#include <ossimImageReconstructionFilterFactory.h>
| virtual | ~ossimImageReconstructionFilterFactory () |
| virtual ossimObject * | createObject (const ossimString &name) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimImageSourceFactoryBase | |
| virtual ossimImageSource * | createImageSource (const ossimString &name) const |
| virtual ossimImageSource * | createImageSource (const ossimKeywordlist &kwl, const char *prefix=0) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimImageReconstructionFilterFactory * | instance () |
| ossimImageReconstructionFilterFactory () | |
| ossimImageReconstructionFilterFactory (const ossimImageReconstructionFilterFactory &) | |
| void | operator= (ossimImageReconstructionFilterFactory &) |
Protected Member Functions inherited from ossimImageSourceFactoryBase | |
| ossimImageSourceFactoryBase () | |
| ossimImageSourceFactoryBase (const ossimImageSourceFactoryBase &) | |
| const ossimImageSourceFactoryBase & | operator= (const ossimImageSourceFactoryBase &) |
Static Protected Attributes | |
| static ossimImageReconstructionFilterFactory * | theInstance = 0 |
Definition at line 13 of file ossimImageReconstructionFilterFactory.h.
Definition at line 18 of file ossimImageReconstructionFilterFactory.cpp.
References theInstance.
protected |
Definition at line 33 of file ossimImageReconstructionFilterFactory.cpp.
Referenced by instance().
inlineprotected |
Definition at line 26 of file ossimImageReconstructionFilterFactory.h.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 38 of file ossimImageReconstructionFilterFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createObject().
Creates and object given a keyword list.
Definition at line 48 of file ossimImageReconstructionFilterFactory.cpp.
References createObject(), ossimKeywordlist::find(), ossimObject::loadState(), and ossimKeywordNames::TYPE_KW.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 69 of file ossimImageReconstructionFilterFactory.cpp.
static |
Definition at line 23 of file ossimImageReconstructionFilterFactory.cpp.
References ossimImageReconstructionFilterFactory(), and theInstance.
Referenced by ossimImageReconstructionFilterRegistry::instance().
inlineprotected |
Definition at line 27 of file ossimImageReconstructionFilterFactory.h.
staticprotected |
Definition at line 29 of file ossimImageReconstructionFilterFactory.h.
Referenced by instance(), ossimImageReconstructionFilterFactory(), and ~ossimImageReconstructionFilterFactory().
