#include <ossimPointCloudSource.h>
| ossimPointCloudSource (ossimObject *owner=0) | |
| virtual | ~ossimPointCloudSource () |
| virtual void | getBlock (const ossimGrect &bounds, ossimPointBlock &block) const =0 |
| Fetches the block of points inside the block bounds. More... | |
| virtual ossim_uint32 | getNumPoints () const =0 |
| Returns the total number of points in the dataset (not just the block returned in getPoints) More... | |
| virtual const ossimPointRecord * | getMinPoint () const |
| Assigns the two points with fields representing the extremes of the dataset. More... | |
| virtual const ossimPointRecord * | getMaxPoint () const |
| virtual ossim_uint32 | getFieldCode () const |
| Fetches the data fields ids available from this source, OR'd together for testing against specific field (. More... | |
| virtual void | setFieldCode (ossim_uint32 fieldCode) |
| Sets the data fields ID of interest for this source, and all input sources connected to this. More... | |
| virtual bool | hasFields (ossim_uint32 id) const |
| Returns true if the data field is available from this source. More... | |
| bool | hasRGB () const |
| Special for convenience. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimPointCloudSource (const ossimPointCloudSource &rhs) | |
Protected Attributes | |
| ossimPointRecord | m_nullPCR |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 23 of file ossimPointCloudSource.h.
| ossimPointCloudSource::ossimPointCloudSource | ( | ossimObject * | owner = 0 | ) |
Definition at line 16 of file ossimPointCloudSource.cpp.
Definition at line 26 of file ossimPointCloudSource.cpp.
protected |
Definition at line 21 of file ossimPointCloudSource.cpp.
required to be overriden by derived classes
Implements ossimConnectableObject.
Reimplemented in ossimPointCloudHandler.
Definition at line 60 of file ossimPointCloudSource.cpp.
References ossimObject::canCastTo().
pure virtual |
If the height components of the bounds are NaN, then only the horizontal bounds are considered. Thread-safe version accepts data block object from caller.
Implemented in ossimPointCloudHandler, and ossimRialtoReader.
bool hasIntensity = getFields() & ossimPointRecord::Intensity;
Reimplemented in ossimPdalReader, and ossimGenericPointCloudHandler.
Definition at line 46 of file ossimPointCloudSource.cpp.
References ossimConnectableObject::getInput().
Definition at line 38 of file ossimPointCloudSource.cpp.
References ossimConnectableObject::getInput(), and m_nullPCR.
Useful for normalizing and establishing bounds.
Definition at line 30 of file ossimPointCloudSource.cpp.
pure virtual |
Implemented in ossimPdalFileReader, ossimPdalReader, and ossimGenericPointCloudHandler.
Referenced by ossimPointCloudImageHandler::getImageGeometry(), and ossimPointCloudImageHandler::getTile().
inlinevirtual |
The argument can be OR'd together for testing multiple fileds simultaneously. Example:
bool hasRGB = hasField(ossimPointRecord::Red|ossimPointRecord::Green|ossimPointRecord::Blue);
Definition at line 68 of file ossimPointCloudSource.h.
inline |
Definition at line 71 of file ossimPointCloudSource.h.
References ossimPointRecord::Blue, ossimPointRecord::Green, and ossimPointRecord::Red.
Referenced by ossimPdalReader::parsePointView().
This is an OR'd mash-up of
Reimplemented in ossimPdalReader.
Definition at line 54 of file ossimPointCloudSource.cpp.
protected |
Definition at line 78 of file ossimPointCloudSource.h.
Referenced by getMaxPoint(), and getMinPoint().
