#include <ossimAtpToolFactory.h>
| virtual | ~ossimAtpToolFactory () |
| virtual ossimTool * | createTool (const std::string &typeName) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| virtual void | getCapabilities (std::map< std::string, std::string > &capabilities) const |
| | Appends map with available utilities along with descriptions as <name, decription> pairs. More...
| virtual std::map< std::string, std::string > | getCapabilities () const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimTool * | createTool (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual | ~ossimObjectFactory () |
| | ossimObject () |
| | Generic print method. More...
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
Definition at line 20 of file ossimAtpToolFactory.h.
◆ ~ossimAtpToolFactory()
| ATP::ossimAtpToolFactory::~ossimAtpToolFactory |
◆ ossimAtpToolFactory() [1/2]
| ATP::ossimAtpToolFactory::ossimAtpToolFactory |
protected |
◆ ossimAtpToolFactory() [2/2]
◆ createTool()
| ossimTool * ATP::ossimAtpToolFactory::createTool |
const std::string & |
typeName | ) |
const |
◆ getCapabilities() [1/2]
| void ATP::ossimAtpToolFactory::getCapabilities |
std::map< std::string, std::string > & |
capabilities | ) |
const |
The names are the human-readable name of the utility/service, typically the utility's class name without the "ossim" prefix nor "Util" suffix, all lowercase.
Implements ossimToolFactoryBase.
Definition at line 45 of file ossimAtpToolFactory.cpp.
◆ getCapabilities() [2/2]
| std::map< std::string, std::string > ATP::ossimAtpToolFactory::getCapabilities |
const |
◆ getTypeNameList()
| void ATP::ossimAtpToolFactory::getTypeNameList |
std::vector< ossimString > & |
typeList | ) |
const |
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 57 of file ossimAtpToolFactory.cpp.
59 typeList.push_back(
"ossimAtpTool");
◆ instance()
◆ operator=()
◆ s_instance
