Go to the source code of this file.
| #define OSSIM_EQU_TOKEN_ABS 18 |
Definition at line 21 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseStdFuncs().
| #define OSSIM_EQU_TOKEN_ACOS 31 |
Definition at line 34 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_ACOSD 32 |
Definition at line 35 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_AMPERSAND 39 |
Definition at line 42 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseRestOfTerm().
| #define OSSIM_EQU_TOKEN_ASIN 29 |
Definition at line 32 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_ASIND 30 |
Definition at line 33 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_ASSIGN_BAND 27 |
Definition at line 30 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_ATAN 35 |
Definition at line 38 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_ATAND 36 |
Definition at line 39 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BAND 26 |
Definition at line 29 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BDIFFERENT 50 |
Definition at line 53 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BEQUAL 45 |
Definition at line 48 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BGREATER 46 |
Definition at line 49 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BGREATEROREQUAL 47 |
Definition at line 50 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BLESS 48 |
Definition at line 51 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BLESSOREQUAL 49 |
Definition at line 52 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_BLURR 23 |
Definition at line 26 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_CLAMP 43 |
Definition at line 46 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_CLIP 44 |
Definition at line 47 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_COMMA 22 |
Definition at line 25 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseArgList(), and ossimEquationCombiner::parseStdFuncs().
| #define OSSIM_EQU_TOKEN_CONSTANT 9 |
Definition at line 12 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseFactor().
| #define OSSIM_EQU_TOKEN_CONV 25 |
Definition at line 28 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_COS 16 |
Definition at line 19 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_COSD 17 |
Definition at line 20 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_DIV 5 |
Definition at line 8 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_EXP 10 |
Definition at line 13 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_IMAGE_VARIABLE 8 |
Definition at line 11 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_LEFT_ARRAY_BRACKET 37 |
Definition at line 40 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_LEFT_PAREN 1 |
Definition at line 4 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseArgList(), ossimEquationCombiner::parseFactor(), and ossimEquationCombiner::parseStdFuncs().
| #define OSSIM_EQU_TOKEN_LOG 3 |
Definition at line 6 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_LOG10 11 |
Definition at line 14 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_MAX 20 |
Definition at line 23 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_MIN 19 |
Definition at line 22 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_MINUS 6 |
Definition at line 9 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseRestOfExp(), and ossimEquationCombiner::parseUnaryFactor().
| #define OSSIM_EQU_TOKEN_MOD 28 |
Definition at line 31 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_MULT 4 |
Definition at line 7 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_OR_BAR 40 |
Definition at line 43 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_PI 12 |
Definition at line 15 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_PLUS 7 |
Definition at line 10 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseRestOfExp().
| #define OSSIM_EQU_TOKEN_POWER 13 |
Definition at line 16 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_RIGHT_ARRAY_BRACKET 38 |
Definition at line 41 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_RIGHT_PAREN 2 |
Definition at line 5 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_SHIFT 24 |
Definition at line 27 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_SIN 14 |
Definition at line 17 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_SIND 15 |
Definition at line 18 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_SQRT 21 |
Definition at line 24 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_TAN 33 |
Definition at line 36 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_TAND 34 |
Definition at line 37 of file ossimEquTokenDefines.h.
| #define OSSIM_EQU_TOKEN_TILDE 41 |
Definition at line 44 of file ossimEquTokenDefines.h.
Referenced by ossimEquationCombiner::parseUnaryFactor().
| #define OSSIM_EQU_TOKEN_XOR 42 |
Definition at line 45 of file ossimEquTokenDefines.h.
