#include <ossimProjectionViewControllerFactory.h>
| virtual ossimViewController * | createViewController (const ossimString &name) const |
| virtual ossimViewController * | createViewController (const ossimKeywordlist &kwl, const char *prefix) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimProjectionViewControllerFactory * | instance () |
| ossimProjectionViewControllerFactory () | |
| ossimProjectionViewControllerFactory (const ossimProjectionViewControllerFactory &) | |
Static Protected Attributes | |
| static ossimProjectionViewControllerFactory * | theInstance = NULL |
Definition at line 17 of file ossimProjectionViewControllerFactory.h.
inlineprotected |
Definition at line 33 of file ossimProjectionViewControllerFactory.h.
Referenced by instance().
inlineprotected |
Definition at line 34 of file ossimProjectionViewControllerFactory.h.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 62 of file ossimProjectionViewControllerFactory.cpp.
References createViewController().
Creates and object given a keyword list.
Definition at line 67 of file ossimProjectionViewControllerFactory.cpp.
Definition at line 31 of file ossimProjectionViewControllerFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createObject(), and createViewController().
Definition at line 41 of file ossimProjectionViewControllerFactory.cpp.
References createViewController(), ossimKeywordlist::find(), ossimSource::loadState(), and ossimKeywordNames::TYPE_KW.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 73 of file ossimProjectionViewControllerFactory.cpp.
static |
Definition at line 21 of file ossimProjectionViewControllerFactory.cpp.
References ossimProjectionViewControllerFactory(), and theInstance.
Referenced by ossimInit::initializeDefaultFactories().
staticprotected |
Definition at line 36 of file ossimProjectionViewControllerFactory.h.
