#include <ossimTilingPoly.h>
Classes | |
| struct | ossimShpFeature |
| ossimTilingPoly () | |
| virtual | ~ossimTilingPoly () |
| virtual bool | initialize (const ossimMapProjection &proj, const ossimIrect &boundingRect) |
| virtual bool | next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName) |
| bool | useMbr () const |
| bool | hasExteriorCut () const |
| return true if exterior cut is initialized. More... | |
| bool | hasInteriorCut () const |
| return true if interior cut is initialized. More... | |
| ossimRefPtr< ossimGeoPolyCutter > & | getExteriorCut () |
| ossimRefPtr< ossimGeoPolyCutter > & | getInteriorCut () |
| bool | isFeatureBoundingIntersect () const |
Public Member Functions inherited from ossimTilingRect | |
| ossimTilingRect () | |
| virtual | ~ossimTilingRect () |
Public Member Functions inherited from ossimTiling | |
| ossimTiling () | |
| bool | next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName) const |
| void | reset () |
| void | setTilingDistance (const ossimDpt &tilingDistance, ossimUnitType unitType) |
| void | setDelta (const ossimDpt &delta, ossimTilingDeltaType deltaType) |
| This sets the pixel delta. More... | |
| void | setTileNameMask (const ossimString &mask) |
| This sets the tilename mask. More... | |
| ossimString | getTileNameMask () const |
| bool | getRowCol (ossim_int64 &row, ossim_int64 &col, ossim_int64 tileId) const |
| bool | getOrigin (ossimDpt &origin, ossim_int64 tileId) const |
| bool | getOrigin (ossimDpt &origin, ossim_int64 row, ossim_int64 col) const |
| void | setPaddingSizeInPixels (const ossimIpt &pizelOverlap) |
| ossimDpt | getDeltaPerPixel () const |
| ossimObject () | |
| bool | parseShpFile () |
| bool | nextFeature () |
| void | setRect () |
Protected Member Functions inherited from ossimTilingRect | |
| bool | initializeBase (const ossimMapProjection &proj, const ossimIrect &boundingRect, ossimDpt &convertedTilingDistance) |
| void | getConvertedDistance (ossimDpt &pt, ossimDpt inputDistance) const |
| ossimDpt | getPaddingSize () const |
Protected Member Functions inherited from ossimTiling | |
| void | getConvertedTilingDistance (ossimDpt &pt) const |
| bool | validate () const |
| bool | isAngularUnit (ossimUnitType unitType) const |
| bool | isLinearUnit (ossimUnitType unitType) const |
| void | getTileName (ossimString &resultingName, ossim_int64 row, ossim_int64 col, ossim_int64 id) const |
| void | clampGeographic (ossimDrect &rect) const |
Public Types inherited from ossimTiling | |
| enum | ossimTilingDeltaType { ossimTilingDeltaType_TOTAL_PIXELS, ossimTilingDeltaType_PER_PIXEL } |
Definition at line 20 of file ossimTilingPoly.h.
| ossimTilingPoly::ossimTilingPoly | ( | ) |
Definition at line 29 of file ossimTilingPoly.cpp.
Definition at line 40 of file ossimTilingPoly.cpp.
References m_exteriorCut, m_features, and m_interiorCut.
| ossimRefPtr< ossimGeoPolyCutter > & ossimTilingPoly::getExteriorCut | ( | ) |
Definition at line 356 of file ossimTilingPoly.cpp.
References m_exteriorCut.
Referenced by ossimIgen::outputProduct().
| ossimRefPtr< ossimGeoPolyCutter > & ossimTilingPoly::getInteriorCut | ( | ) |
Definition at line 361 of file ossimTilingPoly.cpp.
References m_interiorCut.
| bool ossimTilingPoly::hasExteriorCut | ( | ) | const |
Definition at line 346 of file ossimTilingPoly.cpp.
References m_exteriorCut, and ossimRefPtr< T >::valid().
| bool ossimTilingPoly::hasInteriorCut | ( | ) | const |
Definition at line 351 of file ossimTilingPoly.cpp.
References m_interiorCut, and ossimRefPtr< T >::valid().
Reimplemented from ossimTilingRect.
Definition at line 47 of file ossimTilingPoly.cpp.
| bool ossimTilingPoly::isFeatureBoundingIntersect | ( | ) | const |
Definition at line 366 of file ossimTilingPoly.cpp.
References m_featureBoundingIntersect.
Definition at line 115 of file ossimTilingPoly.cpp.
References ossimString::contains(), ossimString::empty(), ossimKeywordlist::find(), ossimTilingRect::loadState(), m_bufferDistance, m_shpFilename, m_useMbr, ossimString::substitute(), ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileNameMask, useMbr(), and ossimDpt::x.
Definition at line 68 of file ossimTilingPoly.cpp.
References ossimPolyCutter::getRectangle(), m_exteriorCut, m_features, nextFeature(), ossimString::substitute(), ossimTiling::theMapProjection, ossimTiling::theTileId, ossimTiling::theTileNameMask, and ossimTiling::theTotalTiles.
protected |
Definition at line 146 of file ossimTilingPoly.cpp.
References ossimGeoPolyCutter::addPolygon(), ossimPolyCutter::clear(), ossimRefPtr< T >::get(), ossimGeoPolygon::getHoleList(), m_exteriorCut, m_features, m_interiorCut, ossimGeoAnnotationPolyObject::OSSIM_POLY_INTERIOR_RING, ossimPolyCutter::OSSIM_POLY_NULL_INSIDE, ossimPolyCutter::setCutType(), ossimGeoPolyCutter::setPolygon(), setRect(), ossimGeoPolyCutter::setView(), ossimTiling::theMapProjection, and ossimTiling::theTileId.
Referenced by next().
protected |
Definition at line 246 of file ossimTilingPoly.cpp.
References ossimString::contains(), ossimString::empty(), ossimRefPtr< T >::get(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimEsriShapeFileInterface::getFeatureTable(), ossimImageHandler::getImageGeometry(), ossimMapProjection::getMetersPerPixel(), ossimGeoAnnotationMultiPolyObject::getMultiPolygon(), ossimGeoAnnotationPolyObject::getPoints(), ossimGeoAnnotationPolyObject::getPolyType(), ossimImageGeometry::getProjection(), ossimImageHandlerRegistry::instance(), ossimMapProjection::isGeographic(), m_bufferDistance, m_features, m_shpFilename, m_useMbr, ossimImageHandlerRegistry::open(), OSSIM_DEGREES, OSSIM_METERS, PTR_CAST, ossimEsriShapeFileInterface::setGeometryBuffer(), ossimEsriShapeFileInterface::setQuery(), ossimString::split(), ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTotalTiles, and ossimDpt::x.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 99 of file ossimTilingPoly.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), m_shpFilename, m_useMbr, and ossimTilingRect::saveState().
protected |
Definition at line 215 of file ossimTilingPoly.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimPolyCutter::getRectangle(), ossimIrect::intersects(), ossimIrect::lr(), m_exteriorCut, m_featureBoundingIntersect, m_useMbr, ossimPolyCutter::setRectangle(), ossimTiling::theImageRect, ossimTiling::thePaddingSizeInPixels, ossimIrect::ul(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by nextFeature().
| bool ossimTilingPoly::useMbr | ( | ) | const |
Definition at line 339 of file ossimTilingPoly.cpp.
References m_useMbr.
Referenced by loadState(), and ossimIgen::outputProduct().
protected |
Definition at line 84 of file ossimTilingPoly.h.
Referenced by loadState(), and parseShpFile().
protected |
Definition at line 86 of file ossimTilingPoly.h.
Referenced by getExteriorCut(), hasExteriorCut(), next(), nextFeature(), setRect(), and ~ossimTilingPoly().
protected |
Definition at line 90 of file ossimTilingPoly.h.
Referenced by isFeatureBoundingIntersect(), and setRect().
protected |
Definition at line 89 of file ossimTilingPoly.h.
Referenced by next(), nextFeature(), parseShpFile(), and ~ossimTilingPoly().
protected |
Definition at line 87 of file ossimTilingPoly.h.
Referenced by getInteriorCut(), hasInteriorCut(), nextFeature(), and ~ossimTilingPoly().
protected |
Definition at line 82 of file ossimTilingPoly.h.
Referenced by loadState(), parseShpFile(), and saveState().
protected |
Definition at line 83 of file ossimTilingPoly.h.
Referenced by loadState(), parseShpFile(), saveState(), setRect(), and useMbr().
