#include <ossimVerticesFinderTool.h>
| ossimVerticesFinderTool () | |
| ~ossimVerticesFinderTool () | |
| virtual void | setUsage (ossimArgumentParser &ap) |
| Initializes the aurgument parser with expected parameters and options. More... | |
| virtual bool | initialize (ossimArgumentParser &ap) |
| Initializes from command line arguments. More... | |
| virtual void | initialize (const ossimKeywordlist &kwl) |
| Reads processing params from KWL and prepares for execute. More... | |
| virtual bool | execute () |
| Writes product to output file if applicable. More... | |
| virtual void | getKwlTemplate (ossimKeywordlist &kwl) |
| Assigns a template keywordlist to string for initializing derived classes. More... | |
Public Member Functions inherited from ossimTool | |
| ossimTool () | |
| virtual | ~ossimTool () |
| virtual void | loadJSON (const Json::Value &json_request) |
| Reads processing params from JSON object provided. More... | |
| virtual void | saveJSON (Json::Value &json) const |
| Fetch product as JSON object when applicable Always returns true since using exception on error. More... | |
| virtual const std::string & | getResponse () const |
| Fetch product as string (typically JSON) when applicable, otherwise passes back empty string. More... | |
| virtual void | clear () |
| Disconnects and clears the DEM and image layers. More... | |
| virtual void | abort () |
| Kills current (asynchronous) process. More... | |
| void | getAPI (std::string &out) const |
| Outputs a JSON representation of the Utility's API. More... | |
| std::string | getAPI () const |
| void | getBuildDate (std::string &s) const |
| Gets build date. More... | |
| void | getRevision (std::string &s) const |
| Gets revision. More... | |
| void | getVersion (std::string &s) const |
| Gets version. More... | |
| virtual bool | isChipProcessor () const |
| Overrides base class implementation to indicate this class supports getChip() calls. More... | |
| void | setOutputStream (std::ostream *os) |
| Redirects any console output to the supplied stream for logging or JNI application. More... | |
| bool | helpRequested () const |
| Returns true when the initialization detects a "--help" option, so caller can avoid subsequent execute() call. More... | |
| ossimObject () | |
Public Member Functions inherited from ossim::JsonInterface | |
| JsonInterface () | |
| virtual | ~JsonInterface () |
Static Public Attributes | |
| static const char * | DESCRIPTION |
| Used by ossimUtilityFactory. More... | |
Protected Attributes | |
| ossimFilename | m_inputFile |
| ossimFilename | m_outputFile |
| ossim_uint32 | m_entryIndex |
Protected Attributes inherited from ossimTool | |
| ossimKeywordlist | m_kwl |
| std::ostream * | m_consoleStream |
| bool | m_helpRequested |
| std::string | m_response |
Class for determining the active image corner vertices inside larger null-filled image rectangle.
Definition at line 18 of file ossimVerticesFinderTool.h.
| ossimVerticesFinderTool::ossimVerticesFinderTool | ( | ) |
Definition at line 27 of file ossimVerticesFinderTool.cpp.
| ossimVerticesFinderTool::~ossimVerticesFinderTool | ( | ) |
Definition at line 32 of file ossimVerticesFinderTool.cpp.
The product may also beAlways returns true since using exception on error.
Implements ossimTool.
Definition at line 126 of file ossimVerticesFinderTool.cpp.
References ossimListenerManager::addListener(), ossimVertexExtractor::execute(), ossimRefPtr< T >::get(), ossimImageHandler::getBoundingRect(), ossimImageHandlerRegistry::instance(), m_entryIndex, ossimTool::m_helpRequested, m_inputFile, m_outputFile, ossimImageHandlerRegistry::open(), ossimVertexExtractor::setAreaOfInterest(), ossimImageHandler::setCurrentEntry(), ossimVertexExtractor::setOutputName(), and ossimRefPtr< T >::valid().
inlinevirtual |
Reimplemented from ossimTool.
Definition at line 32 of file ossimVerticesFinderTool.h.
Definition at line 165 of file ossimVerticesFinderTool.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::ENTRY_KW, ossimKeywordNames::IMAGE_FILE_KW, and ossimKeywordNames::OUTPUT_FILE_KW.
This base class has some common arguments to read. The derived class should call this implementation in addition to setting its own arguments.
| ap | Represents command line. |
Definition at line 55 of file ossimVerticesFinderTool.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::addPair(), ossimArgumentParser::argc(), ossimKeywordNames::ENTRY_KW, ossimKeywordNames::IMAGE_FILE_KW, ossimTool::initialize(), ossimTool::m_helpRequested, ossimTool::m_kwl, ossimNotify(), ossimNotifyLevel_NOTICE, ossimKeywordNames::OUTPUT_FILE_KW, ossimArgumentParser::read(), and ossimArgumentParser::remove().
Returns TRUE if successful.
| kwl | Full keyword-list representing state |
Definition at line 90 of file ossimVerticesFinderTool.cpp.
References ossimKeywordlist::addList(), ossimKeywordlist::clear(), ossimFilename::dirCat(), ossimString::empty(), ossimKeywordNames::ENTRY_KW, ossimFilename::fileNoExtension(), ossimKeywordlist::find(), ossimKeywordNames::IMAGE_FILE_KW, ossimFilename::isReadable(), m_entryIndex, m_inputFile, ossimTool::m_kwl, m_outputFile, ossimKeywordNames::OUTPUT_FILE_KW, ossimFilename::path(), and ossimString::toUInt32().
It does not output anything. To see the usage, the caller will need to do something like:
ap.getApplicationUsage()->write(<ostream>);
This base class has some common arguments to add. The derived class should call this implementation in addition to setting its own arguments.
Definition at line 36 of file ossimVerticesFinderTool.cpp.
References ossimApplicationUsage::addCommandLineOption(), DESCRIPTION, ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimApplicationUsage::setCommandLineUsage(), ossimApplicationUsage::setDescription(), and ossimTool::setUsage().
static |
Definition at line 37 of file ossimVerticesFinderTool.h.
Referenced by ossimToolFactory::getCapabilities(), and setUsage().
protected |
Definition at line 42 of file ossimVerticesFinderTool.h.
Referenced by execute(), and initialize().
protected |
Definition at line 40 of file ossimVerticesFinderTool.h.
protected |
Definition at line 41 of file ossimVerticesFinderTool.h.
