#include <ossimRialtoReader.h>
| ossimRialtoReader () | |
| virtual | ~ossimRialtoReader () |
| virtual bool | open (const ossimFilename &fname) |
| Accepts filename of Rialto database file. More... | |
| virtual void | getFileBlock (ossim_uint32 offset, ossimPointBlock &block, ossim_uint32 np=0) const |
| Riaalto implementation does not support direct file reads, so this method is stubbed out with a warining message. More... | |
| virtual void | getBlock (const ossimGrect &bounds, ossimPointBlock &block) const |
| Fetches the block of points inside the block bounds. More... | |
Public Member Functions inherited from ossimPdalReader | |
| ossimPdalReader () | |
| virtual | ~ossimPdalReader () |
| virtual void | rewind () const |
| virtual ossim_uint32 | getNumPoints () const |
| Returns number of points in the data file. More... | |
| virtual void | close () |
| Closes the point cloud file(s). More... | |
| virtual ossim_uint32 | getFieldCode () const |
| Fetches the data fields ids available from this source, OR'd together for testing against specific field (. More... | |
| virtual void | setFieldCode (ossim_uint32 fieldCode) |
| Sets the data fields ID of interest for this source, and all input sources connected to this. More... | |
Public Member Functions inherited from ossimPointCloudHandler | |
| ossimPointCloudHandler () | |
| ossimPointCloudHandler (ossimObject *owner) | |
| virtual | ~ossimPointCloudHandler () |
| virtual void | getNextFileBlock (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const |
| virtual const ossimPointRecord * | getMinPoint () const |
| Assigns the two points with fields representing the extremes of the dataset. More... | |
| virtual const ossimPointRecord * | getMaxPoint () const |
| virtual void | getBounds (ossimGrect &bounds) const |
| virtual bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
| Handler is always on the start of the pipeline. More... | |
| void | normalizeBlock (ossimPointBlock &block) |
Public Member Functions inherited from ossimPointCloudSource | |
| ossimPointCloudSource (ossimObject *owner=0) | |
| virtual | ~ossimPointCloudSource () |
| virtual bool | hasFields (ossim_uint32 id) const |
| Returns true if the data field is available from this source. More... | |
| bool | hasRGB () const |
| Special for convenience. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Member Functions | |
| virtual void | establishMinMax () |
| Computes min and max records using points in the current PointViewSet. More... | |
| virtual void | establishAvailableFields () |
Definition at line 21 of file ossimRialtoReader.h.
| ossimRialtoReader::ossimRialtoReader | ( | ) |
virtual destructor
Definition at line 18 of file ossimRialtoReader.cpp.
inlineprivatevirtual |
Reimplemented from ossimPdalReader.
Definition at line 52 of file ossimRialtoReader.h.
References ossimPdalReader::establishMinMax().
privatevirtual |
Definition at line 100 of file ossimRialtoReader.cpp.
References ossimPointRecord::Blue, ossimString::contains(), ossimPointRecord::GpsTime, ossimPointRecord::Green, ossimGpt::hgt, ossimPointRecord::Infrared, ossimPointRecord::Intensity, ossimGpt::lat, ossimGpt::lon, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, and ossimPointRecord::ReturnNumber.
If the height components of the bounds are NaN, then only the horizontal bounds are considered. Thread-safe version accepts data block object from caller. The block object is cleared before points are pushed on the vector. The block size will be non-zero if points were found.
Reimplemented from ossimPointCloudHandler.
Definition at line 63 of file ossimRialtoReader.cpp.
References ossimPointBlock::clear(), ossimGpt::lat, ossimGpt::lon, ossimGrect::lr(), and ossimGrect::ul().
Referenced by test_rialto().
Implements ossimPointCloudHandler.
Definition at line 53 of file ossimRialtoReader.cpp.
References ossimPointBlock::clear(), ossimNotify(), and ossimNotifyLevel_WARN.
Returns TRUE if successful.
Definition at line 23 of file ossimRialtoReader.cpp.
References ossimNotify().
