#include <ossimEllipsoidFactory.h>
| virtual | ~ossimEllipsoidFactory () |
| const ossimEllipsoid * | create (const ossimString &code) const |
| const ossimEllipsoid * | wgs84 () const |
| const ossimEllipsoid * | wgs72 () const |
| ossim_uint32 | findEpsgCode (const ossimString &alpha_code) const |
| Given an alpha code (for example "WE" for WGS84), returns the corresponding EPSG code or 0 if not found. More... | |
| static ossimEllipsoidFactory * | instance () |
Private Types | |
| typedef std::map< std::string, ossimEllipsoid * > | TableType |
| typedef std::map< ossim_uint32, std::string > | EpsgTableType |
Private Member Functions | |
| ossimEllipsoidFactory () | |
| void | initializeTable () |
| void | deleteAll () |
Private Attributes | |
| ossimEllipsoid * | theWgs84Ellipsoid |
| ossimEllipsoid * | theWgs72Ellipsoid |
| TableType | theEllipsoidTable |
| EpsgTableType | theEpsgTable |
Definition at line 25 of file ossimEllipsoidFactory.h.
private |
Definition at line 41 of file ossimEllipsoidFactory.h.
private |
Definition at line 40 of file ossimEllipsoidFactory.h.
private |
Definition at line 36 of file ossimEllipsoidFactory.cpp.
| const ossimEllipsoid * ossimEllipsoidFactory::create | ( | const ossimString & | code | ) | const |
Definition at line 45 of file ossimEllipsoidFactory.cpp.
References ossimString::empty(), ossimNotify(), ossimNotifyLevel_WARN, theEllipsoidTable, theEpsgTable, and ossimString::toUInt32().
Referenced by ossimNgaProjectionFactory::createProjection(), and ossimEllipsoid::loadState().
private |
Definition at line 197 of file ossimEllipsoidFactory.cpp.
References theEllipsoidTable, theEpsgTable, theWgs72Ellipsoid, and theWgs84Ellipsoid.
Referenced by ~ossimEllipsoidFactory().
| ossim_uint32 ossimEllipsoidFactory::findEpsgCode | ( | const ossimString & | alpha_code | ) | const |
Definition at line 226 of file ossimEllipsoidFactory.cpp.
References ossimString::empty(), ossimString::string(), and theEpsgTable.
Referenced by ossimEllipsoid::getEpsgCode(), and ossimEllipsoid::ossimEllipsoid().
private |
Definition at line 79 of file ossimEllipsoidFactory.cpp.
Referenced by instance().
static |
Definition at line 17 of file ossimEllipsoidFactory.cpp.
References initializeTable().
Referenced by ossimNgaProjectionFactory::createProjection(), ossimEllipsoid::getEpsgCode(), ossimEllipsoid::loadState(), ossimDatumFactory::ossimDatumFactory(), ossimEllipsoid::ossimEllipsoid(), ossimWgs72Datum::shiftFromWgs84(), and ossimWgs72Datum::shiftToWgs84().
inline |
Definition at line 31 of file ossimEllipsoidFactory.h.
Referenced by ossimWgs72Datum::shiftFromWgs84(), and ossimWgs72Datum::shiftToWgs84().
inline |
Definition at line 30 of file ossimEllipsoidFactory.h.
Referenced by ossimEllipsoid::loadState(), ossimEllipsoid::ossimEllipsoid(), ossimWgs72Datum::shiftFromWgs84(), and ossimWgs72Datum::shiftToWgs84().
private |
Definition at line 46 of file ossimEllipsoidFactory.h.
Referenced by create(), deleteAll(), and initializeTable().
private |
Definition at line 47 of file ossimEllipsoidFactory.h.
Referenced by create(), deleteAll(), findEpsgCode(), and initializeTable().
private |
Definition at line 45 of file ossimEllipsoidFactory.h.
Referenced by deleteAll(), and initializeTable().
private |
Definition at line 44 of file ossimEllipsoidFactory.h.
