#include <ossimImageMetaDataWriterFactory.h>
| ~ossimImageMetaDataWriterFactory () | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimRefPtr< ossimMetadataFileWriter > | createWriter (const ossimString &type) const |
| Creates a writer from either a class name or a string representing the meta data type like "tiff_world_file". More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| This should return the type name of all objects in all factories. More... | |
| virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const |
| Satisfies pure virtual from ossimImageMetaDataWriterFactoryBase. More... | |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimImageMetaDataWriterFactory * | instance () |
| ossimImageMetaDataWriterFactory (const ossimImageMetaDataWriterFactory &rhs) | |
| const ossimImageMetaDataWriterFactory & | operator= (const ossimImageMetaDataWriterFactory &rhs) |
Protected Member Functions inherited from ossimImageMetaDataWriterFactoryBase | |
| ossimImageMetaDataWriterFactoryBase () | |
| ossimImageMetaDataWriterFactoryBase (const ossimImageMetaDataWriterFactoryBase &) | |
| const ossimImageMetaDataWriterFactoryBase & | operator= (const ossimImageMetaDataWriterFactoryBase &) |
Static Protected Attributes | |
| static ossimImageMetaDataWriterFactory * | theInstance = NULL |
Definition at line 21 of file ossimImageMetaDataWriterFactory.h.
| ossimImageMetaDataWriterFactory::~ossimImageMetaDataWriterFactory | ( | ) |
Definition at line 33 of file ossimImageMetaDataWriterFactory.cpp.
References theInstance.
protected |
Definition at line 28 of file ossimImageMetaDataWriterFactory.cpp.
Referenced by instance().
protected |
Definition at line 205 of file ossimImageMetaDataWriterFactory.cpp.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 48 of file ossimImageMetaDataWriterFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createObject().
Creates and object given a keyword list.
Definition at line 88 of file ossimImageMetaDataWriterFactory.cpp.
References createObject(), ossimKeywordlist::find(), ossimObject::loadState(), and ossimKeywordNames::TYPE_KW.
Implements ossimImageMetaDataWriterFactoryBase.
Definition at line 112 of file ossimImageMetaDataWriterFactory.cpp.
References ossimObject::getClassName(), and ossimMetadataFileWriter::hasMetadataType().
Appends the meta data writers types from each of the supported meta data writers in this factor to the "metadatatypeList".
This is the actual metadata type name like: ossim_geometry envi_header tiff_world_file jpeg_world_file
| metadatatypeList | stl::vector<ossimString> List to append to. |
Definition at line 181 of file ossimImageMetaDataWriterFactory.cpp.
References ossimMetadataFileWriter::getMetadatatypeList().
This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 169 of file ossimImageMetaDataWriterFactory.cpp.
static |
Definition at line 38 of file ossimImageMetaDataWriterFactory.cpp.
References ossimImageMetaDataWriterFactory(), and theInstance.
Referenced by ossimImageMetaDataWriterRegistry::ossimImageMetaDataWriterRegistry().
protected |
Definition at line 211 of file ossimImageMetaDataWriterFactory.cpp.
staticprotected |
Definition at line 75 of file ossimImageMetaDataWriterFactory.h.
Referenced by instance(), ossimImageMetaDataWriterFactory(), and ~ossimImageMetaDataWriterFactory().
