#include <ossimGeoAnnotationLineObject.h>
| ossimGeoAnnotationLineObject (const ossimGpt &start, const ossimGpt &end, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimGeoAnnotationLineObject (const ossimGeoAnnotationLineObject &rhs) | |
| virtual void | applyScale (double x, double y) |
| virtual void | transform (ossimImageGeometry *projection) |
| virtual bool | intersects (const ossimDrect &rect) const |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual void | computeBoundingRect () |
Public Member Functions inherited from ossimGeoAnnotationObject | |
| ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs) | |
| Saves the current state of this object. More... | |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual ossimDrect | getBoundingRect () const |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual void | setThickness (ossim_uint8 thickness) |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
| virtual | ~ossimGeoAnnotationLineObject () |
Protected Member Functions inherited from ossimGeoAnnotationObject | |
| virtual | ~ossimGeoAnnotationObject () |
Protected Attributes | |
| ossimAnnotationLineObject * | theProjectedLineObject |
| ossimGpt | theStart |
| ossimGpt | theEnd |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
Definition at line 17 of file ossimGeoAnnotationLineObject.h.
| ossimGeoAnnotationLineObject::ossimGeoAnnotationLineObject | ( | const ossimGpt & | start, |
| const ossimGpt & | end, | ||
| unsigned char | r = 255, |
| unsigned char | g = 255, |
| unsigned char | b = 255, |
| long | thickness = 1 |
Referenced by dup().
| ossimGeoAnnotationLineObject::ossimGeoAnnotationLineObject | ( | const ossimGeoAnnotationLineObject & | rhs | ) |
Definition at line 40 of file ossimGeoAnnotationLineObject.cpp.
protectedvirtual |
Definition at line 50 of file ossimGeoAnnotationLineObject.cpp.
References theProjectedLineObject.
Implements ossimAnnotationObject.
Definition at line 64 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::applyScale(), ossimGpt::latd(), ossimGpt::lond(), theEnd, theProjectedLineObject, theStart, x, and y.
Definition at line 131 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::computeBoundingRect(), and theProjectedLineObject.
Definition at line 98 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::draw(), and theProjectedLineObject.
Definition at line 59 of file ossimGeoAnnotationLineObject.cpp.
References ossimGeoAnnotationLineObject().
Definition at line 126 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::getBoundingRect(), and theProjectedLineObject.
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 113 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::getNewClippedObject(), intersects(), and theProjectedLineObject.
Definition at line 103 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::intersects(), and theProjectedLineObject.
Referenced by getNewClippedObject().
Generic print method.
Derived classes should re-implement as they see fit.
Reimplemented from ossimAnnotationObject.
Definition at line 91 of file ossimGeoAnnotationLineObject.cpp.
References theEnd, and theStart.
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 77 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::setLine(), theEnd, theProjectedLineObject, theStart, and ossimImageGeometry::worldToLocal().
protected |
Definition at line 45 of file ossimGeoAnnotationLineObject.h.
Referenced by applyScale(), print(), and transform().
protected |
Definition at line 43 of file ossimGeoAnnotationLineObject.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getBoundingRect(), getNewClippedObject(), intersects(), transform(), and ~ossimGeoAnnotationLineObject().
protected |
Definition at line 44 of file ossimGeoAnnotationLineObject.h.
