ossimImageViewProjectionTransform.cpp
Go to the documentation of this file.
1 //*****************************************************************************
2 // FILE: ossimImageViewProjectionTransform.cc
3 //
4 // License: LGPL
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // AUTHOR: Garrett Potts
9 // Oscar Kramer ([email protected])
10 //
11 // DESCRIPTION: Contains declaration of ossimImageViewProjectionTransform.
12 // This class provides an image to view transform that utilizes two
13 // independent 2D-to-3D projections. Intended for transforming view to
14 // geographic "world" space to input image space.
15 //
16 // LIMITATIONS: None.
17 //
18 //*****************************************************************************
19 // $Id: ossimImageViewProjectionTransform.cpp 20489 2012-01-23 20:07:56Z dburken $
20 //
22 #include <ossim/base/ossimDrect.h>
24 #include <ossim/base/ossimIpt.h>
28 #include <cmath>
29
31  "ossimImageViewProjectionTransform",
33
34 //*****************************************************************************
35 // CONSTRUCTOR: ossimImageViewProjectionTransform
36 //*****************************************************************************
38 ( ossimImageGeometry* imageGeometry, ossimImageGeometry* viewGeometry)
39 : m_imageGeometry(imageGeometry),
40  m_viewGeometry(viewGeometry),
41  m_crossesDateline(false)
42 {
43 }
44
45 //*****************************************************************************
46 // CONSTRUCTOR: ossimImageViewProjectionTransform
47 //*****************************************************************************
51  m_imageGeometry(src.m_imageGeometry),
52  m_viewGeometry(src.m_viewGeometry),
53  m_crossesDateline(false)
54 {
55 }
56
57 //*****************************************************************************
58 // DESTRUCTOR: ~ossimImageViewProjectionTransform
59 //*****************************************************************************
61 {
62 }
65 {
66  m_viewGeometry = g;
67
69 }
70
73 {
74  m_imageGeometry = g;
76 }
77
78 //*****************************************************************************
79 // Workhorse of the object. Converts image-space to view-space.
80 //*****************************************************************************
82 {
83  // Check for same geometries on input and output (this includes NULL geoms):
85  {
86  vp = ip;
87  return;
88  }
89
90  // Otherwise we need access to good geoms. Check for a bad geometry object:
92  {
93  vp.makeNan();
94  return;
95  }
96
97  // Check for same projection on input and output sides to save projection to ground:
99  {
100  // Check for possible same 2D transforms as well:
103  {
104  vp = ip;
105  return;
106  }
107
108  // Not the same 2D transform, so just perform local-image -> full-image -> local-view:
109  ossimDpt fp;
110  m_imageGeometry->rnToFull(ip, 0, fp);
111  m_viewGeometry->fullToRn(fp, 0, vp);
112  return;
113  }
114
115  //---
116  // Completely different left and right side geoms (typical situation).
117  // Need to project to ground.
118  //---
119  ossimGpt gp;
120  m_imageGeometry->localToWorld(ip, gp);
121  m_viewGeometry->worldToLocal(gp, vp);
122
123 #if 0 /* Please leave for debug. */
124  cout <<"DEBUG ossimImageViewProjectionTransform::imageToView:"
125  <<"\n ip: "<<ip
126  <<"\n gp: "<<gp
127  <<"\n vp: "<<vp<<std::endl;
128 #endif
129 }
130
131 //*****************************************************************************
132 // Other workhorse of the object. Converts view-space to image-space.
133 //*****************************************************************************
135 {
136  // Check for same geometries on input and output (this includes NULL geoms):
138  {
139  ip = vp;
140  return;
141  }
142
143  // Otherwise we need access to good geoms. Check for a bad geometry object:
145  {
146  ip.makeNan();
147  return;
148  }
149
150  // Check for same projection on input and output sides to save projection to ground:
152  const ossimProjection* vproj = m_viewGeometry->getProjection();
153  if ((iproj && vproj && iproj->isEqualTo(*vproj)) || (iproj == vproj))
154  {
155  // Check for possible same 2D transforms as well:
158  if (((ixform && vxform && ixform->isEqualTo(*vxform)) || (ixform == vxform)) &&
160  {
161  ip = vp;
162  return;
163  }
164
165  // Not the same 2D transform, so just perform local-image -> full-image -> local-view:
166  ossimDpt fp;
167  m_viewGeometry->rnToFull(vp, 0, fp);
168  m_imageGeometry->fullToRn(fp, 0, ip);
169  return;
170  }
171
172  //---
173  // Completely different left and right side geoms (typical situation).
174  // Need to project to ground.
175  //---
176  ossimGpt gp;
177  m_viewGeometry->localToWorld(vp, gp);
178  m_imageGeometry->worldToLocal(gp, ip);
179
180 #if 0 /* Please leave for debug. */
181  cout <<"DEBUG ossimImageViewProjectionTransform::viewToImage:"
182  <<"\n vp: "<<vp
183  <<"\n gp: "<<gp
184  <<"\n ip: "<<ip
185  <<std::endl;
186 #endif
187 }
188
189 void ossimImageViewProjectionTransform::getViewSegments(std::vector<ossimDrect>& viewBounds,
190  ossimPolyArea2d& polyArea,
191  ossim_uint32 numberOfEdgePoints)const
192 {
193  ossimDrect imageRect;
194  ossimDrect worldRect(ossimDpt(-180,-90),
195  ossimDpt(-180,90),
196  ossimDpt(180,90),
197  ossimDpt(180,-90));
198  viewBounds.clear();
199  polyArea.clear();
200
201  if(m_imageGeometry.valid())
202  {
203  m_imageGeometry->getBoundingRect(imageRect);
204  ossim_uint32 idx=0;
205  std::vector<ossimDpt> points;
206  std::vector<ossimGpt> gPoints;
207  bool affectedByElevation = m_imageGeometry->isAffectedByElevation();
208
209
210  if((numberOfEdgePoints > 2)&&(affectedByElevation))
211  {
212  m_imageGeometry->getImageEdgePoints(points, numberOfEdgePoints);
213  }
214  else
215  {
216  points.resize(4);
217
218  points[0] = imageRect.ul();
219  points[1] = imageRect.ur();
220  points[2] = imageRect.lr();
221  points[3] = imageRect.ll();
222  }
224  {
225  ossimDpt testPt;
226  ossimGpt cg;
227  m_imageGeometry->localToWorld(imageRect.midPoint(), cg);
228  ossim_int32 sgn = static_cast<ossim_int32>(ossim::sgn(cg.lond()));
229  std::vector<ossimPolygon> polyList;
230  for(idx=0; idx < points.size();++idx)
231  {
232  ossimGpt testGpt;
233  m_imageGeometry->localToWorld(points[idx], testGpt);
234
235  if(!testGpt.isLatNan()&&!testGpt.isLonNan())
236  {
237  gPoints.push_back(testGpt);
238  }
239  }
240
241  // first we get the list of ground points initialized
242  // and shifted to one side of the full world rect
243  // We will do the other side next
244  //
245  for(idx=0; idx < gPoints.size();++idx)
246  {
247  if(std::fabs(gPoints[idx].lond()-cg.lond()) > 180)
248  {
249  gPoints[idx].lond(gPoints[idx].lond()+sgn*360);
250  }
251  }
252
253  // now clip the ground list to the full ground rect
254  //
255  ossimPolygon tempPoly(gPoints);
256  tempPoly.clipToRect(polyList, worldRect);
257
258  ossim_uint32 pointListIdx=0;
259
260  // Loop through the clipped polygons and find their
261  // view projection. We will add this to the view
262  // bounds and we will add to the poly Area. Poly Area
263  // is used for a tighter clip.
264  //
265  for(pointListIdx=0;pointListIdx<polyList.size();++pointListIdx)
266  {
267  const std::vector<ossimDpt>& clipPoints = polyList[pointListIdx].getVertexList();
268  points.clear();
269  for(idx = 0; idx<clipPoints.size(); ++idx)
270  {
271  m_viewGeometry->worldToLocal(ossimGpt(clipPoints[idx]), testPt);
272  if(!testPt.hasNans())
273  {
274  points.push_back(testPt);
275  }
276  }
277  viewBounds.push_back(ossimDrect(points));
278
279  if (points.size() >= 4)
280  {
281  points.push_back(points[0]);
282  polyArea.add(ossimPolyArea2d(points));//ossimPolygon(points)));
283  }
284  }
285
286  // now shift the ground points to the other side of the world rect
287  //
288  for(idx=0; idx < gPoints.size();++idx)
289  {
290  gPoints[idx].lond(gPoints[idx].lond()+(-sgn*360));
291  }
292
293  // Now we will do the same thing to the other side of the world
294  // and find the view projection and add those to the poly area
295  // and the view rect
296  //
297  tempPoly = gPoints;
298  polyList.clear();
299  tempPoly.clipToRect(polyList, worldRect);
300
301  for(pointListIdx=0;pointListIdx<polyList.size();++pointListIdx)
302  {
303  const std::vector<ossimDpt>& clipPoints = polyList[pointListIdx].getVertexList();
304  points.clear();
305  for(idx = 0; idx<clipPoints.size(); ++idx)
306  {
307  m_viewGeometry->worldToLocal(ossimGpt(clipPoints[idx]), testPt);
308  if(!testPt.hasNans())
309  {
310  points.push_back(testPt);
311  }
312  }
313  viewBounds.push_back(ossimDrect(points));
314  if (points.size() >= 4)
315  {
316  points.push_back(points[0]);
317  polyArea.add(ossimPolyArea2d(points));//ossimPolygon(points)));
318  }
319
320  }
321  }// end: if(m_crossesDateline)
322  else
323  {
324  ossimDpt testPoint;
325  std::vector<ossimDpt> vpoints;
326
327  for(idx=0; idx < points.size();++idx)
328  {
329  ossimDpt testDpt;
330  imageToView(points[idx], testDpt);
331  if(!testDpt.hasNans())
332  {
333  vpoints.push_back(testDpt);
334  }
335  }
336
337  if(vpoints.size())
338  {
339  vpoints.push_back(vpoints[0]);
340  viewBounds.push_back(ossimDrect(vpoints));
341  polyArea = vpoints;// = ossimPolyArea2d(points);
342
343  }
344  }
345  }
346 }
347
348
350 {
351  ossimImageGeometry* g = dynamic_cast<ossimImageGeometry*>(baseObject);
352  bool new_view_set = false;
353  m_crossesDateline = false;
354  if (g)
355  {
356  m_viewGeometry = g;
357  new_view_set = true;
358  }
359  else
360  {
361  ossimProjection* proj = dynamic_cast<ossimProjection*>(baseObject);
362  if(proj)
363  {
364  if(m_viewGeometry.valid())
365  {
367  }
368  else
369  {
370  m_viewGeometry = new ossimImageGeometry(0, proj);
371  }
372
373  new_view_set = true;
374  }
375  }
376
377  if ( m_viewGeometry.valid() && m_viewGeometry-> getImageSize().hasNans() )
378  {
379  // Sets the view image size from the image geometry if present.
381  }
382
383  return new_view_set;
384 }
385
386 //*****************************************************************************
387 // Dumps contents to stream
388 //*****************************************************************************
390 {
391  out << "ossimImageViewProjectionTransform::print: ..... entered " <<endl;
392
393  if(m_imageGeometry.valid())
394  {
395  out << " Input Image (LEFT) Geometry: " << endl;
396  m_imageGeometry->print(out);
397  }
398  else
399  {
400  out << " None defined." << endl;
401  }
402  if(m_viewGeometry.valid())
403  {
404  out << "Output View (RIGHT) Geometry: " << endl;
405  m_viewGeometry->print(out);
406  }
407  else
408  {
409  out << " None defined." << endl;
410  }
411  return out;
412 }
413
414 //**************************************************************************************************
415 // Converts the local image space rect into bounding view-space rect
416 //**************************************************************************************************
418 {
419  // Let base class try:
421
422  // If not successful, compute using input and output geometries:
423  if (result.hasNans() && m_imageGeometry.valid() && m_viewGeometry.valid() &&
425  {
426  ossimGeoPolygon viewClip;
428  if(viewClip.size())
429  {
430  std::vector<ossimGpt> imageGpts(4);
431  m_imageGeometry->localToWorld(imageRect.ul(), imageGpts[0]);
432  m_imageGeometry->localToWorld(imageRect.ur(), imageGpts[1]);
433  m_imageGeometry->localToWorld(imageRect.lr(), imageGpts[2]);
434  m_imageGeometry->localToWorld(imageRect.ll(), imageGpts[3]);
435
436  const ossimDatum* viewDatum = m_viewGeometry->getProjection()->origin().datum();
437  imageGpts[0].changeDatum(viewDatum);
438  imageGpts[1].changeDatum(viewDatum);
439  imageGpts[2].changeDatum(viewDatum);
440  imageGpts[3].changeDatum(viewDatum);
441
442  ossimPolyArea2d viewPolyArea(viewClip.getVertexList());
443  ossimPolyArea2d imagePolyArea(imageGpts);
444  viewPolyArea &= imagePolyArea;
445  std::vector<ossimPolygon> visiblePolygons;
446  viewPolyArea.getVisiblePolygons(visiblePolygons);
447  if(visiblePolygons.size())
448  {
449  std::vector<ossimDpt> vpts;
450  ossim_uint32 idx = 0;
451  for(idx=0; idx<visiblePolygons[0].getNumberOfVertices();++idx)
452  {
453  ossimDpt tempPt;
454  ossimGpt gpt(visiblePolygons[0][idx].lat, visiblePolygons[0][idx].lon, 0.0, viewDatum);
455  m_viewGeometry->worldToLocal(gpt, tempPt);
456  vpts.push_back(tempPt);
457  }
458  result = ossimDrect(vpts);
459  }
460  }
461  }
462  return result;
463 }
464
465 //*****************************************************************************
466 // METHOD: ossimImageViewProjectionTransform::loadState
467 //*****************************************************************************
469  const char* prefix)
470 {
471  bool result = ossimImageViewTransform::loadState(kwl, prefix);
472  if(result)
473  {
474  ossimString imagePrefix = ossimString(prefix)+"image_geometry.";
475  ossimString viewPrefix = ossimString(prefix)+"view_geometry.";
476  if(kwl.numberOf(imagePrefix.c_str())>0)
477  {
479  m_imageGeometry->loadState(kwl, imagePrefix.c_str());
480  }
481  if(kwl.numberOf(viewPrefix.c_str())>0)
482  {
484  m_viewGeometry->loadState(kwl, viewPrefix.c_str());
485  }
486
487  }
488
489  return result;
490 }
491
492 //**************************************************************************************************
493 //
494 //**************************************************************************************************
496  const char* prefix)const
497 {
498  ossimString imagePrefix = ossimString(prefix)+"image_geometry.";
499  ossimString viewPrefix = ossimString(prefix)+"view_geometry.";
500
501  if(m_imageGeometry.valid())
502  {
503  m_imageGeometry->saveState(kwl, imagePrefix.c_str());
504  }
505  if(m_viewGeometry.valid())
506  {
507  m_viewGeometry->saveState(kwl, viewPrefix.c_str());
508  }
509  return ossimImageViewTransform::saveState(kwl, prefix);
510 }
511
512 //**************************************************************************************************
513 // Returns the GSD of input image.
514 //**************************************************************************************************
516 {
517  ossimDpt result;
518
521  else
522  result.makeNan();
523
524  return result;
525 }
526
527 //**************************************************************************************************
528 // Returns the GSD of the output view.
529 //**************************************************************************************************
531 {
532  ossimDpt result;
533
536  else
537  result.makeNan();
538
539  return result;
540 }
541
542 // Initialize view geometry image size from image geometry.
544 {
545  bool result = false;
546  m_crossesDateline = false;
547  if ( m_imageGeometry.valid() )
548  {
550  ossimDrect imageRect( 0, 0,
553  ossimDpt size;
554  ossimDrect rect;
556  {
557  ossimGpt ulg;
558  ossimGpt urg;
559  ossimGpt lrg;
560  ossimGpt llg;
561  ossimGpt cg;
562  ossimDpt ul;
563  ossimDpt ur;
564  ossimDpt lr;
565  ossimDpt ll;
566  m_imageGeometry->localToWorld(imageRect.ul(), ulg);
567  m_imageGeometry->localToWorld(imageRect.ur(), urg);
568  m_imageGeometry->localToWorld(imageRect.lr(), lrg);
569  m_imageGeometry->localToWorld(imageRect.ll(), llg);
570  m_imageGeometry->localToWorld(imageRect.midPoint(), cg);
571
572  if(std::fabs(ulg.lond()-cg.lond()) > 180)
573  {
574  ulg.lond(ulg.lond()+ossim::sgn(cg.lond())*360);
575  }
576  if(std::fabs(urg.lond()-cg.lond()) > 180)
577  {
578  urg.lond((urg.lond()+ossim::sgn(cg.lond())*360));
579  }
580  if(std::fabs(lrg.lond()-cg.lond()) > 180)
581  {
582  lrg.lond(lrg.lond()+ossim::sgn(cg.lond())*360);
583  }
584  if(std::fabs(llg.lond()-cg.lond()) > 180)
585  {
586  llg.lond(llg.lond()+ossim::sgn(cg.lond())*360);
587  }
588
589  m_viewGeometry->worldToLocal(ulg, ul);
590  m_viewGeometry->worldToLocal(urg, ur);
591  m_viewGeometry->worldToLocal(lrg, lr);
592  m_viewGeometry->worldToLocal(llg, ll);
593
594  rect= ossimDrect(ul,ur,lr,ll);
595  }
596  else
597  {
598  rect = getImageToViewBounds( imageRect );
599  }
600  size.x = ossim::round<ossim_int32>( rect.width() );
601  size.y = ossim::round<ossim_int32>( rect.height() );
602  if ( size.hasNans() == false )
603  {
605  result = true;
606  }
607 // std::cout << "VIEW SIZE ============== " << size << "\n";
608 #if 0
609
610  if ( (imageRect.hasNans() == false) && m_viewGeometry.valid() )
611  {
613  if ( viewProj.valid() )
614  {
615  ossimIpt size;
616  size.makeNan();
617
618  const ossimEquDistCylProjection* eqProj =
619  dynamic_cast<const ossimEquDistCylProjection*>( viewProj.get() );
620  if ( eqProj )
621  {
622  // Specialized to take into consideration a date line crossing.
623
624  // Get the ground points we need:
625  ossimDpt iRight(imageRect.ul().x+1, imageRect.ul().y);
626  ossimDpt iDown(imageRect.ul().x, imageRect.ul().y+1);
627  ossimGpt gul;
628  ossimGpt gur;
629  ossimGpt glr;
630  ossimGpt gll;
631  ossimGpt gRight;
632  ossimGpt gDown;
633  ossim_float64 hdd; // height decimal degrees
634  ossim_float64 wdd; // width decimal degrees
635  ossim_float64 leftLon;
636  ossim_float64 rightLon;
637
638  m_imageGeometry->localToWorld( imageRect.ul(), gul );
639  m_imageGeometry->localToWorld( imageRect.ur(), gur );
640  m_imageGeometry->localToWorld( imageRect.lr(), glr );
641  m_imageGeometry->localToWorld( imageRect.ll(), gll );
642  m_imageGeometry->localToWorld( iRight, gRight );
643  m_imageGeometry->localToWorld( iDown, gDown );
644
645  //---
646  // Determine the direction of the image and get the geographic bounding box.
647  // For the longitude consider a date line crossing.
648  //---
649  if ( gul.lat > gDown.lat ) // oriented north up
650  {
651  if ( gul.lat >= gRight.lat ) // straight up or leaning right
652  {
653  hdd = gul.lat - glr.lat;
654  leftLon = gll.lon;
655  rightLon = gur.lon;
656  }
657  else // leaning left
658  {
659  hdd = gur.lat - gll.lat;
660  leftLon = gul.lon;
661  rightLon = glr.lon;
662  }
663  }
664  else // south or on side
665  {
666  if ( gRight.lat >= gul.lat ) // straight down or leaning right
667  {
668  hdd = glr.lat - gul.lat;
669  leftLon = gur.lon;
670  rightLon = gll.lon;
671  }
672  else // leaning left
673  {
674  hdd = gll.lat - gur.lat;
675  leftLon = glr.lon;
676  rightLon = gul.lon;
677  }
678  }
679
680  if ( rightLon > leftLon )
681  {
682  wdd = rightLon - leftLon;
683  }
684  else // Date line cross:
685  {
686  wdd = rightLon + 360.0 - leftLon;
687  }
688
689  //---
690  // Add one pixel width/height to the point to point size to make it edge to edge
691  // before dividing by gsd to get the size. The view projection gsd is used here
692  // since the view could be a different resolution than the input projection.
693  //---
694  size.x = ossim::round<ossim_int32>(
695  ( wdd + eqProj->getDecimalDegreesPerPixel().x ) /
696  eqProj->getDecimalDegreesPerPixel().x );
697  size.y = ossim::round<ossim_int32>(
698  ( hdd + eqProj->getDecimalDegreesPerPixel().y ) /
699  eqProj->getDecimalDegreesPerPixel().y );
700
701 #if 0 /* Please leave for debug: */
702  cout << "\nwdd: " << wdd
703  << "\nhdd: " << hdd
704  << "\ngul: " << gul
705  << "\ngur: " << gur
706  << "\nglr: " << glr
707  << "\ngll: " << gll
708  << endl;
709 #endif
710  }
711  else // Not an ossimEquDistCylProjection:
712  {
713  ossimDrect rect = getImageToViewBounds( imageRect );
714  size.x = ossim::round<ossim_int32>( rect.width() );
715  size.y = ossim::round<ossim_int32>( rect.height() );
716  }
717
718 #if 0 /* Please leave for debug: */
719  cout << "m_imageGeometry:\n" << *(m_imageGeometry.get())
720  << "\n\nm_viewGeometry:\n" << *(m_viewGeometry.get())
721  << "\n\ncomputed view size: " << size << endl;
722 #endif
723
724  if ( size.hasNans() == false )
725  {
727  result = true;
728  }
729
730  } // Matches: if ( viewProj.valid() )
731
732  } // Matches: if ( (imageRect.hasNans() == false) ...
733 #endif
734
735  } // Matches: if ( m_imageGeometry.valid() && ...
736
737  return result;
738
739 } // End: bool ossimImageViewProjectionTransform::initializeViewSize()
740
742 {
743  m_crossesDateline = false;
744  if(m_imageGeometry.valid())
745  {
747  }
748 }
Dumps contents to stream.
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
virtual ossimDrect getImageToViewBounds(const ossimDrect &imageRect) const
Gets the image bounding rect in view-space coordinates.
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
virtual bool isEqualTo(const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const
ossim_uint32 numberOf(const char *str) const
virtual void imageToView(const ossimDpt &imagePoint, ossimDpt &viewPoint) const
bool isAffectedByElevation() const
Returns TRUE if this geometry is sensitive to elevation.
T sgn(T x)
Definition: ossimCommon.h:339
ossim_float64 width() const
Definition: ossimDrect.h:522
const ossimIpt & getImageSize() const
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
bool isLonNan() const
Definition: ossimGpt.h:140
bool valid() const
Definition: ossimRefPtr.h:75
Attempts to initialize a transform and a projection given the KWL.
std::ostream & print(std::ostream &out) const
Prints contents to output stream.
void getBoundingRect(ossimIrect &bounding_rect) const
Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1).
const ossimDpt & ul() const
Definition: ossimDrect.h:339
double y
Definition: ossimDpt.h:165
virtual void viewToImage(const ossimDpt &viewPoint, ossimDpt &imagePoint) const
RTTI_DEF1(ossimImageViewProjectionTransform, "ossimImageViewProjectionTransform", ossimImageViewTransform)
void setImageSize(const ossimIpt &size)
void setViewGeometry(ossimImageGeometry *g)
Assigns the geometry to use for output view. This object does NOT own the geometry.
bool isLatNan() const
Definition: ossimGpt.h:139
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
double ossim_float64
virtual ossimDpt getOutputMetersPerPixel() const
void rnToFull(const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimDpt &fullPt) const
rnToFull is a utility method that takes a rn resolution image point and maps it to the full image poi...
virtual void getGroundClipPoints(ossimGeoPolygon &gpts) const
Computes the bounding rect in view space of the quad formed by the transformed image points of the in...
yy_size_t size
ossim_float64 lon
Definition: ossimGpt.h:266
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
virtual ossimDpt getMetersPerPixel() const =0
unsigned int ossim_uint32
virtual bool setView(ossimObject *baseObject)
This is used a a general access point for setting a view to a chain.
const std::vector< ossimGpt > & getVertexList() const
ossimRefPtr< ossimImageGeometry > m_imageGeometry
ossimRefPtr< ossimImageGeometry > m_viewGeometry
bool hasNans() const
Definition: ossimDrect.h:396
Definition: ossimDpt.h:67
void add(const ossimPolyArea2d &rhs)
ossim_float64 height() const
Definition: ossimDrect.h:517
ossim_uint32 size() const
virtual void getViewSegments(std::vector< ossimDrect > &viewBounds, ossimPolyArea2d &polyArea, ossim_uint32 numberOfEdgePoints=25) const
Because of the fact we can have dateline crossings there exist on the view plane both positive and ne...
bool clipToRect(vector< ossimPolygon > &result, const ossimDrect &rect) const
Uses the ossimPolyArea2d class for the intersection.
After rewrite for incorporating ossimImageGeometry: No longer needed.
bool initializeViewSize()
Initializes the view geometry image size from image geometry bounding rect.
virtual ossimGpt origin() const =0
ossimDpt midPoint() const
Definition: ossimDrect.h:817
ossim_int32 y
Definition: ossimIpt.h:142
const ossimDpt & ur() const
Definition: ossimDrect.h:340
virtual ossimDpt getInputMetersPerPixel() const
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
const ossim2dTo2dTransform * getTransform() const
Access methods for transform (may be NULL pointer).
bool hasProjection() const
Returns TRUE if valid projection defined.
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
Saves the transform (if any) and projection (if any) states to the KWL.
ossim_int32 x
Definition: ossimIpt.h:141
const ossimDpt & ll() const
Definition: ossimDrect.h:342
ossim_float64 lat
Definition: ossimGpt.h:265
void fullToRn(const ossimDpt &fullPt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
fullToRn is a utility method that takes a full image point and maps it to a rn resolution image point...
ossimImageViewProjectionTransform(ossimImageGeometry *imageGeometry=0, ossimImageGeometry *viewGeometry=0)
const ossimDpt & lr() const
Definition: ossimDrect.h:341
void makeNan()
Definition: ossimDpt.h:65
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
void setImageGeometry(ossimImageGeometry *g)
Assigns the geometry to use for input image. This object does NOT own the geometry.
ossimDpt decimationFactor(ossim_uint32 r_index) const
Returns the decimation factor from R0 for the resolution level specified.
int ossim_int32
void getImageEdgePoints(std::vector< ossimDpt > &result, ossim_uint32 partitions=25) const
