Factory for J2K image reader. More...
#include <ossimKakaduReaderFactory.h>
| virtual | ~ossimKakaduReaderFactory () |
| virtual ossimImageHandler * | open (const ossimFilename &fileName, bool openOverview=true) const |
| open that takes a file name. More... | |
| virtual ossimImageHandler * | open (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Open overview that takes a file name. More... | |
| virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview) const |
| Open method that takes a stream. More... | |
| virtual ossimRefPtr< ossimImageHandler > | openOverview (const ossimFilename &file) const |
| virtual ossimRefPtr< ossimImageHandler > | openOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| createObject that takes a class name (ossimKakaduReader) More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Creates and object given a keyword list and prefix. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Adds ossimKakaduWriter to the typeList. More... | |
| virtual void | getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const |
| Method to add supported extension to the list, like "jp2". More... | |
| virtual void | getImageHandlersBySuffix (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const |
| Will add to the result list any handler that supports the passed in extensions. More... | |
| virtual void | getImageHandlersByMimeType (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const |
| Will add to the result list and handler that supports the passed in mime type. More... | |
Public Member Functions inherited from ossimImageHandlerFactoryBase | |
| virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::ImageHandlerState > state) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimKakaduReaderFactory * | instance () |
| static method to return instance (the only one) of this class. More... | |
| bool | hasExcludedExtension (const ossimFilename &file) const |
| Method to weed out extensions that this plugin knows it does not support. More... | |
| ossimKakaduReaderFactory () | |
| hidden from use default constructor More... | |
| ossimKakaduReaderFactory (const ossimKakaduReaderFactory &) | |
| hidden from use copy constructor More... | |
| void | operator= (const ossimKakaduReaderFactory &) |
Public Types inherited from ossimImageHandlerFactoryBase | |
| typedef UniqueList< ossimString > | UniqueStringList |
| typedef std::vector< ossimRefPtr< ossimImageHandler > > | ImageHandlerList |
Definition at line 21 of file ossimKakaduReaderFactory.h.
protected |
Definition at line 309 of file ossimKakaduReaderFactory.cpp.
protected |
Definition at line 311 of file ossimKakaduReaderFactory.cpp.
| typeName | Should be "ossimKakaduReader". |
Implements ossimObjectFactory.
Definition at line 208 of file ossimKakaduReaderFactory.cpp.
References ossimRefPtr< T >::release().
| kwl | The keyword list. |
| prefix | the keyword list prefix. |
Definition at line 226 of file ossimKakaduReaderFactory.cpp.
References open().
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 290 of file ossimKakaduReaderFactory.cpp.
References ossimString::begin(), ossimString::end(), and ossimString::push_back().
Definition at line 268 of file ossimKakaduReaderFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
| extensionList | The list to add to. |
Implements ossimImageHandlerFactoryBase.
Definition at line 241 of file ossimKakaduReaderFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
| typeList | List to add to. |
Definition at line 233 of file ossimKakaduReaderFactory.cpp.
protected |
This is to avoid a costly open on say a tiff or jpeg that is not handled by this plugin.
Definition at line 248 of file ossimKakaduReaderFactory.cpp.
References ossimString::downcase(), and ossimFilename::ext().
static |
Definition at line 34 of file ossimKakaduReaderFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
| file | The file to open. |
| openOverview | If true image handler will attempt to open overview. default = true |
Definition at line 40 of file ossimKakaduReaderFactory.cpp.
Referenced by createObject().
| file | File to open. |
Definition at line 82 of file ossimKakaduReaderFactory.cpp.
This implementation returns an ossimRefPtr with a null pointer.
| str | Open stream to image. |
| connectionString | |
| openOverview | If true attempt to open overview file. |
Definition at line 143 of file ossimKakaduReaderFactory.cpp.
References ossimRefPtr< T >::get(), ossimNitfTileSource::open(), openOverview(), and ossimImageHandler::setOpenOverviewFlag().
Definition at line 168 of file ossimKakaduReaderFactory.cpp.
References ossimImageHandler::open(), ossimImageHandler::setOpenOverviewFlag(), and ossimString::size().
Referenced by open().
| connectionString |
Definition at line 186 of file ossimKakaduReaderFactory.cpp.
References ossimRefPtr< T >::get(), ossimNitfTileSource::open(), and ossimImageHandler::setOpenOverviewFlag().
protected |
Definition at line 313 of file ossimKakaduReaderFactory.cpp.
