#include <ossimPdalReader.h>
| ossimPdalReader () | |
| virtual | ~ossimPdalReader () |
| virtual void | rewind () const |
| virtual ossim_uint32 | getNumPoints () const |
| Returns number of points in the data file. More... | |
| virtual void | close () |
| Closes the point cloud file(s). More... | |
| virtual ossim_uint32 | getFieldCode () const |
| Fetches the data fields ids available from this source, OR'd together for testing against specific field (. More... | |
| virtual void | setFieldCode (ossim_uint32 fieldCode) |
| Sets the data fields ID of interest for this source, and all input sources connected to this. More... | |
Public Member Functions inherited from ossimPointCloudHandler | |
| ossimPointCloudHandler () | |
| ossimPointCloudHandler (ossimObject *owner) | |
| virtual | ~ossimPointCloudHandler () |
| virtual bool | open (const ossimFilename &imageFile)=0 |
| Method to open input point cloud dataset. More... | |
| virtual void | getFileBlock (ossim_uint32 offset, ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const =0 |
| Fetches up to maxNumPoints points starting at the dataset's <offset> in the order they appear in the data file. More... | |
| virtual void | getNextFileBlock (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const |
| virtual void | getBlock (const ossimGrect &bounds, ossimPointBlock &block) const |
| Fetches the block of points inside the block bounds. More... | |
| virtual const ossimPointRecord * | getMinPoint () const |
| Assigns the two points with fields representing the extremes of the dataset. More... | |
| virtual const ossimPointRecord * | getMaxPoint () const |
| virtual void | getBounds (ossimGrect &bounds) const |
| virtual bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
| Handler is always on the start of the pipeline. More... | |
| void | normalizeBlock (ossimPointBlock &block) |
Public Member Functions inherited from ossimPointCloudSource | |
| ossimPointCloudSource (ossimObject *owner=0) | |
| virtual | ~ossimPointCloudSource () |
| virtual bool | hasFields (ossim_uint32 id) const |
| Returns true if the data field is available from this source. More... | |
| bool | hasRGB () const |
| Special for convenience. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| void | parsePointView (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const |
| The current point ID (pid) gets updated. More... | |
| void | parsePoint (ossimPointRecord *precord) const |
| Need to pass allocated ossimPointRecord with field code set to desired fields. More... | |
| virtual void | establishMinMax () |
| Computes min and max records using points in the current PointViewSet. More... | |
| virtual void | establishAvailableFields () |
Protected Member Functions inherited from ossimPointCloudSource | |
| ossimPointCloudSource (const ossimPointCloudSource &rhs) | |
Static Public Attributes inherited from ossimPointCloudHandler | |
| static ossim_uint32 | DEFAULT_BLOCK_SIZE = 0x400000 |
Definition at line 22 of file ossimPdalReader.h.
| ossimPdalReader::ossimPdalReader | ( | ) |
default constructor
Definition at line 23 of file ossimPdalReader.cpp.
References ossimPointCloudHandler::m_geometry.
inlinevirtual |
Implements ossimPointCloudHandler.
Definition at line 38 of file ossimPdalReader.h.
protectedvirtual |
Reimplemented in ossimRialtoReader.
Definition at line 311 of file ossimPdalReader.cpp.
References ossimPointRecord::Blue, ossimPointRecord::GpsTime, ossimPointRecord::Green, ossimPointRecord::Infrared, ossimPointRecord::Intensity, m_availableFields, m_currentPV, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, and ossimPointRecord::ReturnNumber.
protectedvirtual |
Reimplemented in ossimRialtoReader, and ossimPdalFileReader.
Definition at line 203 of file ossimPdalReader.cpp.
References ossimRefPtr< T >::get(), ossimPointRecord::getField(), getFieldCode(), ossimPointRecord::getFieldCode(), ossimPointRecord::getFieldMap(), ossimPointRecord::getPosition(), ossimPointRecord::Green, ossimGpt::hgt, ossimGpt::lat, ossimGpt::lon, m_currentPV, m_currentPvOffset, ossimPointCloudHandler::m_maxRecord, ossimPointCloudHandler::m_minRecord, m_pvs, parsePoint(), ossimPointRecord::Red, rewind(), ossimPointRecord::setField(), ossimPointRecord::setPosition(), and ossimRefPtr< T >::valid().
Referenced by ossimRialtoReader::establishAvailableFields(), and ossimPdalFileReader::establishMinMax().
inlinevirtual |
bool hasIntensity = getFields() & ossimPointRecord::Intensity;
Reimplemented from ossimPointCloudSource.
Definition at line 46 of file ossimPdalReader.h.
Referenced by establishMinMax().
Implements ossimPointCloudSource.
Reimplemented in ossimPdalFileReader.
Definition at line 297 of file ossimPdalReader.cpp.
References m_pvs.
protected |
The pointNum is the point index into the point view
Definition at line 108 of file ossimPdalReader.cpp.
References ossimPointRecord::Blue, ossimPointCloudGeometry::convertPos(), ossimPointRecord::GpsTime, ossimPointRecord::Green, ossimPointRecord::hasFields(), ossimPointRecord::Infrared, ossimPointRecord::Intensity, m_currentPV, m_currentPvOffset, ossimPointCloudHandler::m_geometry, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, ossimPointRecord::ReturnNumber, ossimPointRecord::setField(), ossimPointRecord::setPosition(), ossimDpt3d::x, ossimDpt3d::y, and ossimDpt3d::z.
Referenced by establishMinMax(), and parsePointView().
protected |
The block is added to – pre-existing points remain or get overwritten if pid matches existing.
Definition at line 49 of file ossimPdalReader.cpp.
References ossimPointBlock::addPoint(), ossimPointRecord::Blue, ossimRefPtr< T >::get(), ossimPointRecord::getField(), ossimPointBlock::getFieldCode(), ossimPointRecord::Green, ossimPointCloudSource::hasRGB(), ossimPointRecord::Intensity, ossimPointCloudHandler::m_currentPID, m_currentPvOffset, ossimPointCloudHandler::m_maxRecord, ossimPointCloudHandler::m_minRecord, parsePoint(), ossimPointRecord::Red, ossimPointRecord::setField(), ossimPointRecord::setPointId(), ossimPointBlock::size(), and size.
Reimplemented from ossimPointCloudHandler.
Definition at line 39 of file ossimPdalReader.cpp.
References ossimPointCloudHandler::m_currentPID, m_currentPV, m_currentPvOffset, and m_pvs.
inlinevirtual |
This is an OR'd mash-up of
Definition at line 52 of file ossimPdalReader.h.
protected |
Definition at line 74 of file ossimPdalReader.h.
Referenced by establishAvailableFields().
mutableprotected |
Definition at line 69 of file ossimPdalReader.h.
Referenced by establishAvailableFields(), establishMinMax(), parsePoint(), and rewind().
mutableprotected |
Definition at line 70 of file ossimPdalReader.h.
Referenced by establishMinMax(), parsePoint(), parsePointView(), and rewind().
mutableprotected |
Definition at line 73 of file ossimPdalReader.h.
protected |
Definition at line 72 of file ossimPdalReader.h.
Referenced by ~ossimPdalReader().
mutableprotected |
Definition at line 71 of file ossimPdalReader.h.
mutableprotected |
Definition at line 68 of file ossimPdalReader.h.
Referenced by establishMinMax(), getNumPoints(), and rewind().
