#include <ossimIkonosMetaData.h>
| ossimIkonosMetaData () | |
| bool | open (const ossimFilename &imageFile) |
| Open method that takes the image file, derives the metadata, header and rpc files, then calls parse methods parseMetaData, parseHdrData, and parseRpcData. More... | |
| void | clearFields () |
| ossimString | getSensorID () const |
| Method to save the state of the object to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
| bool | parseMetaData (const ossimFilename &metadata) |
| Method to parse Ikonos metadata file. More... | |
| bool | parseHdrData (const ossimFilename &data_file) |
| Method to parse Ikonos header file. More... | |
| bool | parseRpcData (const ossimFilename &data_file) |
| Method to parse Ikonos rpc file. More... | |
| ossimObject () | |
| virtual | ~ossimIkonosMetaData () |
Definition at line 27 of file ossimIkonosMetaData.h.
| ossimIkonosMetaData::ossimIkonosMetaData | ( | ) |
default constructor
Definition at line 30 of file ossimIkonosMetaData.cpp.
protectedvirtual |
| void ossimIkonosMetaData::clearFields | ( | ) |
Definition at line 116 of file ossimIkonosMetaData.cpp.
References theAcquisitionDate, theAcquisitionTime, theBandName, theNominalCollectionAzimuth, theNominalCollectionElevation, theNumBands, theProductionDate, theSensorID, theSunAzimuth, and theSunElevation.
Referenced by loadState(), and open().
| ossimString ossimIkonosMetaData::getSensorID | ( | ) | const |
Definition at line 218 of file ossimIkonosMetaData.cpp.
References ossimKeywordNames::AZIMUTH_ANGLE_KW, clearFields(), ossimKeywordNames::ELEVATION_ANGLE_KW, ossimKeywordlist::find(), ossimKeywordNames::NUMBER_BANDS_KW, theAcquisitionDate, theAcquisitionTime, theBandName, theNominalCollectionAzimuth, theNominalCollectionElevation, theNumBands, theProductionDate, theSensorID, theSunAzimuth, theSunElevation, ossimString::toFloat64(), ossimString::toUInt32(), and ossimKeywordNames::TYPE_KW.
Referenced by ossimIkonosRpcModel::loadState().
| bool ossimIkonosMetaData::open | ( | const ossimFilename & | imageFile | ) |
| imageFile | Usually in the form of "po_2619900_pan_0000000.tif". |
Definition at line 49 of file ossimIkonosMetaData.cpp.
References clearFields(), ossimFilename::fileNoExtension(), and ossimString::split().
Referenced by ossimIkonosRpcModel::parseTiffFile().
| bool ossimIkonosMetaData::parseHdrData | ( | const ossimFilename & | data_file | ) |
| metadata | File name usually in the form of "po_149875_pan_0000000.hdr" |
Definition at line 506 of file ossimIkonosMetaData.cpp.
| bool ossimIkonosMetaData::parseMetaData | ( | const ossimFilename & | metadata | ) |
| metadata | File name usually in the form of "po_149875_metadata.txt." |
Definition at line 310 of file ossimIkonosMetaData.cpp.
| bool ossimIkonosMetaData::parseRpcData | ( | const ossimFilename & | data_file | ) |
| metadata | File name usually in the form of "po_149875_pan_0000000_rpc.txt" |
Definition at line 596 of file ossimIkonosMetaData.cpp.
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 130 of file ossimIkonosMetaData.cpp.
Definition at line 156 of file ossimIkonosMetaData.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimKeywordNames::ELEVATION_ANGLE_KW, ossimKeywordNames::NUMBER_BANDS_KW, theAcquisitionDate, theAcquisitionTime, theBandName, theNominalCollectionAzimuth, theNominalCollectionElevation, theNumBands, theProductionDate, theSensorID, theSunAzimuth, theSunElevation, and ossimKeywordNames::TYPE_KW.
Referenced by ossimIkonosRpcModel::saveState().
private |
Definition at line 113 of file ossimIkonosMetaData.h.
Referenced by clearFields(), loadState(), print(), and saveState().
private |
Definition at line 114 of file ossimIkonosMetaData.h.
private |
Definition at line 111 of file ossimIkonosMetaData.h.
private |
Definition at line 106 of file ossimIkonosMetaData.h.
private |
Definition at line 107 of file ossimIkonosMetaData.h.
private |
Definition at line 110 of file ossimIkonosMetaData.h.
private |
Definition at line 112 of file ossimIkonosMetaData.h.
private |
Definition at line 115 of file ossimIkonosMetaData.h.
Referenced by clearFields(), getSensorID(), loadState(), print(), and saveState().
private |
Definition at line 108 of file ossimIkonosMetaData.h.
private |
Definition at line 109 of file ossimIkonosMetaData.h.
