#include <ossimGeographicAnnotationGrid.h>
| ossimGeographicAnnotationGrid () | |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual void | setViewProjectionInformation (ossimMapProjection *projection, const ossimGrect &boundingGroundRect) |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual void | computeBoundingRect () |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (double x, double y)=0 |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual bool | intersects (const ossimDrect &rect) const =0 |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const =0 |
| virtual ossimDrect | getBoundingRect () const |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual void | setThickness (ossim_uint8 thickness) |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
| Saves the current state of this object. More... | |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
Protected Attributes | |
| ossimRefPtr< ossimMapProjection > | theViewProjection |
| ossimGrect | theGroundRect |
| ossimDrect | theBoundingRect |
| double | theDeltaLatSpacing |
| double | theDeltaLonSpacing |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
Definition at line 10 of file ossimGeographicAnnotationGrid.h.
| ossimGeographicAnnotationGrid::ossimGeographicAnnotationGrid | ( | ) |
Definition at line 13 of file ossimGeographicAnnotationGrid.cpp.
Implements ossimAnnotationObject.
Definition at line 236 of file ossimGeographicAnnotationGrid.cpp.
References ossimAnnotationGdBitmapFont::getBoundingRect(), ossimDrect::height(), ossimGrect::ll(), ossimGrect::lr(), ossimDrect::lr(), ossimAnnotationGdBitmapFont::setCenterText(), theBoundingRect, theGroundRect, theViewProjection, ossimGrect::ul(), ossimDrect::ul(), ossimGrect::ur(), ossimRefPtr< T >::valid(), ossimDrect::width(), ossimMapProjection::worldToLineSample(), ossimDpt::x, and ossimDpt::y.
Definition at line 22 of file ossimGeographicAnnotationGrid.cpp.
References ossimGpt::datum(), DBL_EPSILON, ossimAnnotationGdBitmapFont::draw(), ossimAnnotationLineObject::draw(), ossimAnnotationGdBitmapFont::getBoundingRect(), ossimRgbImage::getImageData(), ossimGrect::height(), ossimDrect::height(), ossimGpt::latd(), ossimGpt::lond(), ossimGrect::lr(), ossimAnnotationGdBitmapFont::setCenterText(), ossimAnnotationGdBitmapFont::setCenterTextPosition(), ossimRgbImage::setDrawColor(), ossimAnnotationLineObject::setLine(), ossimAnnotationGdBitmapFont::setText(), ossimAnnotationObject::theBlue, theDeltaLatSpacing, theDeltaLonSpacing, ossimAnnotationObject::theGreen, theGroundRect, ossimAnnotationObject::theRed, theViewProjection, ossimGrect::ul(), ossimGrect::ur(), ossimRefPtr< T >::valid(), ossimGrect::width(), ossimDrect::width(), ossimMapProjection::worldToLineSample(), ossimDpt::x, and ossimDpt::y.
Definition at line 231 of file ossimGeographicAnnotationGrid.cpp.
References theBoundingRect.
Generic print method.
Derived classes should re-implement as they see fit.
Reimplemented from ossimAnnotationObject.
Definition at line 279 of file ossimGeographicAnnotationGrid.cpp.
We need to know what projection the view and we need to know the bounding rect for the view in geographic space. The bounding rect is there for an area of interest.
Definition at line 164 of file ossimGeographicAnnotationGrid.cpp.
References ossimGrect::clipToRect(), ossimGpt::datum(), ossimGpt::latd(), ossimGpt::lond(), ossimGrect::lr(), theDeltaLatSpacing, theDeltaLonSpacing, theGroundRect, theViewProjection, and ossimGrect::ul().
protected |
This will be computed based on the bounding ground and projection.
Definition at line 42 of file ossimGeographicAnnotationGrid.h.
Referenced by computeBoundingRect(), and getBoundingRect().
protected |
Will hold the spacing of the grid cells in geographic lat lon change.
Definition at line 48 of file ossimGeographicAnnotationGrid.h.
Referenced by draw(), and setViewProjectionInformation().
protected |
Definition at line 49 of file ossimGeographicAnnotationGrid.h.
protected |
Definition at line 36 of file ossimGeographicAnnotationGrid.h.
Referenced by computeBoundingRect(), draw(), and setViewProjectionInformation().
protected |
Holds the view projection.
Definition at line 34 of file ossimGeographicAnnotationGrid.h.
