ossimGdalOverviewBuilder Class to build overviews from the GDAL library. More...
#include <ossimGdalOverviewBuilder.h>
Public Types | |
| enum | ossimGdalOverviewType { ossimGdalOverviewType_UNKNOWN = 0, ossimGdalOverviewTiffNearest = 1, ossimGdalOverviewTiffAverage = 2, ossimGdalOverviewHfaNearest = 3, ossimGdalOverviewHfaAverage = 4 } |
| Enumerations for the type of GDAL overviews to build. More... | |
Public Types inherited from ossimProcessInterface | |
| enum | ossimProcessStatus { PROCESS_STATUS_UNKNOWN = 0, PROCESS_STATUS_EXECUTING = 1, PROCESS_STATUS_ABORTED = 2, PROCESS_STATUS_ABORT_REQUEST = 3, PROCESS_STATUS_NOT_EXECUTING = 4 } |
| ossimGdalOverviewBuilder () | |
| virtual | ~ossimGdalOverviewBuilder () |
| bool | open (const ossimFilename &file) |
| Open that takes a file name. More... | |
| virtual bool | execute () |
| Builds the overviews. More... | |
| virtual bool | setInputSource (ossimImageHandler *imageSource) |
Sets the input to the builder. More... | |
| virtual void | setOutputFile (const ossimFilename &file) |
| Sets the output filename. More... | |
| virtual ossimFilename | getOutputFile () const |
| Returns the output. More... | |
| virtual bool | setOverviewType (const ossimString &type) |
| Sets the overview output type. More... | |
| virtual ossimString | getOverviewType () const |
| Gets the overview type. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Method to populate class supported types. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
| Method to set properties. More... | |
| Method to populate the list of property names. More... | |
| print method. More... | |
Public Member Functions inherited from ossimOverviewBuilderBase | |
| ossimOverviewBuilderBase () | |
| virtual bool | setOutputWriter (ossimImageFileWriter *outputWriter) |
| Sets an optional file writer to the builder. More... | |
| virtual bool | hasOverviewType (const ossimString &type) const |
| Method to check if builder can handle type. More... | |
| virtual ossim_uint32 | getOverviewStopDimension () const |
| Get the overview stop dimension. More... | |
| virtual void | setOverviewStopDimension (ossim_uint32 dim) |
| Sets the overview stop dimension. More... | |
| ossimHistogramMode | getHistogramMode () const |
| Gets the histogram accumulation mode. More... | |
| void | setHistogramMode (ossimHistogramMode mode) |
| Sets the histogram accumulation mode. More... | |
| virtual void | finalize () |
| Finalize method. More... | |
| void | setBitMaskSpec (const ossimKeywordlist &bit_mask_spec) |
| Specifies parameters (in KWL) for generation of an alpha (bit) mask such that any full or partial null pixels will be masked out. More... | |
| void | setScanForMinMax (bool flag) |
| Turn on/off scan for min max flag. More... | |
| bool | getScanForMinMax () const |
| void | setScanForMinMaxNull (bool flag) |
| Turn on/off scan for min, max, null flag. More... | |
| bool | getScanForMinMaxNull () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | disconnectInputEvent (ossimConnectionEvent &) |
| virtual void | connectInputEvent (ossimConnectionEvent &) |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Private Member Functions | |
| bool | generateHfaStats () const |
| ossimString | getGdalResamplingType () const |
| ossimString | getExtensionFromType () const |
Private Attributes | |
| ossimGdalDataset * | theDataset |
| ossimFilename | theOutputFile |
| ossimGdalOverviewType | theOverviewType |
| std::vector< ossim_int32 > | theLevels |
| bool | theGenerateHfaStatsFlag |
Definition at line 31 of file ossimGdalOverviewBuilder.h.
| Enumerator | |
| ossimGdalOverviewType_UNKNOWN | |
| ossimGdalOverviewTiffNearest | |
| ossimGdalOverviewTiffAverage | |
| ossimGdalOverviewHfaNearest | |
| ossimGdalOverviewHfaAverage | |
Definition at line 38 of file ossimGdalOverviewBuilder.h.
| ossimGdalOverviewBuilder::ossimGdalOverviewBuilder | ( | ) |
default constructor
Definition at line 38 of file ossimGdalOverviewBuilder.cpp.
virtual destructor
Definition at line 48 of file ossimGdalOverviewBuilder.cpp.
References theDataset.
Implements ossimConnectableObject.
Definition at line 494 of file ossimGdalOverviewBuilder.cpp.
References PTR_CAST.
Implements ossimOverviewBuilderBase.
Definition at line 161 of file ossimGdalOverviewBuilder.cpp.
private |
Definition at line 378 of file ossimGdalOverviewBuilder.cpp.
References ossimString::c_str(), ossimString::empty(), ossimFilename::file(), ossimImageHandler::getFilename(), ossimGdalDataset::getImageHandler(), getOutputFile(), and theDataset.
private |
Definition at line 465 of file ossimGdalOverviewBuilder.cpp.
References ossimGdalOverviewHfaAverage, ossimGdalOverviewHfaNearest, and theOverviewType.
Referenced by getOutputFile().
private |
Definition at line 445 of file ossimGdalOverviewBuilder.cpp.
References ossimGdalOverviewHfaAverage, ossimGdalOverviewHfaNearest, ossimGdalOverviewTiffAverage, ossimGdalOverviewTiffNearest, ossimGdalOverviewType_UNKNOWN, and theOverviewType.
Implements ossimProcessInterface.
Definition at line 484 of file ossimGdalOverviewBuilder.cpp.
Definition at line 489 of file ossimGdalOverviewBuilder.cpp.
Returns the output.
This will be derived from the input file if not explicitly set.
Definition at line 62 of file ossimGdalOverviewBuilder.cpp.
References getExtensionFromType(), ossimImageHandler::getFilename(), ossimGdalDataset::getImageHandler(), ossimFilename::NIL, ossimGdalOverviewHfaAverage, ossimGdalOverviewHfaNearest, ossimFilename::setExtension(), theDataset, theOutputFile, and theOverviewType.
Referenced by generateHfaStats().
Satisfies pure virtual from ossimOverviewBuilderBase.
Definition at line 143 of file ossimGdalOverviewBuilder.cpp.
| propertyNames | List to populate. This does not clear the list just adds to it. |
Definition at line 360 of file ossimGdalOverviewBuilder.cpp.
| typeList | List of ossimStrings to add to. |
Definition at line 148 of file ossimGdalOverviewBuilder.cpp.
| bool ossimGdalOverviewBuilder::open | ( | const ossimFilename & | file | ) |
| file | The file to open. |
Definition at line 91 of file ossimGdalOverviewBuilder.cpp.
References ossimGdalDataset::open(), and theDataset.
print method.
Reimplemented from ossimProcessInterface.
Definition at line 367 of file ossimGdalOverviewBuilder.cpp.
References ossimString::c_str(), and theOutputFile.
| imageSource | The input to the builder. |
Reimplemented from ossimOverviewBuilderBase.
Definition at line 101 of file ossimGdalOverviewBuilder.cpp.
References ossimGdalDataset::setImageHandler(), and theDataset.
| file | The output file name. |
Definition at line 57 of file ossimGdalOverviewBuilder.cpp.
References theOutputFile.
Currently handled types are: "ossim_tiff_nearest" and "ossim_tiff_box"
| type | This should be the string representing the type. This method will do nothing if type is not handled and return false. |
Definition at line 118 of file ossimGdalOverviewBuilder.cpp.
| property | Property to set. |
Definition at line 321 of file ossimGdalOverviewBuilder.cpp.
References ossimString::downcase(), and ossimRefPtr< T >::valid().
private |
Definition at line 172 of file ossimGdalOverviewBuilder.h.
Referenced by generateHfaStats(), getOutputFile(), open(), setInputSource(), and ~ossimGdalOverviewBuilder().
private |
Definition at line 176 of file ossimGdalOverviewBuilder.h.
private |
Definition at line 175 of file ossimGdalOverviewBuilder.h.
private |
Definition at line 173 of file ossimGdalOverviewBuilder.h.
Referenced by getOutputFile(), print(), and setOutputFile().
private |
Definition at line 174 of file ossimGdalOverviewBuilder.h.
Referenced by getExtensionFromType(), getGdalResamplingType(), and getOutputFile().
