#include <ossimNitfXmlDataContentDes.h>
Public Types | |
| enum | { DESSHL_SIZE = 4, DESCRC_SIZE = 5, DESSHFT_SIZE = 8, DESSHDT_SIZE = 20, DESSHRP_SIZE = 40, DESSHSI_SIZE = 60, DESSHSV_SIZE = 10, DESSHSD_SIZE = 20, DESSHTN_SIZE = 120, DESSHLPG_SIZE = 125, DESSHLPT_SIZE = 25, DESSHLI_SIZE = 20, DESSHLIN_SIZE = 120, DESSHABS_SIZE = 200 } |
| ossimNitfXmlDataContentDes () | |
| virtual void | parseStream (std::istream &in) |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (std::ostream &out) |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| Pure virtual print method that outputs a key/value type format adding prefix to keys. More... | |
| virtual void | clearFields () |
| bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
| bool | loadValueFromXml (const ossimRefPtr< ossimXmlDocument >, const ossimString &xpath, ossimString &target) const |
| ossimString | getDesshl () const |
| ossim_uint32 | getDesshlAsUint32 () const |
| ossimString | getDescrc () const |
| ossimString | getDesshft () const |
| ossimString | getDesshdt () const |
| ossimString | getDesshrp () const |
| ossimString | getDesshsi () const |
| ossimString | getDesshsv () const |
| ossimString | getDesshsd () const |
| ossimString | getDesshtn () const |
Public Member Functions inherited from ossimNitfRegisteredDes | |
| ossimNitfRegisteredDes () | |
| ossimNitfRegisteredDes (const std::string &desName, ossim_uint32 desLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredDes () |
| destructor More... | |
| virtual std::string | getRegisterDesName () const |
| This will return the name of the registered des for this user defined header. More... | |
| virtual const std::string & | getDesName () const |
| virtual void | setDesName (const std::string &desName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the des from the CEL or REL field. More... | |
| virtual ossim_uint32 | getDesLength () const |
| virtual void | setDesLength (ossim_uint32 length) |
| Set the des length. More... | |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
Protected Attributes | |
| char | m_desshl [DESSHL_SIZE+1] |
| char | m_descrc [DESCRC_SIZE+1] |
| char | m_desshft [DESSHFT_SIZE+1] |
| char | m_desshdt [DESSHDT_SIZE+1] |
| char | m_desshrp [DESSHRP_SIZE+1] |
| char | m_desshsi [DESSHSI_SIZE+1] |
| char | m_desshsv [DESSHSV_SIZE+1] |
| char | m_desshsd [DESSHSD_SIZE+1] |
| char | m_desshtn [DESSHTN_SIZE+1] |
| char | m_desshlpg [DESSHLPG_SIZE+1] |
| char | m_desshlpt [DESSHLPT_SIZE+1] |
| char | m_desshli [DESSHLI_SIZE+1] |
| char | m_desshlin [DESSHLIN_SIZE+1] |
| char | m_desshabs [DESSHABS_SIZE+1] |
| ossimString | m_xmlString |
| ossimRefPtr< ossimXmlDocument > | m_xmlDocument |
Protected Attributes inherited from ossimNitfRegisteredDes | |
| std::string | m_desName |
| ossim_uint32 | m_desLength |
Definition at line 5 of file ossimNitfXmlDataContentDes.h.
| anonymous enum |
| Enumerator | |
| DESSHL_SIZE | |
| DESCRC_SIZE | |
| DESSHFT_SIZE | |
| DESSHDT_SIZE | |
| DESSHRP_SIZE | |
| DESSHSI_SIZE | |
| DESSHSV_SIZE | |
| DESSHSD_SIZE | |
| DESSHTN_SIZE | |
| DESSHLPG_SIZE | |
| DESSHLPT_SIZE | |
| DESSHLI_SIZE | |
| DESSHLIN_SIZE | |
| DESSHABS_SIZE | |
Definition at line 8 of file ossimNitfXmlDataContentDes.h.
| ossimNitfXmlDataContentDes::ossimNitfXmlDataContentDes | ( | ) |
Definition at line 9 of file ossimNitfXmlDataContentDes.cpp.
References clearFields().
Definition at line 94 of file ossimNitfXmlDataContentDes.cpp.
References DESCRC_SIZE, DESSHABS_SIZE, DESSHDT_SIZE, DESSHFT_SIZE, DESSHLI_SIZE, DESSHLIN_SIZE, DESSHLPG_SIZE, DESSHLPT_SIZE, DESSHRP_SIZE, DESSHSD_SIZE, DESSHSI_SIZE, DESSHSV_SIZE, DESSHTN_SIZE, m_descrc, m_desshabs, m_desshdt, m_desshft, m_desshli, m_desshlin, m_desshlpg, m_desshlpt, m_desshrp, m_desshsd, m_desshsi, m_desshsv, and m_desshtn.
Referenced by ossimNitfXmlDataContentDes(), and parseStream().
| ossimString ossimNitfXmlDataContentDes::getDescrc | ( | ) | const |
Definition at line 178 of file ossimNitfXmlDataContentDes.cpp.
References m_descrc.
| ossimString ossimNitfXmlDataContentDes::getDesshdt | ( | ) | const |
Definition at line 188 of file ossimNitfXmlDataContentDes.cpp.
References m_desshdt.
| ossimString ossimNitfXmlDataContentDes::getDesshft | ( | ) | const |
Definition at line 183 of file ossimNitfXmlDataContentDes.cpp.
References m_desshft.
| ossimString ossimNitfXmlDataContentDes::getDesshl | ( | ) | const |
| ossim_uint32 ossimNitfXmlDataContentDes::getDesshlAsUint32 | ( | ) | const |
| ossimString ossimNitfXmlDataContentDes::getDesshrp | ( | ) | const |
Definition at line 193 of file ossimNitfXmlDataContentDes.cpp.
References m_desshrp.
| ossimString ossimNitfXmlDataContentDes::getDesshsd | ( | ) | const |
Definition at line 208 of file ossimNitfXmlDataContentDes.cpp.
References m_desshsd.
| ossimString ossimNitfXmlDataContentDes::getDesshsi | ( | ) | const |
Definition at line 198 of file ossimNitfXmlDataContentDes.cpp.
References m_desshsi.
| ossimString ossimNitfXmlDataContentDes::getDesshsv | ( | ) | const |
Definition at line 203 of file ossimNitfXmlDataContentDes.cpp.
References m_desshsv.
| ossimString ossimNitfXmlDataContentDes::getDesshtn | ( | ) | const |
Definition at line 213 of file ossimNitfXmlDataContentDes.cpp.
References m_desshtn.
Definition at line 124 of file ossimNitfXmlDataContentDes.cpp.
References ossimKeywordlist::find(), m_descrc, m_desshdt, m_desshft, m_desshrp, m_desshsd, m_desshsi, m_desshsv, and m_desshtn.
| bool ossimNitfXmlDataContentDes::loadValueFromXml | ( | const ossimRefPtr< ossimXmlDocument > | xml, |
| const ossimString & | xpath, | ||
| ossimString & | target | ||
| ) | const |
Definition at line 163 of file ossimNitfXmlDataContentDes.cpp.
References ossimXmlDocument::findNodes(), and ossimErrorStatusInterface::getErrorStatus().
Implements ossimNitfRegisteredDes.
Definition at line 16 of file ossimNitfXmlDataContentDes.cpp.
References clearFields(), DESCRC_SIZE, DESSHABS_SIZE, DESSHDT_SIZE, DESSHFT_SIZE, DESSHLI_SIZE, DESSHLIN_SIZE, DESSHLPG_SIZE, DESSHLPT_SIZE, DESSHRP_SIZE, DESSHSD_SIZE, DESSHSI_SIZE, DESSHSV_SIZE, DESSHTN_SIZE, ossimNitfRegisteredDes::getSizeInBytes(), m_descrc, m_desshabs, m_desshdt, m_desshft, m_desshli, m_desshlin, m_desshlpg, m_desshlpt, m_desshrp, m_desshsd, m_desshsi, m_desshsv, m_desshtn, m_xmlDocument, m_xmlString, ossimXmlDocument::read(), and ossimString::string().
Reimplemented from ossimNitfRegisteredDes.
Definition at line 67 of file ossimNitfXmlDataContentDes.cpp.
References ossimNitfRegisteredDes::getDesName(), ossimPreferences::instance(), m_descrc, m_desshabs, m_desshdt, m_desshft, m_desshli, m_desshlpg, m_desshlpt, m_desshrp, m_desshsd, m_desshsi, m_desshsv, m_desshtn, m_xmlString, ossimString::substitute(), and ossimString::toBool().
Definition at line 49 of file ossimNitfXmlDataContentDes.cpp.
References DESCRC_SIZE, DESSHABS_SIZE, DESSHDT_SIZE, DESSHFT_SIZE, DESSHL_SIZE, DESSHLI_SIZE, DESSHLIN_SIZE, DESSHLPG_SIZE, DESSHLPT_SIZE, DESSHRP_SIZE, DESSHSD_SIZE, DESSHSI_SIZE, DESSHSV_SIZE, DESSHTN_SIZE, m_descrc, m_desshabs, m_desshdt, m_desshft, m_desshl, m_desshli, m_desshlin, m_desshlpg, m_desshlpt, m_desshrp, m_desshsd, m_desshsi, m_desshsv, and m_desshtn.
protected |
Definition at line 58 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDescrc(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 70 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
protected |
Definition at line 60 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDesshdt(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 59 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDesshft(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 57 of file ossimNitfXmlDataContentDes.h.
Referenced by writeStream().
protected |
Definition at line 68 of file ossimNitfXmlDataContentDes.h.
protected |
Definition at line 69 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), parseStream(), and writeStream().
protected |
Definition at line 66 of file ossimNitfXmlDataContentDes.h.
protected |
Definition at line 67 of file ossimNitfXmlDataContentDes.h.
protected |
Definition at line 61 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDesshrp(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 64 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDesshsd(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 62 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDesshsi(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 63 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDesshsv(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 65 of file ossimNitfXmlDataContentDes.h.
Referenced by clearFields(), getDesshtn(), loadState(), parseStream(), print(), and writeStream().
protected |
Definition at line 73 of file ossimNitfXmlDataContentDes.h.
Referenced by parseStream().
protected |
Definition at line 72 of file ossimNitfXmlDataContentDes.h.
Referenced by parseStream(), and print().
