#include <ossimSpaceObliqueMercatorProjection.h>
Public Types | |
| enum | ossimSatelliteType { SOM_TYPE_LANDSAT_1 = 0, SOM_TYPE_LANDSAT_2 = 1, SOM_TYPE_LANDSAT_3 = 2, SOM_TYPE_LANDSAT_4 = 3, SOM_TYPE_LANDSAT_5 = 4, SOM_TYPE_LANDSAT_7 = 5 } |
| ossimSpaceObliqueMercatorProjection (ossimSatelliteType type=SOM_TYPE_LANDSAT_7, double pathNumber=34, const ossimEllipsoid &ellipsoid=ossimEllipsoid()) | |
| virtual ossimDpt | forward (const ossimGpt &worldPoint) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual ossimGpt | inverse (const ossimDpt &projectedPoint) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual void | setParameters (ossimSatelliteType type, double path) |
| virtual void | update () |
| virtual bool | operator== (const ossimProjection &projection) const |
| Returns TRUE if principal parameters are within epsilon tolerance. More... | |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getFalseEasting () const |
| virtual double | getFalseNorthing () const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
| void | seraz0 (double lam, double mult) |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes | |
| double | a2 |
| double | a4 |
| double | b |
| double | c1 |
| double | c3 |
| double | q |
| double | t |
| double | u |
| double | w |
| double | p22 |
| double | sa |
| double | ca |
| double | xj |
| double | rlm |
| double | rlm2 |
| double | lam0 |
| double | es |
| double | e |
| double | one_es |
| double | rone_es |
| double | a |
| double | thePath |
| ossimSatelliteType | theSatelliteType |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
This class implments the formulas for the ellipsoid and circular orbit. All formulas were directly taken from proj 4. Proj 4 implementation is from the following manual reference:
Map Projections - A Working Manual by John Snyder Space Oblique Mercator p. 221.
Definition at line 27 of file ossimSpaceObliqueMercatorProjection.h.
| Enumerator | |
| SOM_TYPE_LANDSAT_1 | |
| SOM_TYPE_LANDSAT_2 | |
| SOM_TYPE_LANDSAT_3 | |
| SOM_TYPE_LANDSAT_4 | |
| SOM_TYPE_LANDSAT_5 | |
| SOM_TYPE_LANDSAT_7 | |
Definition at line 30 of file ossimSpaceObliqueMercatorProjection.h.
| ossimSpaceObliqueMercatorProjection::ossimSpaceObliqueMercatorProjection | ( | ossimSatelliteType | type = SOM_TYPE_LANDSAT_7, |
| double | pathNumber = 34, |
| const ossimEllipsoid & | ellipsoid = ossimEllipsoid() |
Definition at line 81 of file ossimSpaceObliqueMercatorProjection.cpp.
inlinevirtual |
Implements ossimProjection.
Definition at line 44 of file ossimSpaceObliqueMercatorProjection.h.
Definition at line 192 of file ossimSpaceObliqueMercatorProjection.cpp.
References a, a2, a4, aasin(), b, c1, c3, ca, ossimGpt::changeDatum(), ossimDatum::code(), ossimGpt::datum(), es, FORTPI, HALFPI, lam0, ossimGpt::latr(), ossimGpt::lonr(), ossimDpt::makeNan(), one_es, p22, PI_HALFPI, q, rlm, rlm2, sa, t, ossimMapProjection::theDatum, TOL, TWOPI_HALFPI, w, ossimDpt::x, xj, and ossimDpt::y.
Definition at line 273 of file ossimSpaceObliqueMercatorProjection.cpp.
References a, a2, a4, aasin(), b, c1, c3, ca, DEG_PER_RAD, es, FORTPI, HALFPI, lam0, one_es, p22, q, rone_es, sa, t, ossimMapProjection::theDatum, TOL, u, w, ossimDpt::x, xj, and ossimDpt::y.
Definition at line 358 of file ossimSpaceObliqueMercatorProjection.cpp.
References ossimKeywordlist::find().
Definition at line 400 of file ossimSpaceObliqueMercatorProjection.cpp.
References ossim::almostEqual(), thePath, and theSatelliteType.
Definition at line 340 of file ossimSpaceObliqueMercatorProjection.cpp.
References ossimKeywordlist::add().
protected |
Definition at line 165 of file ossimSpaceObliqueMercatorProjection.cpp.
References a2, a4, b, c1, c3, ca, p22, q, RAD_PER_DEG, sa, sq, t, w, and xj.
Referenced by setParameters().
Definition at line 93 of file ossimSpaceObliqueMercatorProjection.cpp.
References ossimEllipsoid::a(), a, a2, a4, b, c1, c3, ca, e, ossimEllipsoid::eccentricity(), es, lam0, one_es, p22, PI, q, RAD_PER_DEG, rlm, rlm2, rone_es, sa, seraz0(), SOM_TYPE_LANDSAT_1, SOM_TYPE_LANDSAT_2, SOM_TYPE_LANDSAT_3, SOM_TYPE_LANDSAT_4, SOM_TYPE_LANDSAT_5, SOM_TYPE_LANDSAT_7, t, ossimMapProjection::theEllipsoid, thePath, theSatelliteType, TWOPI, u, update(), w, and xj.
Definition at line 327 of file ossimSpaceObliqueMercatorProjection.cpp.
protected |
Definition at line 83 of file ossimSpaceObliqueMercatorProjection.h.
Referenced by forward(), inverse(), and setParameters().
protected |
Definition at line 74 of file ossimSpaceObliqueMercatorProjection.h.
Referenced by forward(), inverse(), seraz0(), and setParameters().
protected |
protected |
protected |
protected |
protected |
Definition at line 75 of file ossimSpaceObliqueMercatorProjection.h.
protected |
Definition at line 80 of file ossimSpaceObliqueMercatorProjection.h.
protected |
Definition at line 79 of file ossimSpaceObliqueMercatorProjection.h.
protected |
Definition at line 78 of file ossimSpaceObliqueMercatorProjection.h.
protected |
Definition at line 81 of file ossimSpaceObliqueMercatorProjection.h.
protected |
protected |
protected |
Referenced by forward(), and setParameters().
protected |
protected |
Definition at line 82 of file ossimSpaceObliqueMercatorProjection.h.
Referenced by inverse(), and setParameters().
protected |
protected |
protected |
Is the p variable in Map Projections a Working Manual.
Definition at line 90 of file ossimSpaceObliqueMercatorProjection.h.
Referenced by operator==(), and setParameters().
protected |
Definition at line 91 of file ossimSpaceObliqueMercatorProjection.h.
protected |
protected |
protected |
