint | ( | ossimDpt & | image_pt | ) | const |
Returns false if point not yet defined. Note that there not be any valid peak.
Definition at line 81 of file AutoTiePoint.cpp.
| bool ATP::AutoTiePoint::getRefViewPoint | ( | ossimDpt & | view_pt | ) | const |
Definition at line 221 of file AutoTiePoint.cpp.
References ossimDpt::isNan(), and m_refViewPt.
| bool ATP::AutoTiePoint::getVectorResidual | ( | ossimDpt & | residual | ) | const |
Definition at line 67 of file AutoTiePoint.cpp.
References m_residual.
| bool ATP::AutoTiePoint::hasValidMatch | ( | ) | const |
Definition at line 202 of file AutoTiePoint.cpp.
Referenced by getConfidenceMeasure().
inline |
Definition at line 86 of file AutoTiePoint.h.
Reimplemented from ossim::TiePoint.
Definition at line 129 of file AutoTiePoint.cpp.
References DEG_PER_RAD, ossim::TiePoint::m_imagePoints, m_matchPoints, m_residual, ossim::TiePoint::m_tiePointId, ossim_hdf5::print(), ossimDpt::x, and ossimDpt::y.
protectedvirtual |
Residuals are in view space for this type.
Definition at line 240 of file AutoTiePoint.cpp.
References m_cmpViewPt, m_generator, ossim::TiePoint::m_imagePoints, m_refViewPt, m_residual, and ossimDpt::makeNan().
Referenced by addImageMatch(), and bumpActiveMatch().
Definition at line 109 of file AutoTiePoint.cpp.
References ossimGpt::azimuthTo(), ossimGpt::distanceTo(), m_cmpViewPt, m_generator, m_matchPoints, and m_refViewPt.
| void ATP::AutoTiePoint::setRefImagePt | ( | const ossimDpt & | imagePt | ) |
Definition at line 89 of file AutoTiePoint.cpp.
References m_generator, ossim::TiePoint::m_imagePoints, and m_refViewPt.
| void ATP::AutoTiePoint::setRefViewPt | ( | const ossimDpt & | viewPt | ) |
Definition at line 98 of file AutoTiePoint.cpp.
protected |
Definition at line 132 of file AutoTiePoint.h.
Referenced by addViewMatch(), getCmpViewPoint(), recomputeResidual(), and saveJSON().
protected |
Definition at line 129 of file AutoTiePoint.h.
Referenced by addViewMatch(), getRefGroundPoint(), recomputeResidual(), saveJSON(), setRefImagePt(), and setRefViewPt().
protected |
Definition at line 130 of file AutoTiePoint.h.
Referenced by addImageMatch(), addViewMatch(), AutoTiePoint(), bumpActiveMatch(), getConfidenceMeasure(), getNumMatches(), hasValidMatch(), matchPoints(), print(), saveJSON(), and ~AutoTiePoint().
protected |
Definition at line 131 of file AutoTiePoint.h.
Referenced by getRefGroundPoint(), getRefViewPoint(), recomputeResidual(), saveJSON(), setRefImagePt(), and setRefViewPt().
protected |
Definition at line 134 of file AutoTiePoint.h.
protected |
Definition at line 133 of file AutoTiePoint.h.
Referenced by addImageMatch(), getVectorResidual(), print(), and recomputeResidual().
