#include <ossimAnnotationGdBitmapFont.h>
| ossimAnnotationGdBitmapFont (const ossimDpt &position=ossimDpt(0, 0), const ossimString &text=ossimString(""), ossimGdFontPtr font=ossimGdFontLarge, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimAnnotationGdBitmapFont (const ossimAnnotationGdBitmapFont &rhs) | |
| virtual void | applyScale (double x, double y) |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual bool | intersects (const ossimDrect &rect) const |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual void | computeBoundingRect () |
| virtual void | setFont (ossimGdFontPtr font) |
| virtual void | setText (const ossimString &text) |
| virtual void | setCenterText (const ossimDpt ¢er, const ossimString &text) |
| virtual void | setUpperLeftText (const ossimDpt &upperLeft, const ossimString &text) |
| virtual void | setCenterTextPosition (const ossimDpt &position) |
| virtual void | setUpperLeftTextPosition (const ossimDpt &position) |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual ossimDrect | getBoundingRect () const |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual void | setThickness (ossim_uint8 thickness) |
| Saves the current state of this object. More... | |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
| virtual | ~ossimAnnotationGdBitmapFont () |
Protected Attributes | |
| ossimGdFontPtr | theFontPtr |
| ossimString | theText |
| ossimDrect | theBoundingRect |
| ossimDpt | thePosition |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
This is a class that will have hardcoded bitmap fonts. These fonts will be from the gd library.
Definition at line 22 of file ossimAnnotationGdBitmapFont.h.
| ossimAnnotationGdBitmapFont::ossimAnnotationGdBitmapFont | ( | const ossimDpt & | position = ossimDpt(0,0), |
| const ossimString & | text = ossimString(""), |
| ossimGdFontPtr | font = ossimGdFontLarge, |
| unsigned char | r = 255, |
| unsigned char | g = 255, |
| unsigned char | b = 255, |
| long | thickness = 1 |
Definition at line 20 of file ossimAnnotationGdBitmapFont.cpp.
References computeBoundingRect().
| ossimAnnotationGdBitmapFont::ossimAnnotationGdBitmapFont | ( | const ossimAnnotationGdBitmapFont & | rhs | ) |
Definition at line 35 of file ossimAnnotationGdBitmapFont.cpp.
protectedvirtual |
Definition at line 44 of file ossimAnnotationGdBitmapFont.cpp.
Implements ossimAnnotationObject.
Definition at line 53 of file ossimAnnotationGdBitmapFont.cpp.
References theBoundingRect, thePosition, ossimDpt::x, x, ossimDpt::y, and y.
Referenced by ossimGeoAnnotationGdBitmapFont::applyScale().
will compute the bounding rectangle.
Definition at line 131 of file ossimAnnotationGdBitmapFont.cpp.
References ossimGdFont::h, ossimString::size(), theBoundingRect, theFontPtr, thePosition, theText, ossimGdFont::w, ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeoAnnotationGdBitmapFont::computeBoundingRect(), ossimAnnotationGdBitmapFont(), setCenterTextPosition(), setText(), and setUpperLeftTextPosition().
Will draw the bitmap to the screen.
Definition at line 61 of file ossimAnnotationGdBitmapFont.cpp.
References ossimGdFont::data, ossimRgbImage::getImageData(), ossimImageData::getImageRectangle(), ossimImageData::getOrigin(), ossimGdFont::h, ossimDrect::intersects(), ossimRgbImage::setDrawColor(), ossimString::size(), ossimRgbImage::slowPlotPixel(), ossimAnnotationObject::theBlue, theBoundingRect, theFontPtr, ossimAnnotationObject::theGreen, thePosition, ossimAnnotationObject::theRed, theText, ossimGdFont::w, ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeographicAnnotationGrid::draw(), and ossimGeoAnnotationGdBitmapFont::draw().
inlinevirtual |
Definition at line 34 of file ossimAnnotationGdBitmapFont.h.
Referenced by getNewClippedObject().
Will retrieve the bound rectangle for this object.
Definition at line 48 of file ossimAnnotationGdBitmapFont.cpp.
References theBoundingRect.
Referenced by ossimGeographicAnnotationGrid::computeBoundingRect(), ossimGeographicAnnotationGrid::draw(), and ossimGeoAnnotationGdBitmapFont::getBoundingRect().
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 111 of file ossimAnnotationGdBitmapFont.cpp.
References dup(), and intersects().
Referenced by ossimGeoAnnotationGdBitmapFont::getNewClippedObject().
inlinevirtual |
Definition at line 45 of file ossimAnnotationGdBitmapFont.h.
References ossimDrect::intersects().
Referenced by getNewClippedObject(), and ossimGeoAnnotationGdBitmapFont::intersects().
Will determine if the point is within the font
Reimplemented from ossimAnnotationObject.
Definition at line 180 of file ossimAnnotationGdBitmapFont.cpp.
References ossimDrect::pointWithin(), and theBoundingRect.
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 123 of file ossimAnnotationGdBitmapFont.cpp.
References theBoundingRect, thePosition, and theText.
Referenced by ossimGeoAnnotationGdBitmapFont::print().
Set's the text string to render. This will assume that the x,y passed in is suppose to be the center. We will compute the upper left corner from this
Definition at line 166 of file ossimAnnotationGdBitmapFont.cpp.
References setCenterTextPosition(), and setText().
Referenced by ossimGeographicAnnotationGrid::computeBoundingRect(), and ossimGeographicAnnotationGrid::draw().
Sets the center position of the string. will use this value to compute the actual origin of upper left corner of the first character. Make sure you have the text set before you call this method
Definition at line 173 of file ossimAnnotationGdBitmapFont.cpp.
References computeBoundingRect(), ossimDrect::height(), theBoundingRect, thePosition, ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeographicAnnotationGrid::draw(), and setCenterText().
Sets the current bitmap font to use.
Definition at line 142 of file ossimAnnotationGdBitmapFont.cpp.
References theFontPtr.
Referenced by ossimGeoAnnotationGdBitmapFont::setFont().
Definition at line 147 of file ossimAnnotationGdBitmapFont.cpp.
References computeBoundingRect(), and theText.
Referenced by ossimGeographicAnnotationGrid::draw(), setCenterText(), ossimGeoAnnotationGdBitmapFont::setText(), and setUpperLeftText().
Set's the text string to render. This will assume that the x,y passed in is suppose to be the upper left.
Definition at line 153 of file ossimAnnotationGdBitmapFont.cpp.
References setText(), and setUpperLeftTextPosition().
The actual upper left corner of the character.
Definition at line 160 of file ossimAnnotationGdBitmapFont.cpp.
References computeBoundingRect(), and thePosition.
Referenced by setUpperLeftText(), and ossimGeoAnnotationGdBitmapFont::transform().
protected |
Definition at line 114 of file ossimAnnotationGdBitmapFont.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getBoundingRect(), isPointWithin(), print(), and setCenterTextPosition().
protected |
Definition at line 112 of file ossimAnnotationGdBitmapFont.h.
Referenced by computeBoundingRect(), draw(), and setFont().
protected |
This position is suppose to be the upperleft corner of the first character in the string
Definition at line 120 of file ossimAnnotationGdBitmapFont.h.
Referenced by applyScale(), computeBoundingRect(), draw(), print(), setCenterTextPosition(), and setUpperLeftTextPosition().
protected |
Definition at line 113 of file ossimAnnotationGdBitmapFont.h.
Referenced by computeBoundingRect(), draw(), print(), and setText().
