#include <ossimTilingRect.h>
| ossimTilingRect () | |
| virtual | ~ossimTilingRect () |
| virtual bool | initialize (const ossimMapProjection &proj, const ossimIrect &boundingRect) |
| virtual bool | next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName) |
Public Member Functions inherited from ossimTiling | |
| ossimTiling () | |
| bool | next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName) const |
| void | reset () |
| void | setTilingDistance (const ossimDpt &tilingDistance, ossimUnitType unitType) |
| void | setDelta (const ossimDpt &delta, ossimTilingDeltaType deltaType) |
| This sets the pixel delta. More... | |
| void | setTileNameMask (const ossimString &mask) |
| This sets the tilename mask. More... | |
| ossimString | getTileNameMask () const |
| bool | getRowCol (ossim_int64 &row, ossim_int64 &col, ossim_int64 tileId) const |
| bool | getOrigin (ossimDpt &origin, ossim_int64 tileId) const |
| bool | getOrigin (ossimDpt &origin, ossim_int64 row, ossim_int64 col) const |
| void | setPaddingSizeInPixels (const ossimIpt &pizelOverlap) |
| ossimDpt | getDeltaPerPixel () const |
| ossimObject () | |
| bool | initializeBase (const ossimMapProjection &proj, const ossimIrect &boundingRect, ossimDpt &convertedTilingDistance) |
| void | getConvertedDistance (ossimDpt &pt, ossimDpt inputDistance) const |
| ossimDpt | getPaddingSize () const |
Protected Member Functions inherited from ossimTiling | |
| void | getConvertedTilingDistance (ossimDpt &pt) const |
| bool | validate () const |
| bool | isAngularUnit (ossimUnitType unitType) const |
| bool | isLinearUnit (ossimUnitType unitType) const |
| void | getTileName (ossimString &resultingName, ossim_int64 row, ossim_int64 col, ossim_int64 id) const |
| void | clampGeographic (ossimDrect &rect) const |
Public Types inherited from ossimTiling | |
| enum | ossimTilingDeltaType { ossimTilingDeltaType_TOTAL_PIXELS, ossimTilingDeltaType_PER_PIXEL } |
Definition at line 22 of file ossimTilingRect.h.
| ossimTilingRect::ossimTilingRect | ( | ) |
Definition at line 29 of file ossimTilingRect.cpp.
Definition at line 43 of file ossimTilingRect.cpp.
protected |
Definition at line 856 of file ossimTilingRect.cpp.
References ossimMapProjection::isGeographic(), ossimMapProjection::origin(), OSSIM_DEGREES, OSSIM_METERS, ossimNotify(), ossimNotifyLevel_WARN, ossimUnitConversionTool::setValue(), ossimTiling::theMapProjection, ossimTiling::theTilingDistanceUnitType, ossimDpt::x, and ossimDpt::y.
Referenced by initializeBase().
protected |
Definition at line 832 of file ossimTilingRect.cpp.
References ossimUnitConversionTool::getValue(), ossimMapProjection::isGeographic(), OSSIM_DEGREES, OSSIM_METERS, ossimUnitConversionTool::setValue(), ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTilingDistanceUnitType, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Reimplemented in ossimTilingPoly.
Definition at line 218 of file ossimTilingRect.cpp.
protected |
Definition at line 47 of file ossimTilingRect.cpp.
References ossimProjection::dup(), ossimRefPtr< T >::get(), getConvertedDistance(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimMapProjection::getMetersPerPixel(), ossimImageGeometry::getMetersPerPixel(), getPaddingSize(), ossimDpt::hasNans(), ossimIrect::height(), ossimMapProjection::isGeographic(), ossimGpt::lat, ossimMapProjection::lineSampleToWorld(), ossimIrect::ll(), ossimGpt::lon, ossimIrect::lr(), m_fractionalPixelMisalignment, m_offsetInPixels, m_tilingDistanceInPixels, m_tilingResolutionUnitType, m_tilinResolutionDistance, m_useOffset, OSSIM_DEGREES, OSSIM_PIXEL, ossimMapProjection::setDecimalDegreesPerPixel(), ossimImageGeometry::setImageSize(), ossimMapProjection::setMetersPerPixel(), ossimTiling::theImageRect, ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTilingDistance, ossimTiling::theTilingDistanceUnitType, ossimIrect::ul(), ossimIrect::ur(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Reimplemented from ossimTiling.
Definition at line 733 of file ossimTilingRect.cpp.
References ossimString::contains(), distance(), ossimKeywordlist::find(), ossimUnitTypeLut::getEntryNumber(), ossimUnitTypeLut::instance(), m_clipToAoi, m_offsetInPixels, m_tilingResolutionUnitType, m_tilinResolutionDistance, m_useOffset, ossimTiling::setTileNameMask(), ossimTiling::theDelta, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileNameMask, ossimTiling::theTilingDistance, ossimTiling::theTilingDistanceUnitType, ossimString::toFloat64(), ossimDpt::x, x, ossimDpt::y, and y.
Referenced by ossimTilingPoly::loadState().
Definition at line 386 of file ossimTilingRect.cpp.
References ossimGpt::datum(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimMapProjection::getMetersPerPixel(), ossimTiling::getOrigin(), ossimTiling::getRowCol(), ossimTiling::getTileName(), ossimIrect::height(), ossimMapProjection::isGeographic(), ossimDpt::isNan(), ossimDpt::lat, ossimDpt::lon, m_clipToAoi, m_fractionalPixelMisalignment, m_lastHeight, m_lastWidth, m_offsetInPixels, m_tilingDistanceInPixels, m_useOffset, ossimMapProjection::origin(), ossimMapProjection::setUlTiePoints(), ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileId, ossimTiling::theTotalHorizontalTiles, ossimTiling::theTotalTiles, ossimTiling::theTotalVerticalTiles, ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 694 of file ossimTilingRect.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimUnitTypeLut::instance(), m_clipToAoi, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileNameMask, ossimTiling::theTilingDistance, ossimTiling::theTilingDistanceUnitType, ossimDpt::x, and ossimDpt::y.
Referenced by ossimTilingPoly::saveState().
protected |
Definition at line 53 of file ossimTilingRect.h.
Referenced by loadState(), next(), and saveState().
protected |
Definition at line 61 of file ossimTilingRect.h.
Referenced by initializeBase(), and next().
protected |
Definition at line 55 of file ossimTilingRect.h.
Referenced by next().
protected |
Definition at line 54 of file ossimTilingRect.h.
protected |
Definition at line 57 of file ossimTilingRect.h.
Referenced by initializeBase(), loadState(), and next().
protected |
Definition at line 58 of file ossimTilingRect.h.
protected |
Definition at line 60 of file ossimTilingRect.h.
Referenced by initializeBase(), and loadState().
protected |
Definition at line 59 of file ossimTilingRect.h.
protected |
Definition at line 56 of file ossimTilingRect.h.
