#include <ossimGdalFactory.h>
| virtual | ~ossimGdalFactory () |
| virtual ossimImageHandler * | open (const ossimFilename &fileName, bool openOverview=true) const |
| open that takes a filename. More... | |
| virtual ossimImageHandler * | open (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimRefPtr< ossimImageHandler > | openOverview (const ossimFilename &file) const |
| Open overview that takes a file name. More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| virtual void | getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const |
| virtual void | getImageHandlersBySuffix (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const |
| virtual void | getImageHandlersByMimeType (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const |
Public Member Functions inherited from ossimImageHandlerFactoryBase | |
| virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const |
| Open method that takes a stream. More... | |
| virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::ImageHandlerState > state) const |
| virtual ossimRefPtr< ossimImageHandler > | openOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimGdalFactory * | instance () |
| ossimGdalFactory () | |
| ossimGdalFactory (const ossimGdalFactory &) | |
| void | operator= (const ossimGdalFactory &) |
Static Protected Attributes | |
| static ossimGdalFactory * | theInstance = 0 |
Public Types inherited from ossimImageHandlerFactoryBase | |
| typedef UniqueList< ossimString > | UniqueStringList |
| typedef std::vector< ossimRefPtr< ossimImageHandler > > | ImageHandlerList |
Definition at line 25 of file ossimGdalFactory.h.
Definition at line 32 of file ossimGdalFactory.cpp.
References theInstance.
inlineprotected |
inlineprotected |
Definition at line 75 of file ossimGdalFactory.h.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 218 of file ossimGdalFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createObject().
Creates and object given a keyword list.
Definition at line 236 of file ossimGdalFactory.cpp.
References createObject(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimObject::loadState(), open(), ossimRefPtr< T >::release(), STATIC_TYPE_NAME, ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 332 of file ossimGdalFactory.cpp.
Definition at line 310 of file ossimGdalFactory.cpp.
References ossimString::downcase(), ossimImageHandlerFactoryBase::UniqueList< T >::getList(), getSupportedExtensions(), and ossimString::push_back().
Implements ossimImageHandlerFactoryBase.
Definition at line 273 of file ossimGdalFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back(), and ossimString::split().
Referenced by getImageHandlersBySuffix().
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 266 of file ossimGdalFactory.cpp.
static |
Definition at line 38 of file ossimGdalFactory.cpp.
References ossimGdalFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
| fileName | File to open. |
| trySuffixFirst | If true calls code to try to open by suffix first, then goes through the list of available handlers. default=true. |
| openOverview | If true image handler will attempt to open overview. default = true |
Definition at line 56 of file ossimGdalFactory.cpp.
References ossimString::downcase(), and ossimFilename::ext().
Definition at line 151 of file ossimGdalFactory.cpp.
| file | File to open. |
Definition at line 200 of file ossimGdalFactory.cpp.
References ossimImageHandler::open(), ossimImageHandler::setOpenOverviewFlag(), and ossimString::size().
inlineprotected |
Definition at line 76 of file ossimGdalFactory.h.
staticprotected |
Definition at line 78 of file ossimGdalFactory.h.
Referenced by instance(), and ~ossimGdalFactory().
