#include <ossimWgs84Datum.h>
| ossimWgs84Datum () | |
| virtual | ~ossimWgs84Datum () |
| virtual ossimGpt | shift (const ossimGpt &aPt) const |
| virtual ossimGpt | shiftToWgs84 (const ossimGpt &aPt) const |
| virtual ossimGpt | shiftFromWgs84 (const ossimGpt &aPt) const |
Public Member Functions inherited from ossimThreeParamDatum | |
| ossimThreeParamDatum (const ossimString &code, const ossimString &name, const ossimEllipsoid *anEllipsoid, ossim_float64 sigmaX, ossim_float64 sigmaY, ossim_float64 sigmaZ, ossim_float64 westLongitude, ossim_float64 eastLongitude, ossim_float64 southLatitude, ossim_float64 northLatitude, ossim_float64 param1, ossim_float64 param2, ossim_float64 param3) | |
| virtual | ~ossimThreeParamDatum () |
| virtual ossim_float64 | param1 () const |
| virtual ossim_float64 | param2 () const |
| virtual ossim_float64 | param3 () const |
| virtual ossim_float64 | param4 () const |
| virtual ossim_float64 | param5 () const |
| virtual ossim_float64 | param6 () const |
| virtual ossim_float64 | param7 () const |
Public Member Functions inherited from ossimDatum | |
| ossimDatum (const ossimString &alpha_code, const ossimString &name, const ossimEllipsoid *anEllipsoid, ossim_float64 sigmaX, ossim_float64 sigmaY, ossim_float64 sigmaZ, ossim_float64 westLongitude, ossim_float64 eastLongitude, ossim_float64 southLatitude, ossim_float64 northLatitude) | |
| virtual bool | isTheSameAs (const ossimDatum *aDatum) const |
| virtual const ossimString & | code () const |
| virtual const ossimString & | name () const |
| virtual ossim_uint32 | epsgCode () const |
| virtual const ossimEllipsoid * | ellipsoid () const |
| virtual ossim_float64 | sigmaX () const |
| virtual ossim_float64 | sigmaY () const |
| virtual ossim_float64 | sigmaZ () const |
| virtual ossim_float64 | westLongitude () const |
| virtual ossim_float64 | eastLongitude () const |
| virtual ossim_float64 | southLatitude () const |
| virtual ossim_float64 | northLatitude () const |
| virtual bool | isInside (ossim_float64 latitude, ossim_float64 longitude) const |
| bool | operator== (const ossimDatum &rhs) const |
| bool | operator!= (const ossimDatum &rhs) const |
| ossimObject () | |
Protected Attributes | |
| TYPE_DATA | |
Protected Attributes inherited from ossimThreeParamDatum | |
| ossim_float64 | theParam1 |
| ossim_float64 | theParam2 |
| ossim_float64 | theParam3 |
| TYPE_DATA | |
Protected Attributes inherited from ossimDatum | |
| ossimString | theCode |
| ossim_uint32 | theEpsgCode |
| ossimString | theName |
| const ossimEllipsoid * | theEllipsoid |
| ossim_float64 | theSigmaX |
| ossim_float64 | theSigmaY |
| ossim_float64 | theSigmaZ |
| ossim_float64 | theWestLongitude |
| ossim_float64 | theEastLongitude |
| ossim_float64 | theSouthLatitude |
| ossim_float64 | theNorthLatitude |
| TYPE_DATA | |
Protected Member Functions inherited from ossimDatum | |
| virtual | ~ossimDatum () |
| Only friend ossimDatumFactory is permitted to delete. More... | |
| virtual void | molodenskyShift (double a, double da, double f, double df, double dx, double dy, double dz, double Lat_in, double Lon_in, double Hgt_in, double &Lat_out, double &Lon_out, double &Hgt_out) const |
| bool | withinMolodenskyRange (const ossimGpt &pt) const |
Definition at line 19 of file ossimWgs84Datum.h.
| ossimWgs84Datum::ossimWgs84Datum | ( | ) |
Definition at line 23 of file ossimWgs84Datum.cpp.
References ossimDatum::ellipsoid().
inlinevirtual |
Definition at line 23 of file ossimWgs84Datum.h.
Will shift a ground point to this datum. If they are the same datum then nothing happens.
Reimplemented from ossimThreeParamDatum.
Definition at line 38 of file ossimWgs84Datum.cpp.
References ossimDatum::code(), ossimGpt::datum(), ossimGpt::height(), ossimGpt::latd(), ossimGpt::lond(), and ossimDatum::shiftToWgs84().
Definition at line 63 of file ossimWgs84Datum.cpp.
Definition at line 55 of file ossimWgs84Datum.cpp.
References ossimGpt::height(), ossimDatumFactory::instance(), ossimGpt::latd(), ossimGpt::lond(), and ossimDatumFactory::wgs84().
protected |
Definition at line 32 of file ossimWgs84Datum.h.
