#include <ossimImageReconstructionFilterRegistry.h>
| virtual ossimObject * | createObject (const ossimString &name) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| void | registerFactory (ossimImageSourceFactoryBase *factory) |
| void | unregisterFactory (ossimImageSourceFactoryBase *factory) |
| bool | findFactory (ossimImageSourceFactoryBase *factory) const |
Public Member Functions inherited from ossimImageSourceFactoryBase | |
| virtual ossimImageSource * | createImageSource (const ossimString &name) const |
| virtual ossimImageSource * | createImageSource (const ossimKeywordlist &kwl, const char *prefix=0) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimImageReconstructionFilterRegistry * | instance () |
| virtual | ~ossimImageReconstructionFilterRegistry () |
| ossimImageReconstructionFilterRegistry () | |
| ossimImageReconstructionFilterRegistry (const ossimImageReconstructionFilterRegistry &) | |
| void | operator= (ossimImageReconstructionFilterRegistry &) |
Protected Member Functions inherited from ossimImageSourceFactoryBase | |
| ossimImageSourceFactoryBase () | |
| ossimImageSourceFactoryBase (const ossimImageSourceFactoryBase &) | |
| const ossimImageSourceFactoryBase & | operator= (const ossimImageSourceFactoryBase &) |
Protected Attributes | |
| std::vector< ossimImageSourceFactoryBase * > | theFactoryList |
Static Protected Attributes | |
| static ossimImageReconstructionFilterRegistry * | theInstance = 0 |
Definition at line 13 of file ossimImageReconstructionFilterRegistry.h.
protectedvirtual |
Definition at line 25 of file ossimImageReconstructionFilterRegistry.cpp.
References theInstance.
protected |
Definition at line 20 of file ossimImageReconstructionFilterRegistry.cpp.
Referenced by instance().
inlineprotected |
Definition at line 29 of file ossimImageReconstructionFilterRegistry.h.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 40 of file ossimImageReconstructionFilterRegistry.cpp.
References theFactoryList.
Creates and object given a keyword list.
Definition at line 55 of file ossimImageReconstructionFilterRegistry.cpp.
| bool ossimImageReconstructionFilterRegistry::findFactory | ( | ossimImageSourceFactoryBase * | factory | ) | const |
Definition at line 110 of file ossimImageReconstructionFilterRegistry.cpp.
Referenced by registerFactory().
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 72 of file ossimImageReconstructionFilterRegistry.cpp.
static |
Definition at line 30 of file ossimImageReconstructionFilterRegistry.cpp.
References ossimImageReconstructionFilterFactory::instance(), ossimImageReconstructionFilterRegistry(), registerFactory(), and theInstance.
Referenced by ossimImageSourceFactoryRegistry::instance().
inlineprotected |
Definition at line 30 of file ossimImageReconstructionFilterRegistry.h.
| void ossimImageReconstructionFilterRegistry::registerFactory | ( | ossimImageSourceFactoryBase * | factory | ) |
Definition at line 91 of file ossimImageReconstructionFilterRegistry.cpp.
References findFactory(), and theFactoryList.
| void ossimImageReconstructionFilterRegistry::unregisterFactory | ( | ossimImageSourceFactoryBase * | factory | ) |
Definition at line 99 of file ossimImageReconstructionFilterRegistry.cpp.
protected |
Definition at line 33 of file ossimImageReconstructionFilterRegistry.h.
Referenced by createObject(), findFactory(), getTypeNameList(), registerFactory(), and unregisterFactory().
staticprotected |
Definition at line 32 of file ossimImageReconstructionFilterRegistry.h.
Referenced by instance(), ossimImageReconstructionFilterRegistry(), and ~ossimImageReconstructionFilterRegistry().
