The factory registry for overview builders. More...
#include <ossimOverviewBuilderFactoryRegistry.h>
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimOverviewBuilderBase * | createBuilder (const ossimString &typeName) const |
| Creates a builder from a string. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Method to populate a list of supported types of all factories registered to this registry. More... | |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
Public Member Functions inherited from ossimFactoryListInterface< ossimOverviewBuilderFactoryBase, ossimOverviewBuilderBase > | |
| ossimFactoryListInterface () | |
| void | addFactory (ossimOverviewBuilderFactoryBase *factory) |
| This is for backward compatability and calls registerFactory for simple adds. More... | |
| bool | isFactoryRegistered (ossimOverviewBuilderFactoryBase *factory) const |
| Public access method to determine if a factory is already registered to this list. More... | |
| void | registerFactory (ossimOverviewBuilderFactoryBase *factory, bool pushToFrontFlag=false) |
| Will register a factory to the factory list. More... | |
| void | unregisterFactory (ossimOverviewBuilderFactoryBase *factory) |
| Will remove the factory from the registry. More... | |
| void | unregisterFactory (const ossimString &factoryTypeName) |
| Will remove the factory from the registry by name. More... | |
| void | unregisterAllFactories () |
| Will remove all factories from the registry. More... | |
| void | registerFactoryToFront (ossimOverviewBuilderFactoryBase *factory) |
| Inserts the factory to the front of the list. More... | |
| void | registerFactoryBefore (ossimOverviewBuilderFactoryBase *factory, ossimOverviewBuilderFactoryBase *beforeThisFactory) |
| Will insert the factory before the beforeThisFactory. More... | |
| void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
| Will add all object types the factories can allocate. More... | |
| ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
| This is the base object return for all objects in the system. More... | |
| ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimOverviewBuilderBase * | createNativeObjectFromRegistry (const ossimString &typeName) const |
| This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More... | |
| ossimOverviewBuilderBase * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| static ossimOverviewBuilderFactoryRegistry * | instance () |
| instance method for access to theInstance pointer. More... | |
Private Member Functions | |
| ossimOverviewBuilderFactoryRegistry () | |
| default constructor hidden from use More... | |
| ossimOverviewBuilderFactoryRegistry (const ossimOverviewBuilderFactoryRegistry &obj) | |
| copy constructor hidden from use More... | |
| void | operator= (const ossimOverviewBuilderFactoryRegistry &rhs) |
| operator= hidden from use. More... | |
Static Private Attributes | |
| static ossimOverviewBuilderFactoryRegistry * | m_instance = 0 |
| The static instance of this class. More... | |
Public Types inherited from ossimFactoryListInterface< ossimOverviewBuilderFactoryBase, ossimOverviewBuilderBase > | |
| typedef std::vector< ossimOverviewBuilderFactoryBase *> | FactoryListType |
| typedef ossimOverviewBuilderFactoryBase | FactoryType |
| typedef ossimOverviewBuilderBase | NativeReturnType |
Protected Member Functions inherited from ossimFactoryListInterface< ossimOverviewBuilderFactoryBase, ossimOverviewBuilderBase > | |
| bool | findFactory (ossimOverviewBuilderFactoryBase *factory) const |
| Utility to find a factory in the list. More... | |
Protected Attributes inherited from ossimFactoryListInterface< ossimOverviewBuilderFactoryBase, ossimOverviewBuilderBase > | |
| std::mutex | m_factoryListMutex |
| FactoryListType | m_factoryList |
Typical usage: std::vector<ossimString> typeList; ossimOverviewBuilderFactoryRegistry::instance()->getTypeNameList(typeList); ossimOverviewBuilderBase* builder = ossimOverviewBuilderFactoryRegistry::instance()->createBuilder( someStringFromTypeList);
Definition at line 33 of file ossimOverviewBuilderFactoryRegistry.h.
private |
Definition at line 80 of file ossimOverviewBuilderFactoryRegistry.cpp.
References m_instance.
Referenced by instance().
private |
Definition at line 85 of file ossimOverviewBuilderFactoryRegistry.cpp.
| ossimOverviewBuilderBase * ossimOverviewBuilderFactoryRegistry::createBuilder | ( | const ossimString & | typeName | ) | const |
This should match a string from the getTypeNameList() method.
Definition at line 56 of file ossimOverviewBuilderFactoryRegistry.cpp.
References ossimFactoryListInterface< ossimOverviewBuilderFactoryBase, ossimOverviewBuilderBase >::m_factoryList.
Referenced by createObject().
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 29 of file ossimOverviewBuilderFactoryRegistry.cpp.
Creates and object given a keyword list.
Definition at line 34 of file ossimOverviewBuilderFactoryRegistry.cpp.
References createBuilder(), ossimString::empty(), ossimKeywordlist::find(), ossimSource::loadState(), ossimRefPtr< T >::release(), and ossimRefPtr< T >::valid().
Example:
ossimTiffOverviewNearest ossimTiffOverviewBox
| typeList | List of ossimStrings to add to. |
Definition at line 75 of file ossimOverviewBuilderFactoryRegistry.cpp.
Referenced by ossimImageUtil::outputOverviewWriterTypes(), and ossimInfo::printOverviewTypes().
static |
Definition at line 19 of file ossimOverviewBuilderFactoryRegistry.cpp.
References ossimObjectFactoryRegistry::instance(), m_instance, ossimOverviewBuilderFactoryRegistry(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
Referenced by ossimInit::initializeDefaultFactories(), ossimSharedLibraryFinalize(), ossimSharedLibraryInitialize(), ossimImageUtil::outputOverviewWriterTypes(), and ossimInfo::printOverviewTypes().
private |
Definition at line 91 of file ossimOverviewBuilderFactoryRegistry.cpp.
staticprivate |
Definition at line 87 of file ossimOverviewBuilderFactoryRegistry.h.
Referenced by instance(), and ossimOverviewBuilderFactoryRegistry().
