#include <ossimHillshadeTool.h>
| ossimHillshadeTool () | |
| virtual | ~ossimHillshadeTool () |
| virtual void | setUsage (ossimArgumentParser &ap) |
| Initializes the aurgument parser with expected parameters and options. More... | |
| virtual bool | initialize (ossimArgumentParser &ap) |
| Initial method to be ran prior to execute. More... | |
Public Member Functions inherited from ossimChipProcTool | |
| ossimChipProcTool () | |
| virtual | ~ossimChipProcTool () |
| virtual void | clear () |
| Disconnects and clears the dem and image layers. More... | |
| virtual void | initialize (const ossimKeywordlist &kwl) |
| This method is responsible for completely setting up the full processing chain according to the specifications given in the kwl passed in. More... | |
| virtual bool | execute () |
| Performs the actual product write. More... | |
| virtual void | abort () |
| virtual bool | isChipProcessor () const |
| Overrides base class implementation to indicate this class supports getChip() calls. More... | |
| virtual ossimListenerManager * | getManager () |
| virtual ossimRefPtr< ossimImageData > | getChip (const ossimIrect &img_rect) |
| The meat and potatos of this class. More... | |
| virtual ossimRefPtr< ossimImageData > | getChip (const ossimGrect &gnd_rect) |
| ossimRefPtr< ossimImageData > | getChip (const ossimDrect &map_bounding_rect, const ossimDpt &gsd) |
| ossimRefPtr< ossimImageData > | getChip () |
| Get chip method that assumes pre-initialized state. More... | |
| const ossimFilename & | getProductFilename () const |
Public Member Functions inherited from ossimTool | |
| ossimTool () | |
| virtual | ~ossimTool () |
| virtual void | loadJSON (const Json::Value &json_request) |
| Reads processing params from JSON object provided. More... | |
| virtual void | saveJSON (Json::Value &json) const |
| Fetch product as JSON object when applicable Always returns true since using exception on error. More... | |
| virtual const std::string & | getResponse () const |
| Fetch product as string (typically JSON) when applicable, otherwise passes back empty string. More... | |
| virtual void | getKwlTemplate (ossimKeywordlist &kwl) |
| Assigns a template keywordlist to string for initializing derived classes. More... | |
| void | getAPI (std::string &out) const |
| Outputs a JSON representation of the Utility's API. More... | |
| std::string | getAPI () const |
| void | getBuildDate (std::string &s) const |
| Gets build date. More... | |
| void | getRevision (std::string &s) const |
| Gets revision. More... | |
| void | getVersion (std::string &s) const |
| Gets version. More... | |
| void | setOutputStream (std::ostream *os) |
| Redirects any console output to the supplied stream for logging or JNI application. More... | |
| bool | helpRequested () const |
| Returns true when the initialization detects a "--help" option, so caller can avoid subsequent execute() call. More... | |
| ossimObject () | |
Public Member Functions inherited from ossim::JsonInterface | |
| JsonInterface () | |
| virtual | ~JsonInterface () |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ossimListenerManager () | |
Static Public Attributes | |
| static const char * | DESCRIPTION |
| Used by ossimUtilityFactory. More... | |
| virtual void | initProcessingChain () |
| Derived classes initialize their custom chains here. More... | |
| ossimHillshadeTool (const ossimHillshadeTool &obj) | |
| Hidden from use copy constructor. More... | |
| const ossimHillshadeTool & | operator= (const ossimHillshadeTool &rhs) |
| Hidden from use assignment operator. More... | |
Protected Member Functions inherited from ossimChipProcTool | |
| void | processRemainingArgs (ossimArgumentParser &ap) |
| Intended to be called after derived class has picked off its own options from the parser, and arguments remain (such as input and output filenames). More... | |
| virtual void | finalizeChain () |
| Called after initProcessingChain() to append common items to the processing chain. More... | |
| virtual void | loadImageFiles () |
| Creates chains for image entries associated with specified keyword. More... | |
| virtual void | loadDemFiles () |
| Loads all DEM files specified in master KWL into the elev manager's database. More... | |
| ossimRefPtr< ossimSingleImageChain > | createInputChain (const ossimFilename &image_file, ossim_uint32 entry_index=0) |
| Creates the ossimSingleImageChain from image filename and populates the chain with resampler and product output projection on view-side of resampler's IVT. More... | |
| void | createOutputProjection () |
| Creates the output or view projection. More... | |
| ossimRefPtr< ossimMapProjection > | newIdentityProjection () |
| Sets the single image chain for identity operations view to a ossimImageViewAffineTransform. More... | |
| ossimRefPtr< ossimMapProjection > | newUtmProjection () |
| Convenience method to get a utm projection. More... | |
| virtual void | initializeProjectionGsd () |
| Initializes the projection gsd. More... | |
| virtual void | initializeAOI () |
| Initializes m_aoiViewRect with the output area of interest as specified in master KWL. More... | |
| bool | getProjectionOrigin (ossimGpt &gpt) |
| Reads the KWL for origin latitude and central meridian. More... | |
| ossimRefPtr< ossimImageFileWriter > | newWriter () |
| Creates a new writer. More... | |
| void | propagateGeometryToChains () |
| Loops through all chains and sets the output projection. More... | |
| ossimRefPtr< ossimImageSource > | combineLayers (std::vector< ossimRefPtr< ossimSingleImageChain > > &layers) const |
| When multiple input sources are present, this method instantiates a combiner and adds inputs. More... | |
| void | computeAdjustedViewFromGrect () |
| Initializes m_aoiViewRect given m_aoiGroundRect. More... | |
| void | setAoiToInputs () |
| Assigns the AOI to be the bounding rect of the union of all inputs. More... | |
| void | getBandList (ossim_uint32 image_idx, std::vector< ossim_uint32 > &bandList) const |
| Gets the band list if BANDS keyword is set. More... | |
| void | setReaderProps (ossimImageHandler *ih) const |
| Passes reader properties to single image handler if any. More... | |
| ossimChipProcTool (const ossimChipProcTool &obj) | |
| const ossimChipProcTool & | operator= (const ossimChipProcTool &) |
| ossimRefPtr< ossimGeoPolygon > | createClipPolygon () const |
| void | findCenterGpt (ossimGpt &gpt) |
| Tries to determine the AOI center point based on KWL entries, else returns NaNs in gpt. More... | |
| ossimRefPtr< ossimImageSource > | mosaicDemSources () |
| Some utilities need to work on DEMs as images. More... | |
Definition at line 33 of file ossimHillshadeTool.h.
| ossimHillshadeTool::ossimHillshadeTool | ( | ) |
default constructor
Definition at line 71 of file ossimHillshadeTool.cpp.
References ossimTool::m_kwl, and ossimKeywordlist::setExpandEnvVarsFlag().
virtual destructor
Definition at line 87 of file ossimHillshadeTool.cpp.
References ossimChipProcTool::clear().
protected |
inlinevirtual |
Reimplemented from ossimTool.
Definition at line 46 of file ossimHillshadeTool.h.
Intended for command-line app usage.
| ap | Arg parser to initialize from. |
Reimplemented from ossimChipProcTool.
Definition at line 92 of file ossimHillshadeTool.cpp.
References ossimKeywordlist::addPair(), ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimChipProcTool::initialize(), ossimTool::m_helpRequested, ossimTool::m_kwl, and ossimArgumentParser::read().
protectedvirtual |
Implements ossimChipProcTool.
Definition at line 150 of file ossimHillshadeTool.cpp.
References ossimImageChain::add(), ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimChipProcTool::combineLayers(), ossimConnectableObject::connectMyInputTo(), ossimKeywordNames::ELEVATION_ANGLE_KW, ossimKeywordlist::findKey(), ossimRefPtr< T >::get(), ossimChipProcTool::m_imgLayers, ossimTool::m_kwl, ossimChipProcTool::m_procChain, ossimChipProcTool::mosaicDemSources(), ossimBumpShadeTileSource::setAzimuthAngle(), ossimBumpShadeTileSource::setElevationAngle(), ossimImageToPlaneNormalFilter::setSmoothnessFactor(), ossimImageToPlaneNormalFilter::setTrackScaleFlag(), ossimString::size(), and ossimString::toFloat64().
protected |
Definition at line 82 of file ossimHillshadeTool.cpp.
It does not output anything. To see the usage, the caller will need to do something like:
ap.getApplicationUsage()->write(<ostream>);
This base class has some common arguments to add. The derived class should call this implementation in addition to setting its own arguments.
Definition at line 222 of file ossimHillshadeTool.cpp.
References ossimApplicationUsage::addCommandLineOption(), ossimInit::addOptions(), DESCRIPTION, ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimInit::instance(), ossimApplicationUsage::setCommandLineUsage(), ossimApplicationUsage::setDescription(), and ossimChipProcTool::setUsage().
static |
Definition at line 49 of file ossimHillshadeTool.h.
Referenced by ossimToolFactory::getCapabilities(), and setUsage().
