#include <ossimAffineTransform.h>
| ossimAffineTransform () | |
| ossimAffineTransform (const ossimAffineTransform &src) | |
| virtual const ossimAffineTransform & | operator= (const ossimAffineTransform &rhs) |
| assignment operator= More... | |
| virtual void | forward (const ossimDpt &input, ossimDpt &output) const |
| virtual void | inverse (const ossimDpt &input, ossimDpt &output) const |
| virtual ossimDpt | getOrigin () const |
| bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
| bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setScale (const ossimDpt &scale) |
| void | setRotation (double rotation) |
| void | setTranslation (const ossimDpt &translation) |
| ossimDpt | getScale () const |
| ossimDpt | getTranslation () const |
| double | getRotation () const |
| void | setIdentity () |
| void | setAffineEnabledFlag (bool flag) |
Public Member Functions inherited from ossim2dTo2dTransform | |
| virtual void | forward (ossimDpt &modify_this) const |
| virtual void | inverse (ossimDpt &modify_this) const |
| virtual const ossim2dTo2dTransform & | operator= (const ossim2dTo2dTransform &rhs) |
| void | setConvergenceThreshold (const double &new_threshold) |
| void | setMaxIterations (int new_max_iters) |
| void | setDxDy (const ossimDpt &dxdy) |
| ossimObject () | |
| void | computeMatrix () |
Protected Member Functions inherited from ossim2dTo2dTransform | |
| ossim2dTo2dTransform () | |
| virtual | ~ossim2dTo2dTransform () |
Protected Attributes | |
| ossimDpt | theScale |
| double | theRotation |
| ossimDpt | theTranslation |
| bool | theAffineEnabledFlag |
| NEWMAT::Matrix | theForwardXform |
| NEWMAT::Matrix | theInverseXform |
Protected Attributes inherited from ossim2dTo2dTransform | |
| double | theConvergenceThreshold |
| int | theMaxIterations |
| ossimDpt | theDxDy |
Definition at line 16 of file ossimAffineTransform.h.
| ossimAffineTransform::ossimAffineTransform | ( | ) |
Definition at line 25 of file ossimAffineTransform.cpp.
References setIdentity().
| ossimAffineTransform::ossimAffineTransform | ( | const ossimAffineTransform & | src | ) |
Definition at line 38 of file ossimAffineTransform.cpp.
protected |
Definition at line 210 of file ossimAffineTransform.cpp.
References ossimMatrix3x3::createRotationZMatrix(), ossimMatrix3x3::createScaleMatrix(), ossimMatrix3x3::createTranslationMatrix(), theForwardXform, theInverseXform, theRotation, theScale, theTranslation, ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), setIdentity(), and setMatrix().
inlinevirtual |
Definition at line 30 of file ossimAffineTransform.h.
Implements ossim2dTo2dTransform.
Definition at line 70 of file ossimAffineTransform.cpp.
References theAffineEnabledFlag, theForwardXform, ossimDpt::x, and ossimDpt::y.
inlinevirtual |
Used by the inverse iterator. This will give it a good initial value that is within the input transforms
Reimplemented from ossim2dTo2dTransform.
Definition at line 43 of file ossimAffineTransform.h.
inline |
Definition at line 83 of file ossimAffineTransform.h.
inline |
Definition at line 75 of file ossimAffineTransform.h.
inline |
Definition at line 79 of file ossimAffineTransform.h.
Definition at line 91 of file ossimAffineTransform.cpp.
References theAffineEnabledFlag, theInverseXform, ossimDpt::x, and ossimDpt::y.
Definition at line 144 of file ossimAffineTransform.cpp.
References computeMatrix(), ossimKeywordlist::find(), ossim2dTo2dTransform::loadState(), ossimKeywordNames::ROTATION_KW, ossimKeywordNames::SCALE_X_KW, ossimKeywordNames::SCALE_Y_KW, theRotation, theScale, theTranslation, ossimKeywordNames::TRANSLATION_X_KW, ossimKeywordNames::TRANSLATION_Y_KW, ossimDpt::x, and ossimDpt::y.
| rhs | The data to assign from. |
| A | reference to this object. |
Definition at line 50 of file ossimAffineTransform.cpp.
References ossim2dTo2dTransform::operator=(), theAffineEnabledFlag, theForwardXform, theInverseXform, theRotation, theScale, and theTranslation.
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 230 of file ossimAffineTransform.cpp.
References theRotation, theScale, and theTranslation.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 112 of file ossimAffineTransform.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::ROTATION_KW, ossim2dTo2dTransform::saveState(), ossimKeywordNames::SCALE_X_KW, ossimKeywordNames::SCALE_Y_KW, theRotation, theScale, theTranslation, ossimKeywordNames::TRANSLATION_X_KW, ossimKeywordNames::TRANSLATION_Y_KW, ossimDpt::x, and ossimDpt::y.
inline |
Definition at line 89 of file ossimAffineTransform.h.
| void ossimAffineTransform::setIdentity | ( | ) |
Definition at line 196 of file ossimAffineTransform.cpp.
References computeMatrix(), theRotation, theScale, theTranslation, ossimDpt::x, and ossimDpt::y.
Referenced by ossimAffineTransform().
| void ossimAffineTransform::setMatrix | ( | double | rotation, |
| const ossimDpt & | scale, | ||
| const ossimDpt & | translation | ||
Definition at line 182 of file ossimAffineTransform.cpp.
References computeMatrix(), theRotation, theScale, and theTranslation.
inline |
Definition at line 64 of file ossimAffineTransform.h.
inline |
Definition at line 58 of file ossimAffineTransform.h.
inline |
Definition at line 70 of file ossimAffineTransform.h.
protected |
Definition at line 101 of file ossimAffineTransform.h.
Referenced by forward(), inverse(), and operator=().
protected |
Definition at line 103 of file ossimAffineTransform.h.
Referenced by computeMatrix(), forward(), and operator=().
protected |
Definition at line 104 of file ossimAffineTransform.h.
Referenced by computeMatrix(), inverse(), and operator=().
protected |
Definition at line 99 of file ossimAffineTransform.h.
Referenced by computeMatrix(), loadState(), operator=(), print(), saveState(), setIdentity(), and setMatrix().
protected |
Definition at line 98 of file ossimAffineTransform.h.
protected |
Definition at line 100 of file ossimAffineTransform.h.
