Factory for PNG image reader. More...
#include <ossimPdalReaderFactory.h>
| virtual | ~ossimPdalReaderFactory () |
| virtual ossimPdalReader * | open (const ossimFilename &fileName) const |
| virtual ossimPdalReader * | open (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| virtual void | getSupportedExtensions (std::vector< ossimString > &extList) const |
Public Member Functions inherited from ossimPointCloudHandlerFactory | |
| virtual | ~ossimPointCloudHandlerFactory () |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimPdalReaderFactory * | instance () |
| ossimPdalReaderFactory () | |
| hidden from use default constructor More... | |
| ossimPdalReaderFactory (const ossimPdalReaderFactory &) | |
| hidden from use copy constructor More... | |
| void | operator= (const ossimPdalReaderFactory &) |
Static Protected Attributes | |
| static ossimPdalReaderFactory * | m_instance = 0 |
| static instance of this class More... | |
Definition at line 22 of file ossimPdalReaderFactory.h.
virtual destructor
Definition at line 19 of file ossimPdalReaderFactory.cpp.
References m_instance.
protected |
Definition at line 94 of file ossimPdalReaderFactory.cpp.
Referenced by instance().
protected |
Definition at line 98 of file ossimPdalReaderFactory.cpp.
Creates an object given a type name.
Implements ossimPointCloudHandlerFactory.
Definition at line 61 of file ossimPdalReaderFactory.cpp.
References ossimRefPtr< T >::release().
Creates and object given a keyword list.
Reimplemented from ossimPointCloudHandlerFactory.
Definition at line 75 of file ossimPdalReaderFactory.cpp.
References open().
Definition at line 87 of file ossimPdalReaderFactory.cpp.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 81 of file ossimPdalReaderFactory.cpp.
Referenced by ossimSharedLibraryInitialize().
static |
Definition at line 24 of file ossimPdalReaderFactory.cpp.
References m_instance, and ossimPdalReaderFactory().
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
Definition at line 33 of file ossimPdalReaderFactory.cpp.
References ossimPointCloudHandler::open(), and ossimRefPtr< T >::release().
Referenced by createObject().
Definition at line 47 of file ossimPdalReaderFactory.cpp.
References ossimSource::loadState(), and ossimRefPtr< T >::release().
protected |
Definition at line 102 of file ossimPdalReaderFactory.cpp.
staticprotected |
Definition at line 54 of file ossimPdalReaderFactory.h.
Referenced by instance(), and ~ossimPdalReaderFactory().
