#include <ossimShorelineTool.h>
Public Types | |
| enum | AlgorithmId { UNKNOWN, NDWI, AWEI, PAN_THRESHOLD } |
| enum | ThresholdMode { NONE =0, MEAN =1, SIGMA =2, VARIANCE =3, VALUE =4 } |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
| ossimShorelineTool () | |
| ~ossimShorelineTool () | |
| virtual void | setUsage (ossimArgumentParser &ap) |
| Initializes the aurgument parser with expected parameters and options. More... | |
| virtual bool | initialize (ossimArgumentParser &ap) |
| Initial method to be ran prior to execute. More... | |
| virtual void | initialize (const ossimKeywordlist &kwl) |
| This method is responsible for completely setting up the full processing chain according to the specifications given in the kwl passed in. More... | |
| virtual ossimRefPtr< ossimImageData > | getChip (const ossimIrect &img_rect) |
| The meat and potatos of this class. More... | |
| virtual bool | execute () |
| Performs the actual product write. More... | |
Public Member Functions inherited from ossimChipProcTool | |
| ossimChipProcTool () | |
| virtual | ~ossimChipProcTool () |
| virtual void | clear () |
| Disconnects and clears the dem and image layers. More... | |
| virtual void | abort () |
| virtual bool | isChipProcessor () const |
| Overrides base class implementation to indicate this class supports getChip() calls. More... | |
| virtual ossimListenerManager * | getManager () |
| virtual ossimRefPtr< ossimImageData > | getChip (const ossimGrect &gnd_rect) |
| ossimRefPtr< ossimImageData > | getChip (const ossimDrect &map_bounding_rect, const ossimDpt &gsd) |
| ossimRefPtr< ossimImageData > | getChip () |
| Get chip method that assumes pre-initialized state. More... | |
| const ossimFilename & | getProductFilename () const |
Public Member Functions inherited from ossimTool | |
| ossimTool () | |
| virtual | ~ossimTool () |
| virtual void | loadJSON (const Json::Value &json_request) |
| Reads processing params from JSON object provided. More... | |
| virtual void | saveJSON (Json::Value &json) const |
| Fetch product as JSON object when applicable Always returns true since using exception on error. More... | |
| virtual const std::string & | getResponse () const |
| Fetch product as string (typically JSON) when applicable, otherwise passes back empty string. More... | |
| virtual void | getKwlTemplate (ossimKeywordlist &kwl) |
| Assigns a template keywordlist to string for initializing derived classes. More... | |
| void | getAPI (std::string &out) const |
| Outputs a JSON representation of the Utility's API. More... | |
| std::string | getAPI () const |
| void | getBuildDate (std::string &s) const |
| Gets build date. More... | |
| void | getRevision (std::string &s) const |
| Gets revision. More... | |
| void | getVersion (std::string &s) const |
| Gets version. More... | |
| void | setOutputStream (std::ostream *os) |
| Redirects any console output to the supplied stream for logging or JNI application. More... | |
| bool | helpRequested () const |
| Returns true when the initialization detects a "--help" option, so caller can avoid subsequent execute() call. More... | |
| ossimObject () | |
Public Member Functions inherited from ossim::JsonInterface | |
| JsonInterface () | |
| virtual | ~JsonInterface () |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ossimListenerManager () | |
Static Public Attributes | |
| static const char * | DESCRIPTION |
| Used by ossimUtilityFactory. More... | |
| virtual void | initProcessingChain () |
| Derived classes initialize their custom chains here. More... | |
| void | initLandsat8 () |
| ossimShorelineTool (const ossimShorelineTool &obj) | |
| Hidden from use copy constructor. More... | |
| const ossimShorelineTool & | operator= (const ossimShorelineTool &rhs) |
| Hidden from use assignment operator. More... | |
| void | usage (ossimArgumentParser &ap) |
| Initializes arg parser and outputs usage. More... | |
| void | addArguments (ossimArgumentParser &ap) |
| void | doThreshold () |
| void | autoComputeThreshold () |
Protected Member Functions inherited from ossimChipProcTool | |
| void | processRemainingArgs (ossimArgumentParser &ap) |
| Intended to be called after derived class has picked off its own options from the parser, and arguments remain (such as input and output filenames). More... | |
| virtual void | finalizeChain () |
| Called after initProcessingChain() to append common items to the processing chain. More... | |
| virtual void | loadImageFiles () |
| Creates chains for image entries associated with specified keyword. More... | |
| virtual void | loadDemFiles () |
| Loads all DEM files specified in master KWL into the elev manager's database. More... | |
| ossimRefPtr< ossimSingleImageChain > | createInputChain (const ossimFilename &image_file, ossim_uint32 entry_index=0) |
| Creates the ossimSingleImageChain from image filename and populates the chain with resampler and product output projection on view-side of resampler's IVT. More... | |
| void | createOutputProjection () |
| Creates the output or view projection. More... | |
| ossimRefPtr< ossimMapProjection > | newIdentityProjection () |
| Sets the single image chain for identity operations view to a ossimImageViewAffineTransform. More... | |
| ossimRefPtr< ossimMapProjection > | newUtmProjection () |
| Convenience method to get a utm projection. More... | |
| virtual void | initializeProjectionGsd () |
| Initializes the projection gsd. More... | |
| virtual void | initializeAOI () |
| Initializes m_aoiViewRect with the output area of interest as specified in master KWL. More... | |
| bool | getProjectionOrigin (ossimGpt &gpt) |
| Reads the KWL for origin latitude and central meridian. More... | |
| ossimRefPtr< ossimImageFileWriter > | newWriter () |
| Creates a new writer. More... | |
| void | propagateGeometryToChains () |
| Loops through all chains and sets the output projection. More... | |
| ossimRefPtr< ossimImageSource > | combineLayers (std::vector< ossimRefPtr< ossimSingleImageChain > > &layers) const |
| When multiple input sources are present, this method instantiates a combiner and adds inputs. More... | |
| void | computeAdjustedViewFromGrect () |
| Initializes m_aoiViewRect given m_aoiGroundRect. More... | |
| void | setAoiToInputs () |
| Assigns the AOI to be the bounding rect of the union of all inputs. More... | |
| void | getBandList (ossim_uint32 image_idx, std::vector< ossim_uint32 > &bandList) const |
| Gets the band list if BANDS keyword is set. More... | |
| void | setReaderProps (ossimImageHandler *ih) const |
| Passes reader properties to single image handler if any. More... | |
| ossimChipProcTool (const ossimChipProcTool &obj) | |
| const ossimChipProcTool & | operator= (const ossimChipProcTool &) |
| ossimRefPtr< ossimGeoPolygon > | createClipPolygon () const |
| void | findCenterGpt (ossimGpt &gpt) |
| Tries to determine the AOI center point based on KWL entries, else returns NaNs in gpt. More... | |
| ossimRefPtr< ossimImageSource > | mosaicDemSources () |
| Some utilities need to work on DEMs as images. More... | |
Class for finding helicopter landing zones (HLZ) on a DEM given the final destination and max range from destination.
Definition at line 36 of file ossimShorelineTool.h.
| Enumerator | |
| UNKNOWN | |
| NDWI | |
| AWEI | |
| PAN_THRESHOLD | |
Definition at line 39 of file ossimShorelineTool.h.
| Enumerator | |
| NONE | |
| MEAN | |
| SIGMA | |
| VARIANCE | |
| VALUE | |
Definition at line 40 of file ossimShorelineTool.h.
| ossimShorelineTool::ossimShorelineTool | ( | ) |
Definition at line 49 of file ossimShorelineTool.cpp.
| ossimShorelineTool::~ossimShorelineTool | ( | ) |
Definition at line 63 of file ossimShorelineTool.cpp.
protected |
protected |
protected |
Definition at line 503 of file ossimShorelineTool.cpp.
References ossimKMeansClustering::computeKmeans(), ossimHistogram::GetCounts(), ossimImageChain::getFirstSource(), ossimMultiResLevelHistogram::getHistogram(), ossimImageHandler::getImageHistogram(), ossimKMeansClustering::getMean(), ossimHistogram::GetRes(), ossimKMeansClustering::getSigma(), ossimHistogram::GetVals(), ossimChipProcTool::m_procChain, m_threshold, m_thresholdMode, MEAN, ossimKMeansClustering::setNumClusters(), ossimKMeansClustering::setPopulations(), ossimKMeansClustering::setSamples(), SIGMA, ossimRefPtr< T >::valid(), and VARIANCE.
Referenced by doThreshold().
protected |
Definition at line 430 of file ossimShorelineTool.cpp.
References ossimKeywordlist::add(), ossimImageChain::add(), autoComputeThreshold(), ossimString::chars(), ossimChipProcTool::execute(), FLT_EPSILON, ossimRefPtr< T >::get(), ossimImageHandlerRegistry::instance(), ossimBandLutFilter::loadState(), m_algorithm, m_indexFilename, m_landValue, m_marginalValue, ossimChipProcTool::m_procChain, ossimChipProcTool::m_productFilename, m_threshFilename, m_threshold, m_thresholdMode, m_tolerance, m_waterValue, ossimImageHandlerRegistry::open(), PAN_THRESHOLD, ossimString::toString(), ossimRefPtr< T >::valid(), and VALUE.
Referenced by execute().
Reimplemented from ossimChipProcTool.
Definition at line 351 of file ossimShorelineTool.cpp.
References ossimKeywordlist::add(), ossimImageChain::add(), ossimString::chars(), ossimToolRegistry::createTool(), doThreshold(), ossimTool::execute(), ossimChipProcTool::execute(), ossimFilename::ext(), ossimRefPtr< T >::get(), ossimTool::initialize(), ossimImageChain::initialize(), ossimToolRegistry::instance(), m_algorithm, ossimTool::m_consoleStream, ossimTool::m_helpRequested, ossimChipProcTool::m_imgLayers, m_indexFilename, m_maskFilename, m_noVector, ossimChipProcTool::m_procChain, ossimChipProcTool::m_productFilename, m_smoothing, m_threshFilename, m_thresholdMode, m_vectorFilename, NONE, ossimNotify(), ossimNotifyLevel_INFO, ossimNotifyLevel_WARN, ossimKeywordNames::OUTPUT_FILE_KW, PAN_THRESHOLD, ossimFilename::setExtension(), ossimImageGaussianFilter::setGaussStd(), ossimTool::setOutputStream(), ossimErosionFilter::setWindowSize(), status, and ossimRefPtr< T >::valid().
Performs an execute on specified rect.
Definition at line 334 of file ossimShorelineTool.cpp.
References ossimImageChain::getTile(), ossimImageGeometry::localToWorld(), ossimChipProcTool::m_aoiGroundRect, ossimChipProcTool::m_aoiViewRect, ossimChipProcTool::m_geom, ossimChipProcTool::m_procChain, ossimImageGeometry::setImageSize(), ossimIrect::size(), and ossimRefPtr< T >::valid().
inlinevirtual |
Reimplemented from ossimTool.
Definition at line 51 of file ossimShorelineTool.h.
Intended for command-line app usage.
| ap | Arg parser to initialize from. |
Definition at line 113 of file ossimShorelineTool.cpp.
References ossimKeywordlist::addPair(), ossimChipProcTool::initialize(), ossimTool::m_helpRequested, ossimTool::m_kwl, and ossimArgumentParser::read().
If the utility is run from a command line, the initialize(ossimArgumentParser) will assign the member master KWL and pass it to this method. Web service calls will fill a KWL and pass it.
This base class implementation should be called by the derived class implementation (assuming the derived class needs to pull some parameters out of the KWL before the chains are set up.
This method will instantiate the output projection and define the output bounding rect and product size in pixels. The processing chain (stored in m_procChain) will be completely initialized and ready for calls to getTile(). Then either getChip() or execute() can be called depending on usage to fetch product.
Definition at line 170 of file ossimShorelineTool.cpp.
References ossimKeywordlist::addList(), ossimKeywordlist::clear(), ossimKeywordlist::findKey(), and ossimTool::m_kwl.
protected |
protectedvirtual |
Implements ossimChipProcTool.
Definition at line 268 of file ossimShorelineTool.cpp.
References ossimImageChain::add(), AWEI, ossimRefPtr< T >::get(), ossimGrect::hasNans(), ossimIrect::hasNans(), m_algorithm, ossimChipProcTool::m_aoiGroundRect, ossimChipProcTool::m_aoiViewRect, ossimChipProcTool::m_imgLayers, ossimChipProcTool::m_procChain, m_smoothing, NDWI, OSSIM_NORMALIZED_DOUBLE, PAN_THRESHOLD, ossimEquationCombiner::setEquation(), ossimImageGaussianFilter::setGaussStd(), and ossimEquationCombiner::setOutputScalarType().
protected |
It does not output anything. To see the usage, the caller will need to do something like:
ap.getApplicationUsage()->write(<ostream>);
This base class has some common arguments to add. The derived class should call this implementation in addition to setting its own arguments.
Definition at line 67 of file ossimShorelineTool.cpp.
References ossimApplicationUsage::addCommandLineOption(), ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimApplicationUsage::setCommandLineUsage(), ossimApplicationUsage::setDescription(), and ossimChipProcTool::setUsage().
protected |
static |
Definition at line 54 of file ossimShorelineTool.h.
Referenced by ossimToolFactory::getCapabilities().
protected |
Definition at line 83 of file ossimShorelineTool.h.
Referenced by doThreshold(), execute(), and initProcessingChain().
protected |
Definition at line 90 of file ossimShorelineTool.h.
protected |
Definition at line 87 of file ossimShorelineTool.h.
Referenced by doThreshold(), and execute().
protected |
Definition at line 79 of file ossimShorelineTool.h.
protected |
Definition at line 78 of file ossimShorelineTool.h.
protected |
Definition at line 89 of file ossimShorelineTool.h.
protected |
Definition at line 91 of file ossimShorelineTool.h.
protected |
Definition at line 80 of file ossimShorelineTool.h.
protected |
Definition at line 85 of file ossimShorelineTool.h.
Referenced by execute(), and initProcessingChain().
protected |
Definition at line 88 of file ossimShorelineTool.h.
protected |
Definition at line 81 of file ossimShorelineTool.h.
Referenced by autoComputeThreshold(), and doThreshold().
protected |
Definition at line 84 of file ossimShorelineTool.h.
Referenced by autoComputeThreshold(), doThreshold(), and execute().
protected |
Definition at line 82 of file ossimShorelineTool.h.
protected |
Definition at line 86 of file ossimShorelineTool.h.
protected |
Definition at line 77 of file ossimShorelineTool.h.
