The ossim overview builder factory. More...
#include <ossimGdalOverviewBuilderFactory.h>
| virtual | ~ossimGdalOverviewBuilderFactory () |
| virtual ossimOverviewBuilderBase * | createBuilder (const ossimString &typeName) const |
| Creates a builder from a string. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Method to populate a list of supported types for the factory. More... | |
Public Member Functions inherited from ossimOverviewBuilderFactoryBase | |
| ossimOverviewBuilderFactoryBase () | |
| default constructor hidden from use More... | |
| virtual | ~ossimOverviewBuilderFactoryBase () |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimGdalOverviewBuilderFactory * | instance () |
| static instance method. More... | |
Private Member Functions | |
| ossimGdalOverviewBuilderFactory () | |
| ossimGdalOverviewBuilderFactory (const ossimGdalOverviewBuilderFactory &obj) | |
| copy constructor hidden from use More... | |
| void | operator= (const ossimGdalOverviewBuilderFactory &rhs) |
| operator= hidden from use. More... | |
Static Private Attributes | |
| static ossimGdalOverviewBuilderFactory * | theInstance = 0 |
Definition at line 26 of file ossimGdalOverviewBuilderFactory.h.
virtual destructor
Definition at line 27 of file ossimGdalOverviewBuilderFactory.cpp.
References theInstance.
private |
Definition at line 56 of file ossimGdalOverviewBuilderFactory.cpp.
Referenced by instance().
private |
Definition at line 60 of file ossimGdalOverviewBuilderFactory.cpp.
This should match a string from the getTypeNameList() method. Pure virtual.
Implements ossimOverviewBuilderFactoryBase.
Definition at line 32 of file ossimGdalOverviewBuilderFactory.cpp.
References ossimOverviewBuilderBase::hasOverviewType(), ossimRefPtr< T >::release(), ossimOverviewBuilderBase::setOverviewType(), and true.
registered to this registry. Pure virtual.
| typeList | List of ossimStrings to add to. |
Definition at line 49 of file ossimGdalOverviewBuilderFactory.cpp.
References ossimOverviewBuilderBase::getTypeNameList().
static |
Definition at line 18 of file ossimGdalOverviewBuilderFactory.cpp.
References ossimGdalOverviewBuilderFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
private |
Definition at line 65 of file ossimGdalOverviewBuilderFactory.cpp.
staticprivate |
Definition at line 65 of file ossimGdalOverviewBuilderFactory.h.
Referenced by instance(), and ~ossimGdalOverviewBuilderFactory().
