#include <ossimTangentialRadialLensDistortion.h>
| ossimTangentialRadialLensDistortion () | |
| ossimTangentialRadialLensDistortion (const ossimDpt &calibratedCenter, double k1=0.0, double k2=0.0, double k3=0.0, double p1=0.0, double p2=0.0) | |
| ossimTangentialRadialLensDistortion (const ossimDpt &calibratedCenter, std::vector< double > k, std::vector< double > p) | |
| virtual void | undistort (const ossimDpt &input, ossimDpt &output) const |
Public Member Functions inherited from ossimLensDistortion | |
| ossimLensDistortion (const ossimDpt &callibratedCenter=ossimDpt(0, 0)) | |
| void | setCenter (const ossimDpt ¢er) |
| const ossimDpt & | getCenter () const |
| virtual void | forward (const ossimDpt &input, ossimDpt &output) const |
| virtual void | inverse (const ossimDpt &input, ossimDpt &output) |
| virtual void | distort (const ossimDpt &input, ossimDpt &output) const |
Public Member Functions inherited from ossim2dTo2dTransform | |
| virtual void | forward (ossimDpt &modify_this) const |
| virtual void | inverse (const ossimDpt &input, ossimDpt &output) const |
| virtual void | inverse (ossimDpt &modify_this) const |
| virtual const ossim2dTo2dTransform & | operator= (const ossim2dTo2dTransform &rhs) |
| virtual ossimDpt | getOrigin () const |
| void | setConvergenceThreshold (const double &new_threshold) |
| void | setMaxIterations (int new_max_iters) |
| void | setDxDy (const ossimDpt &dxdy) |
| ossimObject () | |
Protected Attributes | |
| std::vector< ossim_float64 > | m_k |
| std::vector< ossim_float64 > | m_p |
Protected Attributes inherited from ossimLensDistortion | |
| ossimDpt | theCenter |
Protected Attributes inherited from ossim2dTo2dTransform | |
| double | theConvergenceThreshold |
| int | theMaxIterations |
| ossimDpt | theDxDy |
Protected Member Functions inherited from ossim2dTo2dTransform | |
| ossim2dTo2dTransform () | |
| virtual | ~ossim2dTo2dTransform () |
Definition at line 33 of file ossimTangentialRadialLensDistortion.h.
| ossimTangentialRadialLensDistortion::ossimTangentialRadialLensDistortion | ( | ) |
Definition at line 7 of file ossimTangentialRadialLensDistortion.cpp.
| ossimTangentialRadialLensDistortion::ossimTangentialRadialLensDistortion | ( | const ossimDpt & | calibratedCenter, |
| double | k1 = 0.0, |
| double | k2 = 0.0, |
| double | k3 = 0.0, |
| double | p1 = 0.0, |
| double | p2 = 0.0 |
Definition at line 15 of file ossimTangentialRadialLensDistortion.cpp.
| std::vector< double > | k, | ||
| std::vector< double > | p | ||
Definition at line 33 of file ossimTangentialRadialLensDistortion.cpp.
Reimplemented from ossimLensDistortion.
Definition at line 90 of file ossimTangentialRadialLensDistortion.cpp.
References ossimKeywordlist::find(), ossimLensDistortion::loadState(), m_k, m_p, and ossim::toSimpleVector().
inlinevirtual |
Generic print method.
Derived classes should re-implement as they see fit.
Reimplemented from ossim2dTo2dTransform.
Definition at line 46 of file ossimTangentialRadialLensDistortion.h.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 75 of file ossimTangentialRadialLensDistortion.cpp.
References ossimKeywordlist::add(), m_k, m_p, ossimLensDistortion::saveState(), and ossim::toSimpleStringList().
Referenced by ossimSpectraboticsRedEdgeModel::saveState().
Implements ossimLensDistortion.
Definition at line 42 of file ossimTangentialRadialLensDistortion.cpp.
References m_k, m_p, ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 60 of file ossimTangentialRadialLensDistortion.h.
Referenced by loadState(), ossimTangentialRadialLensDistortion(), saveState(), and undistort().
protected |
Definition at line 61 of file ossimTangentialRadialLensDistortion.h.
