Factory for OpenJPEG image writer. More...
#include <ossimOpjWriterFactory.h>
| virtual | ~ossimOpjWriterFactory () |
| virtual ossimImageFileWriter * | createWriterFromExtension (const ossimString &fileExtension) const |
| Creates a writer from extension like "jp2". More... | |
| virtual ossimImageFileWriter * | createWriter (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Create that takes a keyword list and prefix. More... | |
| virtual ossimImageFileWriter * | createWriter (const ossimString &typeName) const |
| createWriter that takes a class name (ossimOpjWriter) More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Creates and object given a keyword list. More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| createObject that takes a class name (ossimOpjWriter) More... | |
| virtual void | getExtensions (std::vector< ossimString > &extList) const |
| Adds "jp2" to list. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Adds "ossimOpjWriter" to list. More... | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| Adds "ossim_opj_jp2", "ossim_opj_geojp2", and "ossim_opj_gmljp2" to writer list. More... | |
| virtual void | getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const |
| Adds an ossimOpjJp2Writer instance to writer list. More... | |
| virtual void | getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const |
Public Member Functions inherited from ossimImageWriterFactoryBase | |
| virtual | ~ossimImageWriterFactoryBase () |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimOpjWriterFactory * | instance () |
| static method to return instance (the only one) of this class. More... | |
| ossimOpjWriterFactory () | |
| hidden from use default constructor More... | |
| ossimOpjWriterFactory (const ossimOpjWriterFactory &) | |
| hidden from use copy constructor More... | |
| void | operator= (const ossimOpjWriterFactory &) |
Static Protected Attributes | |
| static ossimOpjWriterFactory * | theInstance = NULL |
| static instance of this class More... | |
Public Types inherited from ossimImageWriterFactoryBase | |
| typedef std::vector< ossimRefPtr< ossimImageFileWriter > > | ImageFileWriterList |
Definition at line 20 of file ossimOpjWriterFactory.h.
virtual destructor
Definition at line 22 of file ossimOpjWriterFactory.cpp.
References theInstance.
protected |
Definition at line 143 of file ossimOpjWriterFactory.cpp.
Referenced by instance().
protected |
| kwl | The keyword list. |
| prefix | the keyword list prefix. |
Implements ossimObjectFactory.
Definition at line 86 of file ossimOpjWriterFactory.cpp.
References createWriter().
| typeName | Should be "ossimOpjReader". |
Definition at line 92 of file ossimOpjWriterFactory.cpp.
Implements ossimImageWriterFactoryBase.
Definition at line 47 of file ossimOpjWriterFactory.cpp.
References ossimKeywordlist::find(), ossimImageFileWriter::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject().
Definition at line 66 of file ossimOpjWriterFactory.cpp.
References ossimImageFileWriter::hasImageType(), and ossimRefPtr< T >::release().
| fileExtension | e.g. "jpg" |
Definition at line 36 of file ossimOpjWriterFactory.cpp.
Adds "jp2" to list.
| extList | List to add to. |
Definition at line 98 of file ossimOpjWriterFactory.cpp.
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 133 of file ossimOpjWriterFactory.cpp.
| result | List to append to. |
| ext | file extension should be either "jp2" or "j2k" |
Definition at line 122 of file ossimOpjWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
| imageTypeList | List to append to. |
Definition at line 110 of file ossimOpjWriterFactory.cpp.
| typeList | List to add to. |
Definition at line 105 of file ossimOpjWriterFactory.cpp.
static |
Definition at line 27 of file ossimOpjWriterFactory.cpp.
References ossimOpjWriterFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
protected |
staticprotected |
Definition at line 115 of file ossimOpjWriterFactory.h.
Referenced by instance(), and ~ossimOpjWriterFactory().
