#include <ossimImageStatisticsSource.h>
| ossimImageStatisticsSource () | |
| virtual void | computeStatistics () |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| const std::vector< ossim_float64 > & | getMean () const |
| const std::vector< ossim_float64 > & | getMin () const |
| const std::vector< ossim_float64 > & | getMax () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimImageStatisticsSource () |
| void | clearStatistics () |
| template<class T > | |
| void | computeStatisticsTemplate (T dummyVariable) |
| void | setStatsSize (ossim_uint32 size) |
Definition at line 5 of file ossimImageStatisticsSource.h.
| ossimImageStatisticsSource::ossimImageStatisticsSource | ( | ) |
Definition at line 15 of file ossimImageStatisticsSource.cpp.
protectedvirtual |
Definition at line 24 of file ossimImageStatisticsSource.cpp.
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 81 of file ossimImageStatisticsSource.cpp.
References PTR_CAST.
protected |
Definition at line 161 of file ossimImageStatisticsSource.cpp.
References theMax, theMean, and theMin.
Referenced by computeStatistics().
Definition at line 29 of file ossimImageStatisticsSource.cpp.
References clearStatistics(), computeStatisticsTemplate(), ossimConnectableObject::getInput(), ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, and PTR_CAST.
protected |
Definition at line 88 of file ossimImageStatisticsSource.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimImageSourceSequencer::getNextTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageData::getWidth(), OSSIM_EMPTY, setStatsSize(), ossimImageSourceSequencer::setToStartOfSequence(), status, theMax, theMean, and theMin.
| const std::vector< ossim_float64 > & ossimImageStatisticsSource::getMax | ( | ) | const |
Definition at line 156 of file ossimImageStatisticsSource.cpp.
References theMax.
| const std::vector< ossim_float64 > & ossimImageStatisticsSource::getMean | ( | ) | const |
Definition at line 146 of file ossimImageStatisticsSource.cpp.
References theMean.
| const std::vector< ossim_float64 > & ossimImageStatisticsSource::getMin | ( | ) | const |
Definition at line 151 of file ossimImageStatisticsSource.cpp.
References theMin.
protected |
Definition at line 168 of file ossimImageStatisticsSource.cpp.
References OSSIM_DEFAULT_MAX_PIX_DOUBLE, OSSIM_DEFAULT_MIN_PIX_DOUBLE, size, theMax, theMean, and theMin.
Referenced by computeStatisticsTemplate().
protected |
Definition at line 29 of file ossimImageStatisticsSource.h.
Referenced by clearStatistics(), computeStatisticsTemplate(), getMax(), and setStatsSize().
protected |
Definition at line 27 of file ossimImageStatisticsSource.h.
Referenced by clearStatistics(), computeStatisticsTemplate(), getMean(), and setStatsSize().
protected |
Definition at line 28 of file ossimImageStatisticsSource.h.
Referenced by clearStatistics(), computeStatisticsTemplate(), getMin(), and setStatsSize().
