#include <ossimGeoAnnotationEllipseObject.h>
| ossimGeoAnnotationEllipseObject (const ossimGpt ¢er=ossimGpt(0, 0), const ossimDpt &widthHeight=ossimDpt(0, 0), bool enableFill=false, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| ossimGeoAnnotationEllipseObject (const ossimGeoAnnotationEllipseObject &rhs) | |
| virtual void | applyScale (double x, double y) |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual bool | intersects (const ossimDrect &rect) const |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual void | computeBoundingRect () |
| virtual void | transform (ossimImageGeometry *projection) |
| Saves the current state of this object. More... | |
| virtual void | setEllipseWidthHeightUnitType (ossimUnitType type) |
| virtual void | setWidthHeight (const ossimDpt &pt) |
| Sets the width and height of point. More... | |
| virtual void | setAzimuth (ossim_float64 azimuth) |
| Sets the azimuth. More... | |
| virtual ossim_float64 | getAzimuth () const |
| Gets the azimuth. More... | |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| Sets the color of theProjectedEllipse. More... | |
| virtual void | setThickness (ossim_uint8 thickness) |
| Sets the pen thickness of theProjectedEllipse. More... | |
| virtual void | setFillFlag (bool flag) |
| Sets the fill flag. More... | |
| virtual bool | getFillFlag () const |
| virtual void | setDrawAxesFlag (bool flag) |
| Turns on and off drawing of axes on the ellipse. More... | |
| virtual bool | getDrawAxesFlag () const |
| virtual void | setCenter (const ossimGpt &gpt) |
| Sets the center ground point. More... | |
| virtual void | getCenter (ossimGpt &gpt) const |
Public Member Functions inherited from ossimGeoAnnotationObject | |
| ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs) | |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual ossimDrect | getBoundingRect () const |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
| virtual | ~ossimGeoAnnotationEllipseObject () |
| void | getWidthHeightInPixels (ossimDpt &widthHeight, const ossimImageGeometry *projection) const |
Protected Member Functions inherited from ossimGeoAnnotationObject | |
| virtual | ~ossimGeoAnnotationObject () |
Protected Attributes | |
| ossimRefPtr< ossimAnnotationEllipseObject > | theProjectedEllipse |
| ossimGpt | theCenter |
| ossimDpt | theWidthHeight |
| ossimUnitType | theEllipseWidthHeightUnitType |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
Definition at line 14 of file ossimGeoAnnotationEllipseObject.h.
| ossimGeoAnnotationEllipseObject::ossimGeoAnnotationEllipseObject | ( | const ossimGpt & | center = ossimGpt(0,0), |
| const ossimDpt & | widthHeight = ossimDpt(0,0), |
| bool | enableFill = false, |
| ossim_uint8 | r = 255, |
| ossim_uint8 | g = 255, |
| ossim_uint8 | b = 255, |
| ossim_uint8 | thickness = 1 |
It is important to note that the width and height should be specified in width = deltaLon and height = deltaLat. Use the ossimDpt .lat and .lon attributes to set it.
Definition at line 23 of file ossimGeoAnnotationEllipseObject.cpp.
References theProjectedEllipse.
Referenced by dup().
| ossimGeoAnnotationEllipseObject::ossimGeoAnnotationEllipseObject | ( | const ossimGeoAnnotationEllipseObject & | rhs | ) |
Definition at line 46 of file ossimGeoAnnotationEllipseObject.cpp.
protectedvirtual |
Definition at line 56 of file ossimGeoAnnotationEllipseObject.cpp.
References theProjectedEllipse, and ossimRefPtr< T >::valid().
Implements ossimAnnotationObject.
Definition at line 69 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::applyScale(), ossimGpt::latd(), ossimGpt::lond(), theCenter, theProjectedEllipse, theWidthHeight, ossimRefPtr< T >::valid(), ossimDpt::x, x, ossimDpt::y, and y.
Definition at line 131 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::computeBoundingRect(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Definition at line 88 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::draw(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Definition at line 64 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimGeoAnnotationEllipseObject().
Gets the azimuth.
Definition at line 261 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getAzimuth(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by saveState().
Definition at line 119 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getBoundingRect(), ossimDrect::makeNan(), theProjectedEllipse, and ossimRefPtr< T >::valid().
| gpt | The point to initialize with the center. |
Definition at line 392 of file ossimGeoAnnotationEllipseObject.cpp.
References theCenter.
Definition at line 378 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getDrawAxesFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Definition at line 361 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getFillFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 106 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getNewClippedObject(), intersects(), theProjectedEllipse, and ossimRefPtr< T >::valid().
protected |
Definition at line 270 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimImageGeometry::getMetersPerPixel(), ossimImageGeometry::getProjection(), ossimUnitConversionTool::getValue(), ossimImageGeometry::hasProjection(), ossimProjection::origin(), OSSIM_DEGREES, OSSIM_METERS, OSSIM_MINUTES, OSSIM_PIXEL, OSSIM_SECONDS, ossimUnitConversionTool::setValue(), theEllipseWidthHeightUnitType, theWidthHeight, ossimDpt::x, x, ossimDpt::y, and y.
Referenced by transform().
Definition at line 96 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::intersects(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by getNewClippedObject().
Reimplemented from ossimGeoAnnotationObject.
Definition at line 174 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimKeywordlist::find(), ossimUnitTypeLut::getEntryNumber(), ossimUnitTypeLut::instance(), ossimGeoAnnotationObject::loadState(), OSSIM_PIXEL, OSSIM_UNIT_UNKNOWN, setAzimuth(), ossimAnnotationObject::setColor(), setDrawAxesFlag(), setFillFlag(), ossimAnnotationObject::setThickness(), status, ossimAnnotationObject::theBlue, theCenter, theEllipseWidthHeightUnitType, ossimAnnotationObject::theGreen, theProjectedEllipse, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, theWidthHeight, ossimString::toDouble(), ossimDpt::x, and ossimDpt::y.
Generic print method.
Derived classes should re-implement as they see fit.
Reimplemented from ossimAnnotationObject.
Definition at line 79 of file ossimGeoAnnotationEllipseObject.cpp.
References theCenter, theEllipseWidthHeightUnitType, and theProjectedEllipse.
Keywords:
center: ( 42.403388263727003, -90.708557648541046, 0.0, WGE )
ellipse_width: 500
ellipse_height: 500
units: meters
Definition at line 159 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), getAzimuth(), getDrawAxesFlag(), getFillFlag(), ossimUnitTypeLut::instance(), ossimGeoAnnotationObject::saveState(), theCenter, theEllipseWidthHeightUnitType, theWidthHeight, ossimGpt::toString(), ossimString::toString(), ossimDpt::x, and ossimDpt::y.
Sets the azimuth.
| azimuth | in degrees. |
Definition at line 253 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::setAzimuth(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by loadState().
| gpt | The center ground point. |
Definition at line 387 of file ossimGeoAnnotationEllipseObject.cpp.
RGB range 0 to 255
| r | DN value for red. |
| g | DN value for green. |
| b | DN value for blue. |
Definition at line 334 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationObject::setColor(), theProjectedEllipse, and ossimRefPtr< T >::valid().
This flag is only used if fill is turned off.
| flag | true to enable, false to disable. |
Definition at line 370 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::setDrawAxesFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Definition at line 242 of file ossimGeoAnnotationEllipseObject.cpp.
References theEllipseWidthHeightUnitType.
Referenced by ossimEsriShapeFileFilter::loadPoint().
Sets the fill flag.
flag True to fill, false to not fill.
Definition at line 353 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::setFillFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by loadState(), and ossimGdalOgrVectorAnnotation::updateAnnotationSettings().
range 0 to 255
| thickness | Pen thickness. |
Definition at line 345 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationObject::setThickness(), theProjectedEllipse, and ossimRefPtr< T >::valid().
| pt | Point with pt.x being width and pt.y being height. |
Definition at line 248 of file ossimGeoAnnotationEllipseObject.cpp.
References theWidthHeight.
Referenced by ossimGdalOgrVectorAnnotation::updateAnnotationSettings().
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 139 of file ossimGeoAnnotationEllipseObject.cpp.
References getWidthHeightInPixels(), ossimAnnotationEllipseObject::setCenterWidthHeight(), theCenter, theProjectedEllipse, and ossimImageGeometry::worldToLocal().
Referenced by ossimGdalOgrVectorAnnotation::loadPoint(), and ossimGdalOgrVectorAnnotation::updateAnnotationSettings().
protected |
Definition at line 142 of file ossimGeoAnnotationEllipseObject.h.
Referenced by applyScale(), getCenter(), loadState(), print(), saveState(), setCenter(), and transform().
protected |
Definition at line 145 of file ossimGeoAnnotationEllipseObject.h.
Referenced by getWidthHeightInPixels(), loadState(), print(), saveState(), and setEllipseWidthHeightUnitType().
protected |
Definition at line 141 of file ossimGeoAnnotationEllipseObject.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getAzimuth(), getBoundingRect(), getDrawAxesFlag(), getFillFlag(), getNewClippedObject(), intersects(), loadState(), ossimGeoAnnotationEllipseObject(), print(), setAzimuth(), setColor(), setDrawAxesFlag(), setFillFlag(), setThickness(), transform(), and ~ossimGeoAnnotationEllipseObject().
protected |
Definition at line 143 of file ossimGeoAnnotationEllipseObject.h.
Referenced by applyScale(), getWidthHeightInPixels(), loadState(), saveState(), and setWidthHeight().
