Registry of all utility factories. More...
#include <ossimToolRegistry.h>
| ossimToolRegistry () | |
| ~ossimToolRegistry () | |
| virtual bool | initialize () |
| Initializes the utility factory. More... | |
| virtual void | getCapabilities (std::map< std::string, std::string > &capabilities) const |
| Appends map with available utilities along with descriptions as <name, decription> pairs. More... | |
| virtual std::map< std::string, std::string > | getCapabilities () const |
| virtual ossimTool * | createTool (const std::string &typeName) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimToolFactoryBase | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimTool * | createTool (const ossimKeywordlist &kwl, const char *prefix=0) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
Public Member Functions inherited from ossimFactoryListInterface< ossimToolFactoryBase, ossimTool > | |
| ossimFactoryListInterface () | |
| void | addFactory (ossimToolFactoryBase *factory) |
| This is for backward compatability and calls registerFactory for simple adds. More... | |
| bool | isFactoryRegistered (ossimToolFactoryBase *factory) const |
| Public access method to determine if a factory is already registered to this list. More... | |
| void | registerFactory (ossimToolFactoryBase *factory, bool pushToFrontFlag=false) |
| Will register a factory to the factory list. More... | |
| void | unregisterFactory (ossimToolFactoryBase *factory) |
| Will remove the factory from the registry. More... | |
| void | unregisterFactory (const ossimString &factoryTypeName) |
| Will remove the factory from the registry by name. More... | |
| void | unregisterAllFactories () |
| Will remove all factories from the registry. More... | |
| void | registerFactoryToFront (ossimToolFactoryBase *factory) |
| Inserts the factory to the front of the list. More... | |
| void | registerFactoryBefore (ossimToolFactoryBase *factory, ossimToolFactoryBase *beforeThisFactory) |
| Will insert the factory before the beforeThisFactory. More... | |
| void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
| Will add all object types the factories can allocate. More... | |
| ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
| This is the base object return for all objects in the system. More... | |
| ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimTool * | createNativeObjectFromRegistry (const ossimString &typeName) const |
| This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More... | |
| ossimTool * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| static ossimToolRegistry * | instance () |
Static Private Attributes | |
| static ossimToolRegistry * | s_instance = 0 |
Public Types inherited from ossimFactoryListInterface< ossimToolFactoryBase, ossimTool > | |
| typedef std::vector< ossimToolFactoryBase *> | FactoryListType |
| typedef ossimToolFactoryBase | FactoryType |
| typedef ossimTool | NativeReturnType |
Protected Member Functions inherited from ossimFactoryListInterface< ossimToolFactoryBase, ossimTool > | |
| bool | findFactory (ossimToolFactoryBase *factory) const |
| Utility to find a factory in the list. More... | |
Protected Attributes inherited from ossimFactoryListInterface< ossimToolFactoryBase, ossimTool > | |
| std::mutex | m_factoryListMutex |
| FactoryListType | m_factoryList |
Presently only one factory exists, ossimUtilityFactory, but eventually plugins can provide their own utilities and corresponding factories.
Definition at line 22 of file ossimToolRegistry.h.
| ossimToolRegistry::ossimToolRegistry | ( | ) |
Definition at line 22 of file ossimToolRegistry.cpp.
References ossimToolFactory::instance().
| ossimToolRegistry::~ossimToolRegistry | ( | ) |
Definition at line 27 of file ossimToolRegistry.cpp.
Implements ossimToolFactoryBase.
Definition at line 59 of file ossimToolRegistry.cpp.
Referenced by ossimDemTool::doOMG(), and ossimShorelineTool::execute().
The names are the human-readable name of the utility/service, typically the utility's class name without the "ossim" prefix nor "Util" suffix, all lowercase.
Definition at line 52 of file ossimToolRegistry.cpp.
inlinevirtual |
Definition at line 47 of file ossimToolRegistry.h.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 71 of file ossimToolRegistry.cpp.
Returns TRUE if successful.
Definition at line 32 of file ossimToolRegistry.cpp.
static |
Definition at line 15 of file ossimToolRegistry.cpp.
Referenced by ossimDemTool::doOMG(), ossimShorelineTool::execute(), ossimSharedLibraryFinalize(), ossimSharedLibraryInitialize(), ossimToolServer::runCommand(), ATP::ossimAtpToolFactory::~ossimAtpToolFactory(), ossimDemToolFactory::~ossimDemToolFactory(), ossimPotraceToolFactory::~ossimPotraceToolFactory(), ossimRegToolFactory::~ossimRegToolFactory(), and ossimToolFactory::~ossimToolFactory().
staticprivate |
Definition at line 52 of file ossimToolRegistry.h.
