This is our default elevation factory in the ossim core. More...
#include <ossimElevationDatabaseFactory.h>
| ossimElevationDatabaseFactory () | |
| ossimElevationDatabase * | createDatabase (const ossimString &typeName) const |
| ossimElevationDatabase * | createDatabase (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimElevationDatabase * | open (const ossimString &connectionString) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimElevationDatabaseFactoryBase | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| Creates an object given a type name. More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Creates and object given a keyword list. More... | |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimElevationDatabaseFactory * | instance () |
Static Protected Attributes | |
| static ossimElevationDatabaseFactory * | m_instance = 0 |
It supports general_raster, general imagery, DTED and SRTM directory layouts.
Example DTED Keywordlist:
Note: only use memory_map_cells to true if they are small files. DTED0 is small so we set it to true. Where the dted file tree has the form: <rootdir>/w056/n49.dt0
Example General Raster directory:
where the directory is a flat directory with general raster files
Example SRTM directory:
where the directory has files of the form N39W112.hgt and are 1x1 degree cells
Example image directory format:
where the directory can have any image the ossim supports and is a flat directory
Definition at line 57 of file ossimElevationDatabaseFactory.h.
inline |
Definition at line 60 of file ossimElevationDatabaseFactory.h.
Referenced by instance().
| typeName | is the type name of the database you wish to create. |
Implements ossimElevationDatabaseFactoryBase.
Definition at line 20 of file ossimElevationDatabaseFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createDatabase().
| kwl | kewyord list that has state information about how to create a database |
| prefix | prefix key to use when loading the state information. |
Definition at line 53 of file ossimElevationDatabaseFactory.cpp.
References createDatabase(), ossimString::empty(), ossimKeywordlist::find(), ossimElevationDatabase::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
| typeList | appends to the typeList all the type names this factory supports |
Implements ossimObjectFactory.
Definition at line 106 of file ossimElevationDatabaseFactory.cpp.
static |
Definition at line 10 of file ossimElevationDatabaseFactory.cpp.
References m_instance, and ossimElevationDatabaseFactory().
Referenced by ossimElevationDatabaseRegistry::instance().
| connectionString | used to determine which database can support that connection. |
Definition at line 73 of file ossimElevationDatabaseFactory.cpp.
References ossimFilename::isFile(), ossimElevationDatabase::open(), and ossimRefPtr< T >::release().
staticprotected |
Definition at line 99 of file ossimElevationDatabaseFactory.h.
