ossimDemGrid.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Ken Melero ([email protected])
6 // Orginally written by Jamie Moyers ([email protected])
7 // Adapted from the package KDEM.
8 // Description: This class defines a DEM grid.
9 //
10 //********************************************************************
11 // $Id$
12
14 #include <ossim/base/ossimNotify.h>
18
19
21  : _missDataVal(missingDataValue),
22  _width(0),
23  _height(0),
24  _grid(0),
25  _firstTime(true),
26  _curProfile(0)
27 {
28 }
29
31 {
32  if(_grid)
33  {
34  delete [] _grid;
35  _grid =0;
36  }
37 }
38
39 long
40 ossimDemGrid::read(ossim::istream& dem, bool incrementalRead)
41 {
42  if (_firstTime)
43  {
44  dem >> _header;
45  }
46
47  long retval;
48  if (_header.getGroundRefSysCode() == 0) // Geographic
49  retval = fillGeographic(dem,incrementalRead);
50  else
51  retval = fillUTM(dem,incrementalRead); // This may not work if it's
52  // really in State Plane.
53
54  if (_firstTime)
55  _firstTime = false;
56
57  return retval;
58 }
59
60 ossimDemHeader const&
62 {
63  return _header;
64 }
65
66 long
68 {
69  return _width;
70 }
71
72 long
74 {
75  return _height;
76 }
77
79 {
80  if (_grid == 0)
81  return _missDataVal;
82
83  if ((x < 0) || (y < 0) || (x >= _width) || (y >= _height))
84  return _missDataVal;
85
86  return _grid[(y * _width) + x];
87 }
88
90 {
91  return _missDataVal;
92 }
93
94 long ossimDemGrid::fillGeographic(ossim::istream& dem,bool incrementalRead)
95 {
96  if (_firstTime) {
97  _curProfile = 0;
99  }
100
101  while (_curProfile < _width)
102  {
103  _profiles.push_back(ossimDemProfile());
104  dem >> _profiles.back();
105  _curProfile++;
106  if (incrementalRead)
107  return _width - _curProfile + 1;
108  }
109
110  // Assume all profiles have as many elevations as the first.
111  _height = _profiles[0].getNumberOfElevations();
112  if(_grid)
113  {
114  delete [] _grid;
115  _grid =0;
116  }
118
119  ossimDemPoint sw_corner = _profiles[0].getProfileLocation();
120  _northwest_x = sw_corner.getX();
121  _northwest_y = sw_corner.getY()
122  + ((_profiles[0].getNumberOfElevations() - 1) * _header.getSpatialResY());
123
124
125  unsigned int i,j;
126  for (i = 0; (int)i < _width; i++)
127  {
128  ossimDemElevationVector const& elev = _profiles[i].getElevations();
129  for (j = 0; j < elev.size(); j++)
130  {
131  setElevation(i, _height - j - 1, elev[j]);
132  }
133  }
134
135  _profiles.erase(_profiles.begin(), _profiles.end());
136
137  return 0;
138 }
139
140 long
141 ossimDemGrid::fillUTM(ossim::istream& dem, bool incrementalRead)
142 {
143  // 7.5 UTM DEMs are small enough we can get away with doing this stupid...
144
145  unsigned int i;
146  unsigned int x,y;
147
148  if (_firstTime)
149  {
150  _curProfile = 0;
152  }
153
154
155  while (_curProfile < _width)
156  {
157  _profiles.push_back(ossimDemProfile());
158  dem >> _profiles.back();
159  _curProfile++;
160  if (incrementalRead)
161  return _width - _curProfile + 1;
162  }
163
164  double dy = _header.getSpatialResY();
165
166  // Determine min and max Y values.
167  // Some DEMs can have profiles which do not have any
168  // elevations, and erroneous (x,y) values. I suspect
169  // these are probably illegal DEMs, but we'll try to
170  // do the right thing anyway.
171  ossimDemPoint curpoint;
172  i = 0;
173  while ((_profiles[i].getNumberOfElevations() == 0) &&
174  (i < _profiles.size()))
175  i++;
176  if (i < _profiles.size())
177  curpoint = _profiles[i].getProfileLocation();
178  else
179  {
180  // XXX This isn't the best way to handle this...
181  ossimNotify(ossimNotifyLevel_FATAL) << "FATAL ossimDemGrid::fillUTM: Yikes! All profiles have zero elevations!\n";
182  return(1);
183  }
184
185  double miny, maxy;
186  miny = curpoint.getY();
187  maxy = miny;
188  double profymin, profymax; // Min and max y values for current profile.
189  for (i = 0; i < _profiles.size(); i++)
190  {
191  if (_profiles[i].getNumberOfElevations() > 0)
192  {
193  curpoint = _profiles[i].getProfileLocation();
194  profymin = curpoint.getY();
195  profymax = profymin + ((_profiles[i].getNumberOfElevations() - 1) * dy);
196
197  if (profymin < miny)
198  miny = profymin;
199  if (profymax > maxy)
200  maxy = profymax;
201  }
202  }
203
204  // We now have minimum and maximum y values over all profiles in the DEM.
205  // Allocate a rectangular array large enough to hold them.
206
207  _height = static_cast<long>(((maxy - miny) / dy) + 1);
208  if(_grid)
209  {
210  delete [] _grid;
211  _grid =0;
212  }
214
215  // Fill grid with the "missing data" value.
216  for (i = 0; (int)i < _width * _height; i++)
217  _grid[i] = _missDataVal;
218
219  ossimDemPoint sw_corner = _profiles[0].getProfileLocation();
220  _northwest_x = sw_corner.getX();
221  _northwest_y = maxy;
222
223
224  // Now, insert the elevations in the profiles in the appropriate place in the grid.
225
226  long startpos;
227  for (x = 0; (int)x < _width; x++)
228  {
229  ossimDemElevationVector const& elev = _profiles[x].getElevations();
230  curpoint = _profiles[x].getProfileLocation();
231  startpos = static_cast<long>((curpoint.getY() - miny) / dy);
232  for (y = 0; y < elev.size(); y++)
233  {
234  setElevation(x, _height - startpos - y - 1, elev[y]);
235  }
236  }
237
238  _profiles.erase(_profiles.begin(), _profiles.end());
239
240  return 0;
241 }
242
243 void
244 ossimDemGrid::getGroundCoords(long x, long y, double& ground_x,
245  double& ground_y)
246 {
247  ground_x = _northwest_x + (x * _header.getSpatialResX());
248  ground_y = _northwest_y - (y * _header.getSpatialResY());
249 }
double getSpatialResY() const
ossim_uint32 x
ossimDemHeader _header
Definition: ossimDemGrid.h:87
double _northwest_y
Definition: ossimDemGrid.h:94
void getGroundCoords(long x, long y, double &ground_x, double &ground_y)
long getWidth() const
ossim_uint32 y
float ossim_float32
long fillUTM(ossim::istream &dem, bool incrementalRead)
ossim_float32 * _grid
Definition: ossimDemGrid.h:90
long _curProfile
Definition: ossimDemGrid.h:92
long fillGeographic(ossim::istream &dem, bool incrementalRead)
ossim_int32 getGroundRefSysCode() const
std::vector< ossim_int32 > ossimDemElevationVector
ossim_float32 getMissingDataValue() const
void setElevation(long x, long y, ossim_float32 val)
Definition: ossimDemGrid.h:101
double getY() const
Definition: ossimDemPoint.h:60
long getHeight() const
std::vector< ossimDemProfile > _profiles
Definition: ossimDemGrid.h:93
ossim_int32 getProfileColumns() const
long read(ossim::istream &dem, bool incrementalRead=false)
double _northwest_x
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
double getSpatialResX() const
ossimDemGrid(ossim_float32 missingDataValue=-32768.0)
ossimDemHeader const & getHeader() const
ossim_float32 _missDataVal
Definition: ossimDemGrid.h:86
double getX() const
Definition: ossimDemPoint.h:53
ossim_float32 getElevation(long x, long y) const
