#include <ossimGeoAnnotationGdBitmapFont.h>
| ossimGeoAnnotationGdBitmapFont (const ossimGpt &position=ossimGpt(0, 0, 0), const ossimString &text=ossimString(""), ossimGdFontPtr font=ossimGdFontLarge, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimGeoAnnotationGdBitmapFont (const ossimGeoAnnotationGdBitmapFont &rhs) | |
| virtual void | applyScale (double x, double y) |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual bool | intersects (const ossimDrect &rect) const |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual void | computeBoundingRect () |
| virtual void | transform (ossimImageGeometry *projection) |
| virtual void | setText (const ossimString &text) |
| virtual void | setFont (ossimGdFontPtr font) |
Public Member Functions inherited from ossimGeoAnnotationObject | |
| ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs) | |
| Saves the current state of this object. More... | |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual ossimDrect | getBoundingRect () const |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual void | setThickness (ossim_uint8 thickness) |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
| virtual | ~ossimGeoAnnotationGdBitmapFont () |
Protected Member Functions inherited from ossimGeoAnnotationObject | |
| virtual | ~ossimGeoAnnotationObject () |
Protected Attributes | |
| ossimRefPtr< ossimAnnotationGdBitmapFont > | theProjectedFont |
| ossimGpt | thePosition |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
Definition at line 18 of file ossimGeoAnnotationGdBitmapFont.h.
| ossimGeoAnnotationGdBitmapFont::ossimGeoAnnotationGdBitmapFont | ( | const ossimGpt & | position = ossimGpt(0, 0, 0), |
| const ossimString & | text = ossimString(""), |
| ossimGdFontPtr | font = ossimGdFontLarge, |
| unsigned char | r = 255, |
| unsigned char | g = 255, |
| unsigned char | b = 255, |
| long | thickness = 1 |
Referenced by dup().
| ossimGeoAnnotationGdBitmapFont::ossimGeoAnnotationGdBitmapFont | ( | const ossimGeoAnnotationGdBitmapFont & | rhs | ) |
Definition at line 39 of file ossimGeoAnnotationGdBitmapFont.cpp.
protectedvirtual |
Definition at line 46 of file ossimGeoAnnotationGdBitmapFont.cpp.
References theProjectedFont.
Implements ossimAnnotationObject.
Definition at line 56 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::applyScale(), ossimGpt::latd(), ossimGpt::lond(), thePosition, theProjectedFont, ossimRefPtr< T >::valid(), x, and y.
Definition at line 107 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::computeBoundingRect(), and theProjectedFont.
Definition at line 74 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::draw(), and theProjectedFont.
Definition at line 51 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimGeoAnnotationGdBitmapFont().
Definition at line 79 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::getBoundingRect(), and theProjectedFont.
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 94 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::getNewClippedObject(), intersects(), theProjectedFont, and ossimRefPtr< T >::valid().
Definition at line 84 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::intersects(), theProjectedFont, and ossimRefPtr< T >::valid().
Referenced by getNewClippedObject().
Generic print method.
Derived classes should re-implement as they see fit.
Reimplemented from ossimAnnotationObject.
Definition at line 67 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::print(), thePosition, and theProjectedFont.
Definition at line 124 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::setFont(), and theProjectedFont.
Definition at line 119 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::setText(), and theProjectedFont.
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 112 of file ossimGeoAnnotationGdBitmapFont.cpp.
References ossimAnnotationGdBitmapFont::setUpperLeftTextPosition(), thePosition, theProjectedFont, and ossimImageGeometry::worldToLocal().
protected |
Will be the upper left corner of text;
Definition at line 54 of file ossimGeoAnnotationGdBitmapFont.h.
Referenced by applyScale(), print(), and transform().
protected |
Definition at line 49 of file ossimGeoAnnotationGdBitmapFont.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getBoundingRect(), getNewClippedObject(), intersects(), print(), setFont(), setText(), transform(), and ~ossimGeoAnnotationGdBitmapFont().
