Factory for SQLITE image writer. More...
#include <ossimSqliteWriterFactory.h>
| virtual | ~ossimSqliteWriterFactory () |
| virtual ossimImageFileWriter * | createWriterFromExtension (const ossimString &fileExtension) const |
| Creates a writer from extension like "sqlite". More... | |
| virtual ossimImageFileWriter * | createWriter (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Create that takes a keyword list and prefix. More... | |
| virtual ossimImageFileWriter * | createWriter (const ossimString &typeName) const |
| createWriter that takes a class name (ossimSqliteWriter) More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Creates and object given a keyword list. More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| createObject that takes a class name (ossimSqliteWriter) More... | |
| virtual void | getExtensions (std::vector< ossimString > &extList) const |
| Adds "sqlite" to list. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Adds "ossimSqliteWriter" to list. More... | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| Adds "ossim_sqlite" to writer list. More... | |
| virtual void | getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const |
| virtual void | getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const |
Public Member Functions inherited from ossimImageWriterFactoryBase | |
| virtual | ~ossimImageWriterFactoryBase () |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimSqliteWriterFactory * | instance () |
| static method to return instance (the only one) of this class. More... | |
| ossimSqliteWriterFactory () | |
| hidden from use default constructor More... | |
| ossimSqliteWriterFactory (const ossimSqliteWriterFactory &) | |
| hidden from use copy constructor More... | |
| void | operator= (const ossimSqliteWriterFactory &) |
Static Protected Attributes | |
| static ossimSqliteWriterFactory * | theInstance = 0 |
| static instance of this class More... | |
Public Types inherited from ossimImageWriterFactoryBase | |
| typedef std::vector< ossimRefPtr< ossimImageFileWriter > > | ImageFileWriterList |
Definition at line 20 of file ossimSqliteWriterFactory.h.
virtual destructor
Definition at line 23 of file ossimSqliteWriterFactory.cpp.
References theInstance.
protected |
Definition at line 138 of file ossimSqliteWriterFactory.cpp.
Referenced by instance().
protected |
Definition at line 140 of file ossimSqliteWriterFactory.cpp.
| kwl | The keyword list. |
| prefix | the keyword list prefix. |
Implements ossimObjectFactory.
Definition at line 88 of file ossimSqliteWriterFactory.cpp.
References createWriter().
| typeName | Should be "ossimSqliteReader". |
Definition at line 94 of file ossimSqliteWriterFactory.cpp.
Implements ossimImageWriterFactoryBase.
Definition at line 49 of file ossimSqliteWriterFactory.cpp.
References ossimKeywordlist::find(), ossimImageFileWriter::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject().
Definition at line 68 of file ossimSqliteWriterFactory.cpp.
References ossimImageFileWriter::hasImageType(), and ossimRefPtr< T >::release().
| fileExtension | "sqlite" |
Definition at line 37 of file ossimSqliteWriterFactory.cpp.
References ossimRefPtr< T >::release().
| extList | List to add to. |
Definition at line 100 of file ossimSqliteWriterFactory.cpp.
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 128 of file ossimSqliteWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
Definition at line 118 of file ossimSqliteWriterFactory.cpp.
| imageTypeList | List to append to. |
Definition at line 111 of file ossimSqliteWriterFactory.cpp.
References ossimGpkgWriter::getImageTypeList().
| typeList | List to add to. |
Definition at line 106 of file ossimSqliteWriterFactory.cpp.
static |
Definition at line 28 of file ossimSqliteWriterFactory.cpp.
References ossimSqliteWriterFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
protected |
Definition at line 142 of file ossimSqliteWriterFactory.cpp.
staticprotected |
Definition at line 107 of file ossimSqliteWriterFactory.h.
Referenced by instance(), and ~ossimSqliteWriterFactory().
