#include <ossimAtpTool.h>
Public Types | |
| enum | Method { METHOD_UNASSIGNED =0, GET_ALGO_LIST, GET_PARAMS, GENERATE } |
| ossimAtpTool () | |
| virtual | ~ossimAtpTool () |
| virtual void | setUsage (ossimArgumentParser &ap) |
| Initializes the aurgument parser with expected parameters and options. More... | |
| virtual bool | initialize (ossimArgumentParser &ap) |
| Initializes from command line arguments. More... | |
| virtual bool | execute () |
| Writes product to output file if applicable. More... | |
| virtual void | getKwlTemplate (ossimKeywordlist &kwl) |
| Assigns a template keywordlist to string for initializing derived classes. More... | |
| virtual void | loadJSON (const Json::Value &json) |
| Reads processing params from JSON object provided. More... | |
| virtual void | saveJSON (Json::Value &json) const |
| Fetch product as JSON object when applicable Always returns true since using exception on error. More... | |
Public Member Functions inherited from ossimTool | |
| ossimTool () | |
| virtual | ~ossimTool () |
| virtual void | initialize (const ossimKeywordlist &kwl) |
| Reads processing params from KWL and prepares for execute. More... | |
| virtual const std::string & | getResponse () const |
| Fetch product as string (typically JSON) when applicable, otherwise passes back empty string. More... | |
| virtual void | clear () |
| Disconnects and clears the DEM and image layers. More... | |
| virtual void | abort () |
| Kills current (asynchronous) process. More... | |
| void | getAPI (std::string &out) const |
| Outputs a JSON representation of the Utility's API. More... | |
| std::string | getAPI () const |
| void | getBuildDate (std::string &s) const |
| Gets build date. More... | |
| void | getRevision (std::string &s) const |
| Gets revision. More... | |
| void | getVersion (std::string &s) const |
| Gets version. More... | |
| virtual bool | isChipProcessor () const |
| Overrides base class implementation to indicate this class supports getChip() calls. More... | |
| void | setOutputStream (std::ostream *os) |
| Redirects any console output to the supplied stream for logging or JNI application. More... | |
| bool | helpRequested () const |
| Returns true when the initialization detects a "--help" option, so caller can avoid subsequent execute() call. More... | |
| ossimObject () | |
Public Member Functions inherited from ossim::JsonInterface | |
| JsonInterface () | |
| virtual | ~JsonInterface () |
Static Public Attributes | |
| static const char * | DESCRIPTION |
Private Member Functions | |
| void | getAlgorithms () |
| void | getParameters () |
| void | generate () |
| void | doPairwiseMatching () |
| When the ATP generator works with image pairs (crosscorr and descriptor), This method is used to loop over all image pairs and assemble the final tiepoint list for all. More... | |
Private Attributes | |
| std::ostream * | m_outputStream |
| bool | m_verbose |
| bool | m_featureBased |
| unsigned int | m_algorithm |
| Method | m_method |
| std::string | m_configuration |
| Json::Value | m_responseJSON |
| std::shared_ptr< ossim::PhotoBlock > | m_photoBlock |
Protected Attributes inherited from ossimTool | |
| ossimKeywordlist | m_kwl |
| std::ostream * | m_consoleStream |
| bool | m_helpRequested |
| std::string | m_response |
Definition at line 20 of file ossimAtpTool.h.
| Enumerator | |
| METHOD_UNASSIGNED | |
| GET_ALGO_LIST | |
| GET_PARAMS | |
| GENERATE | |
Definition at line 23 of file ossimAtpTool.h.
| ATP::ossimAtpTool::ossimAtpTool | ( | ) |
Definition at line 25 of file ossimAtpTool.cpp.
Definition at line 34 of file ossimAtpTool.cpp.
private |
Definition at line 291 of file ossimAtpTool.cpp.
References ossim::JsonParam::asBool(), CINFO, ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), m_algorithm, m_photoBlock, and m_responseJSON.
Referenced by generate().
The product may also beAlways returns true since using exception on error.
Implements ossimTool.
Definition at line 192 of file ossimAtpTool.cpp.
References CFATAL, GENERATE, generate(), GET_ALGO_LIST, GET_PARAMS, getAlgorithms(), getParameters(), m_method, m_outputStream, m_responseJSON, and ossimException::what().
private |
Definition at line 269 of file ossimAtpTool.cpp.
References ATP::AtpGenerator::ALGO_UNASSIGNED, ATP::AtpGenerator::CROSSCORR, ATP::AtpGenerator::DESCRIPTOR, doPairwiseMatching(), m_algorithm, and ATP::AtpGenerator::NASA.
Referenced by execute().
private |
Definition at line 240 of file ossimAtpTool.cpp.
References m_responseJSON.
inlinevirtual |
Reimplemented from ossimTool.
Definition at line 37 of file ossimAtpTool.h.
Definition at line 236 of file ossimAtpTool.cpp.
private |
Definition at line 258 of file ossimAtpTool.cpp.
References ATP::AtpConfig::instance(), m_responseJSON, and ossim::JsonConfig::saveJSON().
This base class has some common arguments to read. The derived class should call this implementation in addition to setting its own arguments.
| ap | Represents command line. |
Definition at line 65 of file ossimAtpTool.cpp.
References CFATAL, GENERATE, GET_ALGO_LIST, GET_PARAMS, ossimTool::initialize(), loadJSON(), ossimTool::m_helpRequested, m_method, m_outputStream, m_verbose, and ossimArgumentParser::read().
If all good, the object is ready for subsequent call to execute().
Definition at line 122 of file ossimAtpTool.cpp.
References ATP::AtpGenerator::ALGO_UNASSIGNED, ossim::JsonParam::asString(), CINFO, ATP::AtpGenerator::CROSSCORR, ATP::AtpGenerator::DESCRIPTOR, ossim::JsonConfig::diagnosticLevel(), GENERATE, GET_ALGO_LIST, GET_PARAMS, ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), ossim::JsonConfig::loadJSON(), m_algorithm, m_configuration, m_method, m_photoBlock, ATP::AtpGenerator::NASA, and ATP::AtpConfig::readConfig().
Referenced by initialize().
inlinevirtual |
| json | Returns non-empty object if valid response available. |
Definition at line 43 of file ossimAtpTool.h.
It does not output anything. To see the usage, the caller will need to do something like:
ap.getApplicationUsage()->write(<ostream>);
This base class has some common arguments to add. The derived class should call this implementation in addition to setting its own arguments.
Definition at line 38 of file ossimAtpTool.cpp.
References ossimApplicationUsage::addCommandLineOption(), ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimApplicationUsage::setCommandLineUsage(), and ossimTool::setUsage().
static |
Definition at line 25 of file ossimAtpTool.h.
private |
Definition at line 58 of file ossimAtpTool.h.
Referenced by doPairwiseMatching(), generate(), and loadJSON().
private |
Definition at line 60 of file ossimAtpTool.h.
Referenced by loadJSON().
private |
Definition at line 57 of file ossimAtpTool.h.
private |
Definition at line 59 of file ossimAtpTool.h.
Referenced by execute(), initialize(), and loadJSON().
private |
Definition at line 55 of file ossimAtpTool.h.
Referenced by execute(), and initialize().
private |
Definition at line 62 of file ossimAtpTool.h.
Referenced by doPairwiseMatching(), and loadJSON().
private |
Definition at line 61 of file ossimAtpTool.h.
Referenced by doPairwiseMatching(), execute(), getAlgorithms(), and getParameters().
private |
Definition at line 56 of file ossimAtpTool.h.
