#include <ossimGenericPointCloudHandler.h>
| ossimGenericPointCloudHandler (vector< ossimEcefPoint > &ecef_points) | |
| ossimGenericPointCloudHandler (vector< ossimGpt > &ground_points) | |
| virtual | ~ossimGenericPointCloudHandler () |
| virtual ossim_uint32 | getNumPoints () const |
| Returns the total number of points in the dataset (not just the block returned in getPoints) More... | |
| virtual void | getFileBlock (ossim_uint32 offset, ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const |
| Fetches up to maxNumPoints points starting at the dataset's <offset> in the order they appear in the data file. More... | |
| virtual ossim_uint32 | getFieldCode () const |
| Fetches the data fields ids available from this source, OR'd together for testing against specific field (. More... | |
| virtual bool | open (const ossimFilename &pointsFile) |
| Method to open input point cloud dataset. More... | |
| virtual void | close () |
| Closes the point cloud file(s). More... | |
Public Member Functions inherited from ossimPointCloudHandler | |
| ossimPointCloudHandler () | |
| ossimPointCloudHandler (ossimObject *owner) | |
| virtual | ~ossimPointCloudHandler () |
| virtual void | getNextFileBlock (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const |
| virtual void | rewind () const |
| virtual void | getBlock (const ossimGrect &bounds, ossimPointBlock &block) const |
| Fetches the block of points inside the block bounds. More... | |
| virtual const ossimPointRecord * | getMinPoint () const |
| Assigns the two points with fields representing the extremes of the dataset. More... | |
| virtual const ossimPointRecord * | getMaxPoint () const |
| virtual void | getBounds (ossimGrect &bounds) const |
| virtual bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
| Handler is always on the start of the pipeline. More... | |
| void | normalizeBlock (ossimPointBlock &block) |
Public Member Functions inherited from ossimPointCloudSource | |
| ossimPointCloudSource (ossimObject *owner=0) | |
| virtual | ~ossimPointCloudSource () |
| virtual void | setFieldCode (ossim_uint32 fieldCode) |
| Sets the data fields ID of interest for this source, and all input sources connected to this. More... | |
| virtual bool | hasFields (ossim_uint32 id) const |
| Returns true if the data field is available from this source. More... | |
| bool | hasRGB () const |
| Special for convenience. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimGenericPointCloudHandler () | |
Protected Member Functions inherited from ossimPointCloudSource | |
| ossimPointCloudSource (const ossimPointCloudSource &rhs) | |
Static Public Attributes inherited from ossimPointCloudHandler | |
| static ossim_uint32 | DEFAULT_BLOCK_SIZE = 0x400000 |
Definition at line 21 of file ossimGenericPointCloudHandler.h.
| ossimGenericPointCloudHandler::ossimGenericPointCloudHandler | ( | vector< ossimEcefPoint > & | ecef_points | ) |
Definition at line 3 of file ossimGenericPointCloudHandler.cpp.
References ossimPointBlock::addPoint(), ossimPointBlock::getBounds(), ossimGrect::ll(), ossimPointCloudHandler::m_maxRecord, ossimPointCloudHandler::m_minRecord, m_pointBlock, and ossimGrect::ur().
| ossimGenericPointCloudHandler::ossimGenericPointCloudHandler | ( | vector< ossimGpt > & | ground_points | ) |
Definition at line 18 of file ossimGenericPointCloudHandler.cpp.
Definition at line 33 of file ossimGenericPointCloudHandler.cpp.
References ossimPointBlock::clear(), and m_pointBlock.
inlineprotected |
Definition at line 36 of file ossimGenericPointCloudHandler.h.
Implements ossimPointCloudHandler.
Definition at line 67 of file ossimGenericPointCloudHandler.cpp.
bool hasIntensity = getFields() & ossimPointRecord::Intensity;
Reimplemented from ossimPointCloudSource.
Definition at line 57 of file ossimGenericPointCloudHandler.cpp.
Thread-safe implementation accepts an allocated block from the calling method. caller can check block.size() to see if block is full.
Definition at line 43 of file ossimGenericPointCloudHandler.cpp.
References ossimPointBlock::addPoint(), ossimPointBlock::clear(), ossimPointCloudHandler::m_currentPID, m_pointBlock, and ossimPointBlock::size().
Implements ossimPointCloudSource.
Definition at line 38 of file ossimGenericPointCloudHandler.cpp.
References m_pointBlock, and ossimPointBlock::size().
| imageFile | Name of point data file to be opened. (or basename for multi-file sets.) |
Definition at line 62 of file ossimGenericPointCloudHandler.cpp.
protected |
Definition at line 37 of file ossimGenericPointCloudHandler.h.
Referenced by getFileBlock(), getNumPoints(), ossimGenericPointCloudHandler(), and ~ossimGenericPointCloudHandler().
