Go to the source code of this file.
| set_type | read_selected_features (view_type *view, int themenum) |
| void | save_selected_features (view_type *view, int themenum, set_type selset) |
| set_type | get_selected_features (view_type *view, int themenum, library_type library) |
| set_type | bounding_select (char *path, extent_type mapextent, int dec_degrees) |
| int | completely_within (extent_type extent1, extent_type extent2) |
| set_type * | get_selected_primitives (view_type *view, int themenum, library_type *library, map_environment_type *mapenv, int *status) |
| int | draw_selected_features (view_type *view, int themenum, library_type *library, map_environment_type *mapenv) |
◆ bounding_select()
◆ completely_within()
◆ draw_selected_features()
◆ get_selected_features()
◆ get_selected_primitives()
◆ read_selected_features()
◆ save_selected_features()
