#include <ossimMapViewController.h>
| ossimMapViewController () | |
| ossimMapViewController (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListFixedFlag=true, bool outputListFixedFlag=false) | |
| virtual | ~ossimMapViewController () |
| virtual bool | setView (ossimObject *object) |
| virtual void | setFilename (const ossimFilename &file) |
Public Member Functions inherited from ossimViewController | |
| ossimViewController () | |
| ossimViewController (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListFixedFlag=true, bool outputListFixedFlag=false) | |
| virtual | ~ossimViewController () |
| virtual bool | propagateView () |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
| virtual const ossimObject * | findFirstViewOfType (RTTItypeid typeId) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Definition at line 14 of file ossimMapViewController.h.
| ossimMapViewController::ossimMapViewController | ( | ) |
Definition at line 20 of file ossimMapViewController.cpp.
| ossimMapViewController::ossimMapViewController | ( | ossimObject * | owner, |
| ossim_uint32 | inputListSize, | ||
| ossim_uint32 | outputListSize, | ||
| bool | inputListFixedFlag = true, |
| bool | outputListFixedFlag = false |
Definition at line 25 of file ossimMapViewController.cpp.
References ossimProjection::dup(), ossimViewController::findFirstViewOfType(), PTR_CAST, STATIC_TYPE_INFO, ossimConnectableObject::theOwner, and ossimViewController::theView.
Definition at line 59 of file ossimMapViewController.cpp.
Permits changing the object's owner.
Reimplemented from ossimConnectableObject.
Definition at line 73 of file ossimMapViewController.cpp.
References ossimConnectableObject::changeOwner(), ossimProjection::dup(), ossimViewController::findFirstViewOfType(), ossimViewController::propagateView(), PTR_CAST, setView(), STATIC_TYPE_INFO, and ossimViewController::theView.
inlinevirtual |
Definition at line 28 of file ossimMapViewController.h.
References theGeometryFile.
inlinevirtual |
Reimplemented from ossimViewController.
Definition at line 38 of file ossimMapViewController.h.
inlinevirtual |
Definition at line 33 of file ossimMapViewController.h.
Definition at line 159 of file ossimMapViewController.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), ossimProjectionFactoryRegistry::createProjection(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimRefPtr< T >::get(), ossimProjectionFactoryRegistry::instance(), ossimSource::loadState(), setView(), and theGeometryFile.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 120 of file ossimMapViewController.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::FILENAME_KW, ossimViewController::getView(), ossimNotify(), ossimNotifyLevel_WARN, PTR_CAST, ossimSource::saveState(), ossimMapProjection::saveState(), theGeometryFile, and ossimKeywordlist::writeToStream().
Definition at line 102 of file ossimMapViewController.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), ossimProjectionFactoryRegistry::createProjection(), ossimFilename::exists(), ossimRefPtr< T >::get(), ossimProjectionFactoryRegistry::instance(), setView(), and theGeometryFile.
Definition at line 63 of file ossimMapViewController.cpp.
References PTR_CAST, and ossimViewController::setView().
Referenced by changeOwner(), loadState(), and setFilename().
protected |
If the file is not "" (empty) then it will use this filename to load and save the geometry projection.
Definition at line 54 of file ossimMapViewController.h.
Referenced by getFilename(), loadState(), saveState(), and setFilename().
