#include <ossimSensorModelTuple.h>
Public Types | |
| enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
| enum | IntersectStatus { OP_SUCCESS = 0, ERROR_PROP_FAIL = 1, OP_FAIL = 2 } |
| ossimSensorModelTuple () | |
| ~ossimSensorModelTuple () | |
| void | addImage (ossimSensorModel *image) |
| Method to add an image to the tuple. More... | |
| print method. More... | |
| ossimSensorModelTuple::IntersectStatus | intersect (const DptSet_t obs, ossimEcefPoint &pt, NEWMAT::Matrix &covMat) const |
| Multi-image intersection method. More... | |
| ossimSensorModelTuple::IntersectStatus | intersect (const ossim_int32 &img, const ossimDpt &obs, ossimEcefPoint &pt, NEWMAT::Matrix &covMat) |
| Single-image/DEM intersection method. More... | |
| ossimSensorModelTuple::IntersectStatus | intersect (const ossim_int32 &img, const ossimDpt &obs, const ossim_float64 &heightAboveEllipsoid, ossimEcefPoint &pt, NEWMAT::Matrix &covMat) |
| Single-image/height intersection method. More... | |
| bool | setIntersectionSurfaceAccuracy (const ossim_float64 &surfCE90, const ossim_float64 &surfLE90) |
| Set intersection surface accuracy method. More... | |
| void | getRpcPqeInputs (ossimRpcPqeInputs &obj) const |
Private Member Functions | |
| bool | computeSingleInterCov (const ossim_int32 &img, const ossimDpt &obs, const ossimGpt &ptG, HeightRefType_t cRefType, NEWMAT::Matrix &covMat) |
| Compute single image intersection covariance matrix. More... | |
| bool | getGroundObsEqComponents (const ossim_int32 img, const ossimDpt &obs, const ossimGpt &ptEst, ossimDpt &resid, NEWMAT::Matrix &B, NEWMAT::SymmetricMatrix &W) const |
| Get observation equation components. More... | |
| NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
Private Attributes | |
| std::vector< ossimRefPtr< ossimSensorModel > > | theImages |
| ossim_int32 | theNumImages |
| ossim_float64 | theSurfCE90 |
| ossim_float64 | theSurfLE90 |
| bool | theSurfAccSet |
| bool | theSurfAccRepresentsNoDEM |
| ossimRpcPqeInputs | theRpcPqeInputs |
| Rpc model only, container to capture pqe inputs for report purposes only. More... | |
Definition at line 42 of file ossimSensorModelTuple.h.
| Enumerator | |
| OBS_INIT | |
| EVALUATE | |
| P_WRT_X | |
| P_WRT_Y | |
| P_WRT_Z | |
Definition at line 46 of file ossimSensorModelTuple.h.
| ossimSensorModelTuple::ossimSensorModelTuple | ( | ) |
default constructor
Definition at line 52 of file ossimSensorModelTuple.cpp.
| ossimSensorModelTuple::~ossimSensorModelTuple | ( | ) |
virtual destructor
Definition at line 79 of file ossimSensorModelTuple.cpp.
| void ossimSensorModelTuple::addImage | ( | ossimSensorModel * | image | ) |
Definition at line 94 of file ossimSensorModelTuple.cpp.
References theImages, and theNumImages.
Referenced by main().
private |
| img | Image set index of current image. |
| obs | Image point observations. |
| ptG | Current ground estimate. |
| cRefType | Current height reference type. |
| covMat | 3X3 ECF position covariance matrix. |
Definition at line 403 of file ossimSensorModelTuple.cpp.
Referenced by intersect().
private |
| iter | Current iteration. |
| obs | Observations. |
| ptEst | Current ground estimate. |
| resid | Observation residuals. |
| B | Matrix of partials of observations WRT X,Y,Z. |
| W | Weight matrix of observations. |
Definition at line 351 of file ossimSensorModelTuple.cpp.
| void ossimSensorModelTuple::getRpcPqeInputs | ( | ossimRpcPqeInputs & | obj | ) | const |
| obj | Object to initialize with rpc pqe inputs. |
Definition at line 145 of file ossimSensorModelTuple.cpp.
References theRpcPqeInputs.
| ossimSensorModelTuple::IntersectStatus ossimSensorModelTuple::intersect | ( | const DptSet_t | obs, |
| ossimEcefPoint & | pt, | ||
| NEWMAT::Matrix & | covMat | ||
| ) | const |
| obs | Vector of image point observations. |
| pt | Intersected ECF position of point. |
| covMat | 3X3 ECF position covariance matrix [m]. |
Definition at line 173 of file ossimSensorModelTuple.cpp.
References OP_FAIL.
| ossimSensorModelTuple::IntersectStatus ossimSensorModelTuple::intersect | ( | const ossim_int32 & | img, |
| const ossimDpt & | obs, | ||
Definition at line 319 of file ossimSensorModelTuple.cpp.
References AT_DEM, computeSingleInterCov(), ERROR_PROP_FAIL, OP_FAIL, OP_SUCCESS, and theImages.
| const ossim_float64 & | heightAboveEllipsoid, | ||
| heightAboveEllipsoid | Desired intersection height [m]. |
: This method's "const" qualifier was removed as it stores rpc inputs to the pqe constructor for report purposes.
Definition at line 285 of file ossimSensorModelTuple.cpp.
References AT_HGT, computeSingleInterCov(), ERROR_PROP_FAIL, OP_FAIL, OP_SUCCESS, and theImages.
private |
Definition at line 623 of file ossimSensorModelTuple.cpp.
References SVD().
| std::ostream & ossimSensorModelTuple::print | ( | std::ostream & | out | ) | const |
print method.
Definition at line 156 of file ossimSensorModelTuple.cpp.
| bool ossimSensorModelTuple::setIntersectionSurfaceAccuracy | ( | const ossim_float64 & | surfCE90, |
| const ossim_float64 & | surfLE90 | ||
| surfCE90 | 90% CE [m]. |
| surfLE90 | 90% LE [m]. |
Definition at line 110 of file ossimSensorModelTuple.cpp.
References theSurfAccRepresentsNoDEM, theSurfAccSet, theSurfCE90, and theSurfLE90.
mutableprivate |
Definition at line 146 of file ossimSensorModelTuple.h.
Referenced by addImage(), intersect(), and print().
private |
Definition at line 148 of file ossimSensorModelTuple.h.
Referenced by addImage(), and print().
private |
Definition at line 158 of file ossimSensorModelTuple.h.
Referenced by getRpcPqeInputs().
private |
Definition at line 153 of file ossimSensorModelTuple.h.
Referenced by setIntersectionSurfaceAccuracy().
private |
Definition at line 152 of file ossimSensorModelTuple.h.
private |
Definition at line 150 of file ossimSensorModelTuple.h.
private |
Definition at line 151 of file ossimSensorModelTuple.h.
