#include <stdio.h>Go to the source code of this file.
Classes | |
| struct | SAHooks |
| struct | SHPInfo |
| struct | SHPObject |
| struct | shape_tree_node |
| struct | SHPTree |
Macros | |
| #define | TRIM_DBF_WHITESPACE |
| #define | DISABLE_MULTIPATCH_MEASURE |
| #define | SHPAPI_CALL |
| #define | SHPAPI_CALL1(x) x SHPAPI_CALL |
| #define | SHP_CVSID(string) |
| #define | SHPT_NULL 0 |
| #define | SHPT_POINT 1 |
| #define | SHPT_ARC 3 |
| #define | SHPT_POLYGON 5 |
| #define | SHPT_MULTIPOINT 8 |
| #define | SHPT_POINTZ 11 |
| #define | SHPT_ARCZ 13 |
| #define | SHPT_POLYGONZ 15 |
| #define | SHPT_MULTIPOINTZ 18 |
| #define | SHPT_POINTM 21 |
| #define | SHPT_ARCM 23 |
| #define | SHPT_POLYGONM 25 |
| #define | SHPT_MULTIPOINTM 28 |
| #define | SHPT_MULTIPATCH 31 |
| #define | SHPP_TRISTRIP 0 |
| #define | SHPP_TRIFAN 1 |
| #define | SHPP_OUTERRING 2 |
| #define | SHPP_INNERRING 3 |
| #define | SHPP_FIRSTRING 4 |
| #define | SHPP_RING 5 |
| #define | MAX_SUBNODE 4 |
| #define | MAX_DEFAULT_TREE_DEPTH 12 |
| #define | XBASE_FLDHDR_SZ 32 |
Typedefs | |
| typedef int * | SAFile |
| typedef unsigned long | SAOffset |
| typedef SHPInfo * | SHPHandle |
| typedef struct shape_tree_node | SHPTreeNode |
Functions | |
| void SHPAPI_CALL | SASetupDefaultHooks (SAHooks *psHooks) |
| SHPHandle SHPAPI_CALL | SHPOpen (const char *pszShapeFile, const char *pszAccess) |
| SHPHandle SHPAPI_CALL | SHPOpenLL (const char *pszShapeFile, const char *pszAccess, SAHooks *psHooks) |
| SHPHandle SHPAPI_CALL | SHPCreate (const char *pszShapeFile, int nShapeType) |
| SHPHandle SHPAPI_CALL | SHPCreateLL (const char *pszShapeFile, int nShapeType, SAHooks *psHooks) |
| void SHPAPI_CALL | SHPGetInfo (SHPHandle hSHP, int *pnEntities, int *pnShapeType, double *padfMinBound, double *padfMaxBound) |
| SHPObject SHPAPI_CALL1 * | SHPReadObject (SHPHandle hSHP, int iShape);int SHPAPI_CALL SHPWriteObject(SHPHandle hSHP, int iShape, SHPObject *psObject |
| void SHPAPI_CALL | SHPDestroyObject (SHPObject *psObject) |
| void SHPAPI_CALL | SHPComputeExtents (SHPObject *psObject) |
| SHPObject SHPAPI_CALL1 * | SHPCreateObject (int nSHPType, int nShapeId, int nParts, const int *panPartStart, const int *panPartType, int nVertices, const double *padfX, const double *padfY, const double *padfZ, const double *padfM);SHPObject SHPAPI_CALL1(*) SHPCreateSimpleObject(int nSHPType, int nVertices, const double *padfX, const double *padfY, const double *padfZ |
| int SHPAPI_CALL | SHPRewindObject (SHPHandle hSHP, SHPObject *psObject) |
| void SHPAPI_CALL | SHPClose (SHPHandle hSHP) |
| void SHPAPI_CALL | SHPWriteHeader (SHPHandle hSHP) |
| const char SHPAPI_CALL1 * | SHPTypeName (int nSHPType);const char SHPAPI_CALL1(*) SHPPartTypeName(int nPartType |
| SHPTree SHPAPI_CALL1 * | SHPCreateTree (SHPHandle hSHP, int nDimension, int nMaxDepth, double *padfBoundsMin, double *padfBoundsMax);void SHPAPI_CALL SHPDestroyTree(SHPTree *hTree |
| int SHPAPI_CALL | SHPWriteTree (SHPTree *hTree, const char *pszFilename) |
| SHPTree SHPAPI_CALL | SHPReadTree (const char *pszFilename) |
| int SHPAPI_CALL | SHPTreeAddObject (SHPTree *hTree, SHPObject *psObject) |
| int SHPAPI_CALL | SHPTreeAddShapeId (SHPTree *hTree, SHPObject *psObject) |
| int SHPAPI_CALL | SHPTreeRemoveShapeId (SHPTree *hTree, int nShapeId) |
| void SHPAPI_CALL | SHPTreeTrimExtraNodes (SHPTree *hTree) |
| int SHPAPI_CALL1 * | SHPTreeFindLikelyShapes (SHPTree *hTree, double *padfBoundsMin, double *padfBoundsMax, int *);int SHPAPI_CALL SHPCheckBoundsOverlap(double *, double *, double *, double *, int |
| int SHPAPI_CALL1 * | SHPSearchDiskTree (FILE *fp, double *padfBoundsMin, double *padfBoundsMax, int *pnShapeCount);typedef struct{ SAHooks sHooks;SAFile fp;int nRecords;int nRecordLength;int nHeaderLength;int nFields;int *panFieldOffset;int *panFieldSize;int *panFieldDecimals;char *pachFieldType;char *pszHeader;int nCurrentRecord;int bCurrentRecordModified;char *pszCurrentRecord;int nWorkFieldLength;char *pszWorkField;int bNoHeader;int bUpdated;double dfDoubleField;} DBFInfo;typedef DBFInfo *DBFHandle;typedef enum { FTString, FTInteger, FTDouble, FTLogical, FTInvalid} DBFFieldType;#define XBASE_FLDHDR_SZDBFHandle SHPAPI_CALL DBFOpen(const char *pszDBFFile, const char *pszAccess |
| DBFHandle SHPAPI_CALL | DBFOpenLL (const char *pszDBFFile, const char *pszAccess, SAHooks *psHooks) |
| DBFHandle SHPAPI_CALL | DBFCreate (const char *pszDBFFile) |
| DBFHandle SHPAPI_CALL | DBFCreateLL (const char *pszDBFFile, SAHooks *psHooks) |
| int SHPAPI_CALL | DBFGetFieldCount (DBFHandle psDBF) |
| int SHPAPI_CALL | DBFGetRecordCount (DBFHandle psDBF) |
| int SHPAPI_CALL | DBFAddField (DBFHandle hDBF, const char *pszFieldName, DBFFieldType eType, int nWidth, int nDecimals) |
| int SHPAPI_CALL | DBFAddNativeFieldType (DBFHandle hDBF, const char *pszFieldName, char chType, int nWidth, int nDecimals) |
| DBFFieldType SHPAPI_CALL | DBFGetFieldInfo (DBFHandle psDBF, int iField, char *pszFieldName, int *pnWidth, int *pnDecimals) |
| int SHPAPI_CALL | DBFGetFieldIndex (DBFHandle psDBF, const char *pszFieldName) |
| int SHPAPI_CALL | DBFReadIntegerAttribute (DBFHandle hDBF, int iShape, int iField) |
| double SHPAPI_CALL | DBFReadDoubleAttribute (DBFHandle hDBF, int iShape, int iField) |
| const char SHPAPI_CALL1 * | DBFReadStringAttribute (DBFHandle hDBF, int iShape, int iField);const char SHPAPI_CALL1(*) DBFReadLogicalAttribute(DBFHandle hDBF, int iShape, int iField |
| int SHPAPI_CALL | DBFIsAttributeNULL (DBFHandle hDBF, int iShape, int iField) |
| int SHPAPI_CALL | DBFWriteIntegerAttribute (DBFHandle hDBF, int iShape, int iField, int nFieldValue) |
| int SHPAPI_CALL | DBFWriteDoubleAttribute (DBFHandle hDBF, int iShape, int iField, double dFieldValue) |
| int SHPAPI_CALL | DBFWriteStringAttribute (DBFHandle hDBF, int iShape, int iField, const char *pszFieldValue) |
| int SHPAPI_CALL | DBFWriteNULLAttribute (DBFHandle hDBF, int iShape, int iField) |
| int SHPAPI_CALL | DBFWriteLogicalAttribute (DBFHandle hDBF, int iShape, int iField, const char lFieldValue) |
| int SHPAPI_CALL | DBFWriteAttributeDirectly (DBFHandle psDBF, int hEntity, int iField, void *pValue) |
| const char SHPAPI_CALL1 * | DBFReadTuple (DBFHandle psDBF, int hEntity);int SHPAPI_CALL DBFWriteTuple(DBFHandle psDBF, int hEntity, void *pRawTuple |
| int SHPAPI_CALL | DBFIsRecordDeleted (DBFHandle psDBF, int iShape) |
| int SHPAPI_CALL | DBFMarkRecordDeleted (DBFHandle psDBF, int iShape, int bIsDeleted) |
| DBFHandle SHPAPI_CALL | DBFCloneEmpty (DBFHandle psDBF, const char *pszFilename) |
| void SHPAPI_CALL | DBFClose (DBFHandle hDBF) |
| void SHPAPI_CALL | DBFUpdateHeader (DBFHandle hDBF) |
| char SHPAPI_CALL | DBFGetNativeFieldType (DBFHandle hDBF, int iField) |
| #define DISABLE_MULTIPATCH_MEASURE |
Definition at line 129 of file shapefil.h.
| #define MAX_DEFAULT_TREE_DEPTH 12 |
Definition at line 366 of file shapefil.h.
| #define MAX_SUBNODE 4 |
Definition at line 363 of file shapefil.h.
| #define SHP_CVSID | ( | string | ) |
Definition at line 183 of file shapefil.h.
| #define SHPAPI_CALL |
Definition at line 170 of file shapefil.h.
| #define SHPAPI_CALL1 | ( | x | ) | x SHPAPI_CALL |
Definition at line 175 of file shapefil.h.
| #define SHPP_FIRSTRING 4 |
Definition at line 270 of file shapefil.h.
| #define SHPP_INNERRING 3 |
Definition at line 269 of file shapefil.h.
Referenced by ossimShapeObject::getPartByName().
| #define SHPP_OUTERRING 2 |
Definition at line 268 of file shapefil.h.
| #define SHPP_RING 5 |
Definition at line 271 of file shapefil.h.
Referenced by ossimShapeObject::getPartByName(), ossimEsriShapeFileFilter::loadArc(), and ossimEsriShapeFileFilter::loadPolygon().
| #define SHPP_TRIFAN 1 |
Definition at line 267 of file shapefil.h.
| #define SHPP_TRISTRIP 0 |
Definition at line 266 of file shapefil.h.
| #define SHPT_ARC 3 |
Definition at line 247 of file shapefil.h.
Referenced by ossimEsriShapeFileFilter::loadShapeFile().
| #define SHPT_ARCM 23 |
Definition at line 255 of file shapefil.h.
| #define SHPT_ARCZ 13 |
Definition at line 251 of file shapefil.h.
| #define SHPT_MULTIPATCH 31 |
Definition at line 258 of file shapefil.h.
| #define SHPT_MULTIPOINT 8 |
Definition at line 249 of file shapefil.h.
| #define SHPT_MULTIPOINTM 28 |
Definition at line 257 of file shapefil.h.
| #define SHPT_MULTIPOINTZ 18 |
Definition at line 253 of file shapefil.h.
| #define SHPT_NULL 0 |
Definition at line 245 of file shapefil.h.
Referenced by ossimShapeObject::getType(), and ossimEsriShapeFileFilter::loadShapeFile().
| #define SHPT_POINT 1 |
Definition at line 246 of file shapefil.h.
| #define SHPT_POINTM 21 |
Definition at line 254 of file shapefil.h.
| #define SHPT_POINTZ 11 |
Definition at line 250 of file shapefil.h.
| #define SHPT_POLYGON 5 |
Definition at line 248 of file shapefil.h.
| #define SHPT_POLYGONM 25 |
Definition at line 256 of file shapefil.h.
| #define SHPT_POLYGONZ 15 |
Definition at line 252 of file shapefil.h.
| #define TRIM_DBF_WHITESPACE |
Definition at line 122 of file shapefil.h.
| #define XBASE_FLDHDR_SZ 32 |
| typedef int* SAFile |
Definition at line 192 of file shapefil.h.
| typedef unsigned long SAOffset |
Definition at line 195 of file shapefil.h.
Definition at line 240 of file shapefil.h.
| typedef struct shape_tree_node SHPTreeNode |
| int SHPAPI_CALL DBFAddField | ( | DBFHandle | hDBF, |
| const char * | pszFieldName, | ||
| DBFFieldType | eType, | ||
| int | nWidth, | ||
| int | nDecimals | ||
| int SHPAPI_CALL DBFAddNativeFieldType | ( | DBFHandle | hDBF, |
| char | chType, | ||
| int | nWidth, | ||
| DBFHandle SHPAPI_CALL DBFCloneEmpty | ( | DBFHandle | psDBF, |
| const char * | pszFilename | ||
| void SHPAPI_CALL DBFClose | ( | DBFHandle | hDBF | ) |
Referenced by ossimShapeDatabase::close().
| DBFHandle SHPAPI_CALL DBFCreate | ( | const char * | pszDBFFile | ) |
| DBFHandle SHPAPI_CALL DBFCreateLL | ( | const char * | pszDBFFile, |
| SAHooks * | psHooks | ||
| int SHPAPI_CALL DBFGetFieldCount | ( | DBFHandle | psDBF | ) |
| int SHPAPI_CALL DBFGetFieldIndex | ( | DBFHandle | psDBF, |
| const char * | pszFieldName | ||
| DBFFieldType SHPAPI_CALL DBFGetFieldInfo | ( | DBFHandle | psDBF, |
| int | iField, | ||
| int * | pnWidth, | ||
| int * | pnDecimals | ||
Referenced by ossimShapeDatabase::getRecord(), and ossimShapeDatabase::print().
| char SHPAPI_CALL DBFGetNativeFieldType | ( | DBFHandle | hDBF, |
| int | iField | ||
| int SHPAPI_CALL DBFGetRecordCount | ( | DBFHandle | psDBF | ) |
| int SHPAPI_CALL DBFIsAttributeNULL | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField | ||
| int SHPAPI_CALL DBFIsRecordDeleted | ( | DBFHandle | psDBF, |
| int | iShape | ||
| int SHPAPI_CALL DBFMarkRecordDeleted | ( | DBFHandle | psDBF, |
| int | iShape, | ||
| int | bIsDeleted | ||
| DBFHandle SHPAPI_CALL DBFOpenLL | ( | const char * | pszDBFFile, |
| const char * | pszAccess, | ||
| double SHPAPI_CALL DBFReadDoubleAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField | ||
| int SHPAPI_CALL DBFReadIntegerAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField | ||
| const char SHPAPI_CALL1* DBFReadStringAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField | ||
| ) | const |
| const char SHPAPI_CALL1* DBFReadTuple | ( | DBFHandle | psDBF, |
| int | hEntity | ||
| void SHPAPI_CALL DBFUpdateHeader | ( | DBFHandle | hDBF | ) |
| int SHPAPI_CALL DBFWriteAttributeDirectly | ( | DBFHandle | psDBF, |
| int | hEntity, | ||
| int | iField, | ||
| void * | pValue | ||
| int SHPAPI_CALL DBFWriteDoubleAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField, | ||
| double | dFieldValue | ||
| int SHPAPI_CALL DBFWriteIntegerAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField, | ||
| int | nFieldValue | ||
| int SHPAPI_CALL DBFWriteLogicalAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField, | ||
| const char | lFieldValue | ||
| int SHPAPI_CALL DBFWriteNULLAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField | ||
| int SHPAPI_CALL DBFWriteStringAttribute | ( | DBFHandle | hDBF, |
| int | iShape, | ||
| int | iField, | ||
| const char * | pszFieldValue | ||
| void SHPAPI_CALL SASetupDefaultHooks | ( | SAHooks * | psHooks | ) |
| void SHPAPI_CALL SHPClose | ( | SHPHandle | hSHP | ) |
Referenced by ossimShapeFile::close().
| void SHPAPI_CALL SHPComputeExtents | ( | SHPObject * | psObject | ) |
| SHPHandle SHPAPI_CALL SHPCreate | ( | const char * | pszShapeFile, |
| int | nShapeType | ||
| SHPHandle SHPAPI_CALL SHPCreateLL | ( | const char * | pszShapeFile, |
| int | nShapeType, | ||
| SHPObject SHPAPI_CALL1* SHPCreateObject | ( | int | nSHPType, |
| int | nShapeId, | ||
| int | nParts, | ||
| const int * | panPartStart, | ||
| const int * | panPartType, | ||
| int | nVertices, | ||
| const double * | padfX, | ||
| const double * | padfY, | ||
| const double * | padfZ, | ||
| const double * | padfM | ||
| ) | const |
| SHPTree SHPAPI_CALL1* SHPCreateTree | ( | SHPHandle | hSHP, |
| int | nDimension, | ||
| int | nMaxDepth, | ||
| double * | padfBoundsMin, | ||
| double * | padfBoundsMax | ||
| void SHPAPI_CALL SHPDestroyObject | ( | SHPObject * | psObject | ) |
| void SHPAPI_CALL SHPGetInfo | ( | SHPHandle | hSHP, |
| int * | pnEntities, | ||
| int * | pnShapeType, | ||
| double * | padfMinBound, | ||
| double * | padfMaxBound | ||
| SHPHandle SHPAPI_CALL SHPOpen | ( | const char * | pszShapeFile, |
| const char * | pszAccess | ||
Referenced by ossimShapeFile::open().
| SHPHandle SHPAPI_CALL SHPOpenLL | ( | const char * | pszShapeFile, |
| SHPObject SHPAPI_CALL1* SHPReadObject | ( | SHPHandle | hSHP, |
| int | iShape | ||
Referenced by ossimShapeObject::loadShape().
| SHPTree SHPAPI_CALL SHPReadTree | ( | const char * | pszFilename | ) |
| int SHPAPI_CALL SHPRewindObject | ( | SHPHandle | hSHP, |
| SHPObject * | psObject | ||
| int SHPAPI_CALL1* SHPSearchDiskTree | ( | FILE * | fp, |
| double * | padfBoundsMax, | ||
| int * | pnShapeCount | ||
| ) | const |
| int SHPAPI_CALL SHPTreeAddObject | ( | SHPTree * | hTree, |
| int SHPAPI_CALL SHPTreeAddShapeId | ( | SHPTree * | hTree, |
| int SHPAPI_CALL1* SHPTreeFindLikelyShapes | ( | SHPTree * | hTree, |
| int * | |||
Referenced by ossimEsriShapeFileFilter::drawAnnotations().
| int SHPAPI_CALL SHPTreeRemoveShapeId | ( | SHPTree * | hTree, |
| int | nShapeId | ||
| void SHPAPI_CALL SHPTreeTrimExtraNodes | ( | SHPTree * | hTree | ) |
| const char SHPAPI_CALL1* SHPTypeName | ( | int | nSHPType | ) | const |
Referenced by ossimShapeFile::getShapeTypeString(), and ossimShapeObject::getTypeByName().
| void SHPAPI_CALL SHPWriteHeader | ( | SHPHandle | hSHP | ) |
| int SHPAPI_CALL SHPWriteTree | ( | SHPTree * | hTree, |
